Old 11-21-2006, 03:47 PM   #961
Trader Rating: 13 (100%+)
Originally Posted by svines1972
2 Questions before I start the build.
1. I understand the edge of the chassis needs to be sealed w/ CA. How do you do this without runoff onto the top or bottom of the chassis? Very carefully is not the answer I am looking for. Is there a method to it?
2. Just received the kit and noticed the bulkheads are already attached, but there are 3 screws missing on the rear bulkheads and 2 on the front. Is this something I will insert later on or were they left out by mistake.
1. Not only does the chassis need to be sealed- it also has to be sanded. The battery slots need to be filed and sanded as well. After the sanding is complete, I like to clean the chassis with alcohol to make sure all the sanding dust is removed. Make sure you wear a mask for this. One of the best links that explains this is HERE
Rather then letting the glue run on the chassis, many have had good luck with using a Q-Tip dabbed in glue to apply it to the chassis edges. Try to use genuine QTips with the cardboard sticks - the plastic ones react with the CA and release a toxic gas.
2. Take the bulkheads off - they are just there for show at this point. The remaining screws to mount them properly are in the parts-bags.
duckman996 is offline   Reply With Quote
Old 11-21-2006, 03:56 PM   #962
Trader Rating: 26 (100%+)
Thanks for the quick response. I am sure I will be back for more info once I start.
svines1972 is offline   Reply With Quote
Old 11-21-2006, 05:20 PM   #963
Gravity RC
Jag88, I wont say that it is good to have the chassis drag, but we are going so fast into the courners now that its hard to get them not to drag when the bite is up. I think that a little drag can be ok but a ton for me is not ideal atall.
Paul L is offline   Reply With Quote
Old 11-21-2006, 05:50 PM   #964
Anthony.L's Avatar
Trader Rating: 36 (100%+)
In the past I've used the qtip method with good success. I first soak the qtip in CA glue then dab it on a paper towel so it's not dripping wet. Then use the qtip like a brush and with light strokes coat the edges of the chassis.
To be honest, with my last two carpet chassis's I've been lazy and done zero CA. I will use a fill or dremel to bevel the edge a bit just to knock the sharp edge off. With carpet the only real concern is cutting the rug with a sharp edge on the chassis. On asphalt it's more important to glue the chassis so it doesn't splinter on a bad wreck.
Anthony.L is offline   Reply With Quote
Old 11-22-2006, 01:54 AM   #965
RCknight's Avatar
Default Can anyone tell me if a Team Orion lipo 3300 will fit...
in the EU 007 or not? If not, I'll be selling all most of my stuff until the smoke clears with the battery/tc configs. I'm waiting for a lipo/tc design standard.
RCknight is offline   Reply With Quote
Old 11-22-2006, 02:24 AM   #966
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
With the EU kit yes.
THe US kit the thinker chassis and lowered bulkheads made it very hard to fit.
I have two 3200 packs that fit real nice in the Eu. Still trying to get the right conter weights. Seems everyone around here shuts down for thanksging on Monday...Slackers I tell ya...
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 11-22-2006, 08:20 AM   #967
Any update on the conversion kits?
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 11-22-2006, 08:37 AM   #968
ralph m's Avatar
Trader Rating: 31 (100%+)
Hi Guys,
Can anyone let me know what they're using for track width spacers front and rear, running Parma tires? I've seen many setups posted on the XRay site, most/all are using Jaco tires and stated 3mm. This appears to be too wide for Parma's.
Thanks,
Ralph
ralph m is offline   Reply With Quote
Old 11-22-2006, 09:10 AM   #969
pcar951's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ralph m
Hi Guys,
Thanks,
Ralph
I don't use any spacers when I run Parma's as they're already offset. Makes the car feel mushy to me.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy
pcar951 is offline   Reply With Quote
Old 11-22-2006, 09:17 AM   #970
pcar951's Avatar
Anybody got a fix (other than aluminum) for losening screws in the steering knuckles.
I'm on my 3rd set in 3 race days. Never replaced a set on the T2 at all. Camber link screws are stripping the threads in the plastic.
Jim Chapman
Old 11-22-2006, 09:45 AM   #971
Default ORION 3200 LIPOs in t2'007???
-Shookie <><
Hey Shookie,
So you confirm that 3200 team orion carbon edition LIPOs fit in the new 007?
Thanks,
Cham
CRiXman is offline   Reply With Quote
Old 11-22-2006, 09:57 AM   #972
Suspended
Trader Rating: 28 (100%+)
In the EU kit he restated twice in his last post that they fit well.
racenut123 is offline   Reply With Quote
Old 11-22-2006, 10:10 AM   #973
STLNLST's Avatar
Trader Rating: 21 (100%+)
I GET TO RUN THE NEW RIDE TODAY. I JUST HOPE THAT I CAN DRIVE PAUL'S SET UP. TIME TO TO GO RDX HUNTING.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-22-2006, 10:13 AM   #974
Jack Smash's Avatar
Trader Rating: 29 (100%+)
If you cant drive Paul's setup, learn it. Tons of steering = fast.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-22-2006, 10:32 AM   #975
syndr0me's Avatar
Trader Rating: 32 (100%+)
Hehe, "RDX HUNTING." You'd have better luck catching a snipe!
syndr0me is offline   Reply With Quote
