Old 11-22-2006, 10:43 AM   #976
GK
Suspended
Originally Posted by ralph m
Hi Guys,
Can anyone let me know what they're using for track width spacers front and rear, running Parma tires? I've seen many setups posted on the XRay site, most/all are using Jaco tires and stated 3mm. This appears to be too wide for Parma's.
Thanks,
Ralph
Ralph, I'm using 3mm shims front and rear with parmas right now, but will try 1.5 mm as well. Narrow car width will probably work better for you at ssh with the current infield layout (unless you're traction rolling )
GK is offline   Reply With Quote
Old 11-22-2006, 10:49 AM   #977
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
I'm running 3mm on my car with Parma's. I'm still not over max width. Mainly I keep the spacing wider because it actually changes the pivot points of the suspension arms. When they are put further apart from the centerline of the chassis the car creates a little less overall traction, and it helps tone th ecar down and not make it so edgy in really high traction conditions. It also keeps the car flatter in the corner. If you are still wanting to maintain a similar with I would actually get the narrower hex adapters to make parma's have a similar width to jaco's and just shim from the suspension arm.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-22-2006, 11:45 AM   #978
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by syndr0me
Hehe, "RDX HUNTING." You'd have better luck catching a snipe!
I'LL HAVE BOTH BY DAYS END.....
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-22-2006, 11:45 AM   #979
STLNLST's Avatar
Originally Posted by Jack Smash
If you cant drive Paul's setup, learn it. Tons of steering = fast.
WE'LL SEE WHAT HAPPENS.
Old 11-22-2006, 11:54 AM   #980
HarshGuy's Avatar
Originally Posted by STLNLST
TO TO GO RDX HUNTING.
Bring it Homeboy ...bring it on.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 11-22-2006, 12:04 PM   #981
Roger's Avatar
I JUST HOPE THAT I CAN DRIVE PAUL'S SET UP.
Clint: You've been driving long enough to develope your own set-up. Use Paul's set-up as a foundation and change it according to your style of driving. And no, im not joking.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-22-2006, 12:19 PM   #982
Yeah, don't sweat Clint. The car is super easy to dial in.
Old 11-22-2006, 12:36 PM   #983
gonzo416's Avatar
Trader Rating: 39 (98%+)
Originally Posted by svines1972
2 Questions before I start the build.
1. I understand the edge of the chassis needs to be sealed w/ CA. How do you do this without runoff onto the top or bottom of the chassis? Very carefully is not the answer I am looking for. Is there a method to it?
2. Just received the kit and noticed the bulkheads are already attached, but there are 3 screws missing on the rear bulkheads and 2 on the front. Is this something I will insert later on or were they left out by mistake.
to all prepping a chassis: at Walmart they sell Super Glue Loctite with an Easy Brush applicator it is like a plastic bottle of nail polish. the bottle is about 3" tall and clear plastic and the cover is black and has wing tips for easy opening. it has a brush applicator just like womens nail polish, this way there is no mess. just dip the brush and slide it against the inside of the bottle to get the excess off then slide it along the side of the chassis. it can even be used to seal the screw holes as directed in the manual. once you use this you'll never use anything else.
gonzo416 is offline   Reply With Quote
Old 11-22-2006, 12:41 PM   #984
STLNLST's Avatar
For the first time out I'm going with something proven already. I have my own set up that I'll be working on in the future. For today it's Paul's
Old 11-22-2006, 12:42 PM   #985
STLNLST's Avatar
Here I come lil man.....LOL
Old 11-22-2006, 06:28 PM   #986
superslow's Avatar
hey its was the second week running my 007 and the i got it dialed i used the set up on xrays web site, i run on ozite and ran browns in the rear, and double pinks in the front 26mm wide. and changed the rear roll center. team losi 70wt in the front all four holes open in the pistons, and xray 30wt in the rear all holes open the car was on rails i never thought something could rotate quicker than my fully pimped out RDX i had. i rolled the dice and gambled when i switched but i think it paid off. the diffs are still super smooth and the car is holding up very well after two sundays of racing. last sunday took TQ and won the A main by 6 seconds,,, thank you xray.
is the FOR SALE FORUM working i cant get onto it for two day can someone check for me thank you.
superslow is offline   Reply With Quote
Old 11-22-2006, 06:34 PM   #987
[QUOTE
is the FOR SALE FORUM working i cant get onto it for two day can someone check for me thank you.[/QUOTE]
Yes it works, I just checked for you.
OldNSlow2 is offline   Reply With Quote
Old 11-23-2006, 01:38 PM   #988
Customworksking's Avatar
Trader Rating: 73 (100%+)
Arrow 007
looking for a t-2 007 EU rubber car any info will do
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 11-23-2006, 01:43 PM   #989
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
kevin people have already gotten them who ordered them up here
wallstreet is offline   Reply With Quote
Old 11-23-2006, 02:55 PM   #990
PitCrew's Avatar
Try Stormer Hobbies.
PitCrew is offline   Reply With Quote
