Old 11-20-2006, 05:33 AM   #946
"Spanky's Avatar
I am running the co27 tweaked motor in the 007 with the standard 116 spurgear. I am just curious what are you guys using for pinion size?
Brendan a.k.a. "Spanky"
TEAM LOSI 22SCT ..... 22T 2.0 ..... 22 2.0
Orion----Promatch Racing----Spektrum---Proline---Island Raceway
"Gone But Not Forgotten" --- RC10T, RC10T3, RCTc4, XRay007, XXT, XXTcrGraphitePlus, XXXT, XXXTMF, XXXTMF2----
"Spanky is offline   Reply With Quote
Old 11-20-2006, 07:07 AM   #947
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by stiltskin
I should have built a car during the Buckeyes game today. Maybe that would have calmed my nerves.
How is Michigan still ranked #2 after a loss. I hope ND beats USC next week so maybe ND might have a shot. My cousin plays for ND #11 on offense. The car will be completed today once I get off of work. Gotta be ready for Wednesday
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-20-2006, 07:23 AM   #948
Send a message via Yahoo to Babylou
You've got that right.. If it was ND they would of dropped to 8 or 9 in the BCS.. But granted it was a good game they should of dropped to at least 3 or 4th and be 1 in front of ND...
Anywho.. My Xray hits the track tonight... Finally all built and tuned and read to see what she can tear up....
Babylou is offline   Reply With Quote
Old 11-20-2006, 11:02 AM   #949
Just built my 07 EU edition over the weekend and I have a question concerning the multiflex.
I like it really soft, and I looked at the pictures in the setup guide, and for the soft setting, it looks like there are only 2 screws holding the rear bulkheads ( 1 in each) , none in the layshaft/spur bulkhead, and 2 in the front bulkheads(again, one in each. Is that really correct? it seems quite odd to me that there isnt much to keep the bulkheads in alignment.
thanks,
Lon
Lon
Mugen MBX6E Tekno V4 Tekin RX8 Tekin 1700
Losi SCTE 4x4 , Tekin RX8, Tekin SCX4-5.5
Associated SC10 4X4, Tekin RX8, Tekin SCX4 -5.5
Kyosho Ultima SC-R, Tekin RS Pro, Tekin 10.5
Lon_L is offline   Reply With Quote
Old 11-20-2006, 11:15 AM   #950
I think that is because those are not supposed to be removed at all. If you look closely they do not have the same kind of highlight the others have(the big circle). I think it is understood that these are not removed.
Not 100% sure tho.
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 11-20-2006, 12:10 PM   #951
pcar951's Avatar
Trader Rating: 19 (100%+)
27 with 58mm tire diameter (foam) - calculate roll out for larger tires
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 11-20-2006, 02:16 PM   #952
Trader Rating: 13 (100%+)
thanks,
Lon
Like Joe said - I think you have it backwards... you took out the screws you are supposed to keep in and kept in the ones you were supposed to remove.
duckman996 is offline   Reply With Quote
Old 11-20-2006, 02:38 PM   #953
hmmm. when i look at the setup book that came with the car kit. It says hilighted circle is screw not used, and filled in circle is screw used. the pic for the softest setting shows 13 highlighted circles, with four of those circles being the four screws that hold the layshaft bulkhead in, or atleast to my old eyes it appears that way. So I am really confused.
New info: ok I just tore out everything that comes with my 007 EU and I have come to the conclusion that the picture in the setup book must be wrong. The included advertisement has a pic for the multi-flex settings and it shows a more reasonable 8 screws not used, which leaves 2 screws in each bulkhead.
Maybe someone can confirm or deny that the pic in the included setup book is wrong.
Lon
Old 11-20-2006, 10:38 PM   #954
taj
taj's Avatar
hi
trying to find a shop that sells (in stock) fk05 chassis's over the net
thanks for any help
IMCC-Illawarra model car club inc.
The Formula for fun is 9 Corners
quality not quantity
taj is offline   Reply With Quote
Old 11-21-2006, 04:28 AM   #955
Joel Lagace's Avatar
http://www.hobby2000gatineau.com/
Call them i know they have a T1R,FK05 on the shelf.... There online store is not always up to date. This is in CND $$ so take that into consideration. I know there old stock xray cars have been reduced in price.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 11-21-2006, 10:50 AM   #956
Send a message via MSN to makytc4
ive been looking at chassis stiffness as well. it looks to me as it is wrong as well. the way they say in the book means theres gonna be like 2 screws holding the rear end together . that cant be healthy can it. but as u say the leaflet that comes with it makes more sense
makytc4 is offline   Reply With Quote
Old 11-21-2006, 12:08 PM   #957
Indy800's Avatar
Just ran my car over the weakend,carpet version,used Paul L setup,car is dialed in 19t.First time out ran best ever with this car..loving it..
Indy800 is offline   Reply With Quote
Old 11-21-2006, 02:00 PM   #958
jag88's Avatar
Paul, the fast guys at our track (Flack, Johnson) don't seem to be concerned about chassis drag in the corners. I think that even a little scrubs off some speed. What are your thoughts ?
Thanks.
jag88 is offline   Reply With Quote
Old 11-21-2006, 03:29 PM   #959
Trader Rating: 26 (100%+)
2 Questions before I start the build.
1. I understand the edge of the chassis needs to be sealed w/ CA. How do you do this without runoff onto the top or bottom of the chassis? Very carefully is not the answer I am looking for. Is there a method to it?
2. Just received the kit and noticed the bulkheads are already attached, but there are 3 screws missing on the rear bulkheads and 2 on the front. Is this something I will insert later on or were they left out by mistake.
svines1972 is offline   Reply With Quote
Old 11-21-2006, 03:44 PM   #960
adamge's Avatar
svines, you are being very cautious with your new ride.
Applying CA to the edge is all about the applicator. A bottle of thin CA is difficult to use well. Ideally you should buy some clear plastic CA-droppers from your LHS. Something like this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXB970&P=7
They give you great control of how much glue comes out. Once you have them, you can touch the tip to the edge of the chassis, while holding the chassis such that the edge is vertical or near vertical (so gravity pulls the drop down the edge, and not onto the top or bottom surface), and squeeze out as small a drop as possible. Then use the applicator (near the tip) to spread that drop around into a thin film, evenly. Work your way all the way around the chassis.
I think I read about someone use cottom swabs for that. That might work.
The missing bulkhead screws are in one of the bags. At the step where you re-install the bulkheads, you will have the additional screws in front of you.
-Adam
-Nietzsche
