Old 12-11-2006, 02:57 PM   #1171
Trader Rating: 26 (100%+)
I have completed building the car and followed all prewarnings from xray. Even took it apart once to insure the bearings had plenty of oil. 3 things I have noticed.
1. One way installed, put a dab of grease on the pins that hold the wheel hubs. The right front has a clicking noise, but I cannot figure what is causing it.
2. I noticed play / movement with the servo saver shaft in the chassis.
3. During the re-oiling of the wheel bearings, there was already a noticeable amount of black residue/wear on the bearings. I had only ran the car for a minute or 2 during initial setup on the bench. Really not long enough to heat anything up.
svines1972 is offline   Reply With Quote
Old 12-11-2006, 10:24 PM   #1172
Have another question. Does Xray make a servo horn for Hitec servos that will work on the T2 007?
Old 12-11-2006, 11:22 PM   #1173
James's Avatar
Trader Rating: 11 (100%+)
I raced a fresh T2 007 at the aus nationals not long ago, and did fairly well, however five or six bearings just blew up, ceased, melted, whatever. mainly in the hubs, but also on the layshaft.
I pre-oiled them, ran them for the two practice days, but didnt check/clean/oil them for the qualifying and mains.. I SHOULD HAVE. It caused me no end of problems. I ended up putting most of my old T2 bearings in, and throwing most of the 007 bearings in the bin.
I then raced a meet on carpet, during my run, the car started to feel slow, I could hear a small squeeling sound as I was driving, I had my pit man check it... (i pulled over). the front right hub bearings has ceased up, teh drive shaft was stil turnng inside the bearing, heating up, it melted the inside of the hub, melted the bearing covers, and MELTED THE WHEEL. The actual hex in the wheel was melted. my pit man burnt his hand when he went to take the wheel off (just from touching the rim!)
So incase you haven't read the warning from XRAY regarding the bearings... READ IT.
To be honest, I dont want to have to pull and rebuild all my car's bearings after every single race meet, esp for a regular club meet, I like to run say 5 or so meets (of 5 races) before having to rebuild my bearings.... looks like I'll be using 'lesser precision' bearings from now on...
I know the T2 is a professional kit, but it's so professional that I need to do a bearing rebuild every time I take the car out to race? damn....
anyway, I'm sure there are plenty of 'these bearings suck' rants already... I'll quit my sulking now! heh
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 12-11-2006, 11:32 PM   #1174
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
WOW,
I read the instructions, Lubed the bearings well.
Ran the car probably 15-20 times now and the bearings are still smooth.
Not to say I don't hit stuff, cause the Lord knows I do. But if you hit stuff allot especially the rims they really don't transfer damage but to the weakest part in the drive train. (i.e. the bearings). I had this same issue with my RDX when I would hit dots or barriers, the bearing would get smooshed and cause all sorts of issues from bend CVDs to broken knuckles.
Best bet is to make sure your bearings are clean and lubed after each race weekend. I know its a pain but a .99cent part is easy to replace and saves you much more expensive parts from breakage.
Hope that helps,
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-12-2006, 12:15 AM   #1175
Anthony.L's Avatar
Trader Rating: 36 (100%+)
I also lubed the bearings well while building the car and after two 2-day race weekends on carpet the bearings are still very smooth and free.
Anthony.L is offline   Reply With Quote
Old 12-12-2006, 02:41 AM   #1176
Default conversion for rubber
these are the parts needed:
301179 upper deck
302018 front bulkhead 2pcs
302504 quick saver
303018 rear bulkhead 2pcs
303019 right layshift bulhead 1pcs
303029 motor mount
this is for rubber tires and it works well.
ptjonesus is offline   Reply With Quote
Old 12-12-2006, 05:40 AM   #1177
Joel Lagace's Avatar
For some reason they dont... i only use hitec servos I use a red kimbro sevo arm and dremel out what i dont need. ITs the only solution
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-12-2006, 06:23 AM   #1178
Trader Rating: 52 (100%+)
Originally Posted by EAMotorsports
I'd like to take a minute and welcome Mo Denton to the Xray team for 2007. Mo will be a valuable addition to the Xray USA Team.
EA
thanks guys
I look foward to a good year.We will see what a new ride brings for the upcoming events, so far testing went better than expected
Mo
Mo Denton is offline   Reply With Quote
Old 12-12-2006, 08:23 AM   #1179
seaball's Avatar
Send a message via Yahoo to seaball
uh-oh.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-12-2006, 08:37 AM   #1180
Send a message via AIM to R/C Anonymous
I had 7 bearings seize up on my '007. It didn't bother me much though. Just thought it was rather odd. I just replaced them with something else. I had 6 wheel bearings and one layshaft bearing go out. It's a good excuse for when you don't do good. Just tell' em a bearing locked up.
Anyways I haven't had any more problems the last couple times.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-12-2006, 09:36 AM   #1181
syndr0me's Avatar
Trader Rating: 32 (100%+)
You might all know this already, but bearing kits for the car are pretty cheap.
ABEC 3: $6.74
ABEC 5: $8.76
Are the "higher precision" bearings that are causing trouble ABEC 5 instead of 3? Was that the change, or is it something else?
syndr0me is offline   Reply With Quote
Old 12-12-2006, 10:00 AM   #1182
Michael Barch's Avatar
Send a message via AIM to Michael Barch
I'm not reading through all 40 pages, but after reading a few I came up with this. The '007 is better suited for carpet racing, and fixed what the T2 lacked in that department. Also, by just reading this last page, is something wrong with the bearings XRAY supplies? I never had to lube my bearings that often before.
I'm just getting back into the R/C swing of things (see my thread). I had a T2 when they first came out, now that I sold it, and I'm thinking of the '007.
Michael Barch is offline   Reply With Quote
Old 12-12-2006, 11:29 AM   #1183
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
It seems a lot of people are using the Futaba S9550 servo for the T2 and T2 '007, what servo mounting whole does it use? The narrower or wider? Hope that makes sense.
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 12-12-2006, 11:46 AM   #1184
Has anyone else noticed these items? Recommendations?
Old 12-12-2006, 11:48 AM   #1185
Fred Hubbard's Avatar
-The '007 is better suited for carpet racing, and fixed what the T2 lacked in that department.
Keep in mind the '007 comes in 2 versions, rubber and foam tire. So your observation is only half true.
-Also, by just reading this last page, is something wrong with the bearings XRAY supplies?
Nothing wrong in terms of a manufacturing defect. XRay is saying that these bearings have tighter tolerances and so they need to be lubed sufficiently until they are broken in.
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Fred Hubbard is offline   Reply With Quote
