Old 12-07-2006, 03:23 PM   #1141
Trader Rating: 26 (100%+)
So, a set of yellow, white, and blue would be a good starting point along with the Gold and Silver that came with the car?
svines1972 is offline   Reply With Quote
Old 12-07-2006, 03:27 PM   #1142
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Yeah, yellows, whites, and light blues shouild be some good oene to get if you are running asphalt.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-07-2006, 03:30 PM   #1143
I will be running carpet/rubber & asphalt/rubber.
Old 12-07-2006, 03:33 PM   #1144
That should be pretty good for both
Old 12-07-2006, 04:06 PM   #1145
part-time racer's Avatar
svines1972: If you look on the xray site, you can see the set-up section. So far, most team drivers have only tested the car on carpet with rubber and in almost all cases the standard springs which get supplied with the kit are used.
With the T2'007, even the smallest shock mounting positions change has a real effect.
A friend of mine this year completed the whole of the UK National season with the standard springs (Silver / Gold).
Richard Clarke
EWS Event Organizer
CPD Racing ___MuchMore-UK___Awesomatix UK___OTM Racing
part-time racer is offline   Reply With Quote
Old 12-09-2006, 12:11 PM   #1146
Looking for some advice on electronic layout.
I've got a Novak GTX and Futaba HRS receiver. It's REALLY tight if I put everything side by side. Too tight I think. Do you guys recommend putting the receiver on top of the servo or standing the receiver up, so it's on its side.
Thanks.
jon123 is offline   Reply With Quote
Old 12-09-2006, 01:04 PM   #1147
Thanks.
Stand the receiver on it's side...
It always kills-me to see when people dish-out boat-loads of money to buy the latest "low-cg" car and then proceed in installing the receiver on the servo. Kinda defeats the purpose IMO.
As for space on the '007 - if you mount the HRS receiver on it's side, you should be good-to-go.
duckman996 is offline   Reply With Quote
Old 12-09-2006, 01:29 PM   #1148
Joel Lagace's Avatar
WOW i thought there was lots of room on the chassis.
Excuse my sloppy wire job but here is 925servo,hrs receiver and quatum comp:
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 12-09-2006, 02:56 PM   #1149
slotcarrod's Avatar
Thanks.
Hi Jon
I run the same stuff but just switched to the Futaba 2.4 RX. You want the lowest center of gravity!
I put my GTX with the solder tabs facing up and the heatsink facing the left. I remove (unsolder) the RED Battery to motor wire from the board. I then use a Dremel (sp?) cut off wheel and cut a slot in the circuit board so I can slip one length of wire in the hole, (Battery to Motor) and avoid using a T joint. Just remove about 3mm of the silicone housing around the wire, where it needs to be soldered to the circuit board. Make sure you tin the wire a little first. Reverse your BLACK wire on the board and reverse the Cap wires and lay the Cap flat on the chassis. This makes for the neatest GTX wiring on any TC. I wish I was able to get you some pics.
Your RX is very close to the GTX set button if you lay it flat. If you put it on it's side you have a hard time setting the channels on your RX. I move my servo forward by drilling and countersinking an extra hole the same distance as the third servo hole in the chassis. (I have found this helps the 007's balance as well!) You will now have more than enough room to lay the RX flat.
I mount my RX on Velcro to reduce any static or vibration. A plus is you can switch your RX to another car very quickly.
While you are at it. Shorten your servo and ESC leads to the minimum length.
I know this is a bunch of work, but it sure looks sweet!
Rod
It's been said that politics is the second oldest profession, it bares a great similarity to the first.
Rod Littau
slotcarrod is offline   Reply With Quote
Old 12-09-2006, 03:17 PM   #1150
Thank you all for the quick replies. Much appreciated.
Joel, I wonder if the LRP speedo is a bit more narrow than the Novak. My layout seems to be a bit of a tighter squeeze.
Old 12-09-2006, 03:38 PM   #1151
it must be cuz between the ESC and motor i got 5mm of space and between the servo and RX there is about 6mm of space left
www.rcottawa.com
Old 12-09-2006, 03:43 PM   #1152
lbckevin's Avatar
Trader Rating: 91 (99%+)
there is nothing wrong with a tight squeeze....if it fits its all good.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 12-09-2006, 04:00 PM   #1153
Does it make glitching more likely?
Old 12-09-2006, 04:47 PM   #1154
Originally Posted by slotcarrod
Hi Jon
I have a very simular set-up with the GTX - except, I don't think it's necessary to Dremel the board ... rather, I just solder the motor wire on the opposite side of the board where the battery wire solders on, essentially creating the same thing you are doing without any cutting.
Old 12-09-2006, 08:24 PM   #1155
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
I try to keep it as clean as possible, so I shortened all my wires.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
