Old 11-04-2009, 05:07 AM   #3946
lowcel's Avatar
R/C Tech Elite Subscriber
Trader Rating: 80 (100%+)
Anybody have any setup sheets for the t2'007 for VTA on low traction carpet by any chance?
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 11-04-2009, 06:13 AM   #3947
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
found this one dont know how it will work
http://forum.teamxray.com/xform/inde...6&setup=t2_007
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-08-2009, 03:52 PM   #3948
20 SMOKE's Avatar
has any one changed to the 32t pullys
Jamie W
Old 11-08-2009, 04:27 PM   #3949
Con
Yes I tried it....the belts are too long
Con is offline   Reply With Quote
Old 11-08-2009, 04:40 PM   #3950
Trader Rating: 29 (100%+)
what servo would you guys recomend for a 007?
Thanks, Jason
madhammer is offline   Reply With Quote
Old 11-08-2009, 04:44 PM   #3951
20 SMOKE's Avatar
i have the 9550
Jamie W
Old 11-08-2009, 05:25 PM   #3952
revracr909's Avatar
Trader Rating: 21 (92%+)
Default NEW TO ONROAD!
How much different is the 07 from the oringal T2? Also does anyone know this this orion servo will work?
http://www.amainhobbies.com/product_...-Digital-Servo
Team Associated B44_T4
LRP_REEDY_JCONCEPTS_TEAM EPIC
www.jimmybabcock.com_www.wcrcr.com
revracr909 is offline   Reply With Quote
Old 11-08-2009, 05:49 PM   #3953
20 SMOKE's Avatar
it has a hole lot of torque,the 9551 is low profile it will help with installation http://www.amainhobbies.com/product_...-Profile-Servo
the bulk heads are lower the the t2 a few other things are different but all the suspension are the same. you can read what is different http://www.teamxray.com/teamxray/pro...1&catName=XRAY T2 007 US Foam-Spec Edition
Jamie W
Old 02-12-2010, 03:49 PM   #3954
Default Belts flipping
Hi there. I'm (stilll) having all sorts of issues with belts flipping, on BOTH my 2007's
I tried replacing all belts & pullies, helped for a short time , but the problem is back again.
Are the Xray 2007 belts just not very long lasting??
I'm thinking about trying another brand of belt.
1101 is offline   Reply With Quote
Old 02-12-2010, 03:55 PM   #3955
Regional Moderator
CarbonJoe's Avatar
Maybe your belts are too loose? I've never had a belt flip on my '007, '008, or '009. I've only replaced the belts once on each car. I also ground down the pinion set screw with a Dremel so that it doesn't protrude past the "hub" of the pinion. This prevents the belt from catching on the setscrew and wearing prematurely. Do both belts flip or only the front belt?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 02-12-2010, 04:36 PM   #3956
Perhaps it small stones catching in the drivetrain causing belt to flip under load??
Flipped both front and rear..Once they start flipping things just get messy, not good for the pulley's having a flipped belt spinning over it....
After replacing all belts and pulley's, was fine for about 2 months, now having issues again.
After it flips the first time(on new belt) then it just keeps happening: obviously stuffed
I had a few belt drive cars & never had this problem before (even on a T1 & 008)
The 008's belts are quite loose, but no no issues with that car.
Old 05-11-2010, 05:42 PM   #3957
JKL1031's Avatar
Im looking at buying an original t2. What parts are interchangeable from the t2 007+?
edit: found something Its a spreadsheet and a bit un clear. Im pretty safe on being able to find control arms c hubs and steering knuckles for the 006? they fit from the 007? anyone want to give me a simple list of everything that can cross fit?
JKL1031 is offline   Reply With Quote
Old 05-11-2010, 06:57 PM   #3958
20 SMOKE's Avatar
arms,c hubs,hub carriers all fit from the t2-t3
http://www.teamxray.com/teamxray/sho...p?file_id=6147
Jamie W
Old 05-11-2010, 07:13 PM   #3959
JKL1031's Avatar
thats what i was reading from
Old 05-11-2010, 07:24 PM   #3960
20 SMOKE's Avatar
you can convert a 06 to a 07 with new upper deck and bulkheads,if you buy the 06 dont worry about finding parts as there are plenty
Jamie W
