Old 12-08-2008, 11:08 PM   #3871
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Trader Rating: 12 (100%+)
Send a message via MSN to BigDogRacing
mtboy- 2 things- make double sure the hinge pin is straight even if it looks straight to the naked eye, clean it and roll it slowly on clean glass surface. Then double check the hinge pin mount screws. Even a small amount of bend in them can cause bind. If not sure, move the screws and pin to the other side arm and see if problem follows them or stays with the arm.
If neither of those fix it, then if could be the arm or bulkhead tweaked.
Last thing- when I tighten my hingepin screws, I tighten them pretty snug, then back off just a bump- maybe 15deg- to take the bind out of the mount. Some tighten them then give the arm a nice firm tap in both directions.
Hope than helps....
BigDogRacing is offline   Reply With Quote
Old 12-10-2008, 07:21 PM   #3872
mtbboy's Avatar
Hope than helps....
Did help....Thank you.
D.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-10-2008, 09:12 PM   #3873
Davidka's Avatar
Trader Rating: 77 (100%+)
can anyone tell me if kimbrough spur gears will fit on Xray's spur gear mount?
Davidka is offline   Reply With Quote
Old 12-11-2008, 12:55 AM   #3874
Professor's Avatar
Default spur gears
yes they will,they are the only kind that i now use on my 007 (they seem to last longer than others ive tried), i use 48 pitch not 64 but i dont see why 64 wouldnt fit
hope this helps
graham
Professor is offline   Reply With Quote
Old 12-11-2008, 01:08 AM   #3875
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
they have the right bolt pattern, pain in the @$$ to use them on 008 car, If I remember right they should bolt on to 007 no problem(holding the center shaft in my hand)
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-11-2008, 01:57 AM   #3876
Impulse_racer's Avatar
I had to sand them a little thinner on my '007 because they rubbed.
Xray T3 EU
KO Propo Helios
Tekin RS Pro/LRP X-12/Venom LiPo
Hudy
Litemodz CVS
Impulse_racer is offline   Reply With Quote
Old 12-11-2008, 07:46 AM   #3877
Davidka's Avatar
Excellent. That's what I was looking for guys, thanks.
Old 12-15-2008, 08:08 PM   #3878
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Got the arm thing figured out- They were the wrong mounts he had on.
NOW-- Im looking over setup sheets and it seems a lot of guys are running 30/30 oil. That seems awful thin, im wondering if it is Xray brand, and if so- is it thicker than say-- Losi oil?? OR- does the car really just work well with thinner oil?
sorry to come off as a newb- but i have never run this car before..
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 12-15-2008, 08:17 PM   #3879
mtbboy's Avatar
Adjustable pistons affords you the ability to run a thinner oil as you can change damping through # of holes.
Old 12-15-2008, 09:32 PM   #3880
Okay- cool.. so the pistons are actually used.. i remember back in the day there was something similar from race prep or somthing-- for the XX Buggy.. didnt catch on. LOL.
Anyway- so 30 wt it is.. Thanks guys..
Keith
OUT
Old 12-15-2008, 09:35 PM   #3881
Akhor's Avatar
hope this helps
graham
Do you have to drill holes for the access to the motor mounting screws?
Akhor is offline   Reply With Quote
Old 12-16-2008, 04:08 AM   #3882
Professor's Avatar
Default holes
akhor
depends i guess on what motor u are using,currently i am running 17.5 bl with
74 spur & between 27--31 pinion & i have increased two existing diagonal holes just a litlle just so its simple & quick to change pinions without any hassles,but when i was running silver cans with 77--81 spur gears i had to make the two holes somewhat larger, as for anything lower turn than 17.5 i am unsure
hope this helps
graham
Old 12-16-2008, 06:37 AM   #3883
Akhor's Avatar
akhor
hope this helps
graham
This does help. Thanks.
Drilling the spurs, does not cause some crazy rotational wobble does it? Or at least one that's noticable.
Old 12-16-2008, 08:23 AM   #3884
Keith - The 30wt you see in setups is X-Ray brand...I can't remember exactly how it compares to Losi/Assoc, but it's around 50-60wt for those.
Denney
Denney is offline   Reply With Quote
Old 12-16-2008, 03:17 PM   #3885
Thats what i was getting at... I guess ill have to write some emails. unless someone knows off hand what 30 Xray is close to?
I put 30wt Losi in, mainly because i have every losi oil there is LOL..
Car is coming together nicely.. The rest of the supplies i am waiting for will be here this week--
KB
OUT
