Old 12-06-2008, 07:54 AM   #3856
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Good call on the screw-- that will be my first place ill look. Im betting its that, actually.
The arm/reamer.. dont think thats necessary, at least with the arms I have, they have a very nice tolerance...
Thanks guys-
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 12-06-2008, 08:11 AM   #3857
mtbboy's Avatar
Hey all.
Ive not heard any mention of belt tension on this car.
Is there an ideal?
As loose as possible without rubbing or skipping or is there an advantage to going tighter?
Dave.
Team Associated Reedy factory team driver.
B5M Factory lite $ B44.3 Factory $ TC6.2 $ RC12R 5.1
Reedy 410 Speedos $ Reedy Mach Series motors
204 Raceway Winnipeg 1/10-1/8 Offroad. Owner.
mtbboy is offline   Reply With Quote
Old 12-06-2008, 08:36 AM   #3858
Originally Posted by Keith Billanti View Post
Anyone got one of Bob-O Flack-O's set up for this car?
Schrevens???
Keith
Keith,
I am pretty sure this is the one he used as a starting point most of the time,this or his Las Vegas set-up. His computer quit so I'll call and make sure.
http://forum.teamxray.com/xsheets.ph...DESC&start2=60
Ted Flack is offline   Reply With Quote
Old 12-06-2008, 09:01 AM   #3859
Thanks Ted, Hows life going? Been a while.
I just discovered that forum and all the setup sheets.. for some reason i didnt see that until 5 min ago.. thank you though!
I think i may have found the issue with the front arms. I DL'd the manual and was looking it over. It seems that there are marks on all of the suspension blocks according to the manual== little dimples... Or at least it seems. I just glanced at it..
Looking at the car, he has blocks without dimples on the back of the front arms.. blocks with dimples everywhere else. Can someone confirm that this is appropriate? I am going to look over the manual in depth after breakfast.
Need to get some bearings as well...
Keith
OUT
Old 12-06-2008, 09:16 AM   #3860
Regional Moderator
CarbonJoe's Avatar
There are 3 sets of hinge pin holders with dots on them for each arm. They are -0.75 mm, 0 mm, and +0.75 mm offset. Dots low = -0.75 mm, dots in the center = 0 mm, dots at the top = +0.75 mm offset. Thus, no offset, and +/- 0.75 mm offset. This allows you to raise or lower the hinge pins from the stock 0 mm (no offset) setting.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-06-2008, 09:46 AM   #3861
So what are these blocks W/O dimples then? The cause for arm bind, i hope..LMAO.
Cool. Ill go see what i can scare up at the LHS today.. looking in the manual, should be a whole tree.. no?
Keith
OUT
Old 12-06-2008, 09:57 AM   #3862
Regional Moderator
CarbonJoe's Avatar
Keith
Not sure about no dimple pin holders. Yes, there is one whole tree per arm, one set of each offset.
Old 12-06-2008, 10:07 AM   #3863
Probably came off the 04... seems to look familliar..
OUT
Old 12-06-2008, 10:16 AM   #3864
Regional Moderator
CarbonJoe's Avatar
If your LHS doesn't have them, it looks like Ashford Hobby does.
http://ashfordhobby.com/detail.aspx?ID=2183
Old 12-06-2008, 10:22 AM   #3865
Cool-
I gotta try the local first though. Phone is busy- lol.
KB
OUT
Old 12-08-2008, 03:38 PM   #3866
mtbboy's Avatar
Originally Posted by mtbboy View Post
Hey all.
Is there an ideal?
Dave.
Old 12-08-2008, 03:40 PM   #3867
Trader Rating: 70 (100%+)
I run mine center tension setting on cam,i have ran this way for a few months and have had no problems,i run 13.5 sure with more motor they might strecth more.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-08-2008, 03:46 PM   #3868
mtbboy's Avatar
Thanks for that.
Is there a trick to keep the arms from binding on the chassis in the low roll center position.?
Dave.
Old 12-08-2008, 04:02 PM   #3869
Are you running the 2.5 mm chassis?i am running low roll center on the frt with 1.5 mm of droop with no problem.
SpeedZone Batteries
Old 12-08-2008, 05:34 PM   #3870
mtbboy's Avatar
Thanks again Steve.
I,ll have to try it again as it was some time ago that I tried it to no avail.
Seemed like it was binding on the rear where the inner hinge pin housing meets the chassis.
Just want a little more roll for rubber.
Dave.
Oh .
I,m converting a foam version so no its the 3 mm chassis.
