Old 12-03-2008, 09:01 PM   #3841
Warhawk 1's Avatar
Need some assistance. Vintage trans am with the T2'007. GTB esc, 17.5 brushless, 4 cell nimh. 65 x 35 track has a few tight 180 turns. What pinion and spur combination should I look at running? Any help would be appreciated. Thanks.
Warhawk 1 is offline   Reply With Quote
Old 12-03-2008, 10:54 PM   #3842
XxAmpEnergy88xX's Avatar
Send a message via AIM to XxAmpEnergy88xX
i dont know what to run for gears but you could ask this question in one of the VTA threads and see if anyone has a gear setup for you.
*Mike King* *R/C Madness*Team Losi 8 2.0*X-Ray-M18T*X-Ray-M18*
XxAmpEnergy88xX is offline   Reply With Quote
Old 12-04-2008, 06:49 PM   #3843
revo523's Avatar
Hey guys i been running at a parking lot track and in January there going to open a in door track my question is they going to be running either 13.5 or 10.5 but i dont know what brand of motor to go with at the moment im running a x11 3.5.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
revo523 is offline   Reply With Quote
Old 12-04-2008, 08:09 PM   #3844
i think the trinity duo motors are the best for 13.5
Old 12-04-2008, 08:20 PM   #3845
revo523's Avatar
Ok and what brand if we run the 10.5? duo 10.5?
Spektrum DX3S
Old 12-04-2008, 08:31 PM   #3846
yea
Old 12-05-2008, 11:17 AM   #3847
Casey Belarde's Avatar
where can I find a good setup for 13.5 rubber for my car?
thanks for the help!
Casey Belarde is offline   Reply With Quote
Old 12-05-2008, 11:29 AM   #3848
Trader Rating: 70 (100%+)
Go to www.rcamerica.com under the forum look under t2 several set up sheets there to pick from.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-05-2008, 07:53 PM   #3849
revo523's Avatar
Hey guys i was running my 007 today and i notice that every time i was going a lil fast and let of the throttle it will veer to the left or right i dont remember at this moment any ideas what could it be? i checked everything and it looks good. Do i need some toe?
Spektrum DX3S
Old 12-05-2008, 08:28 PM   #3850
harabigfan's Avatar
this is interesting. You mean when you off throttle, only then it will veer to left or right?
Usually when ON throttle this happen... now Im also confused. I usually check my driveshaft on each end... maybe something gone wrong at this area.. im not sure
harabigfan is offline   Reply With Quote
Old 12-05-2008, 09:08 PM   #3851
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Anyone got one of Bob-O Flack-O's set up for this car?
Schrevens???
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 12-05-2008, 09:13 PM   #3852
revo523's Avatar
well it veers to one side i just dont remember if it was to the left or right.
Spektrum DX3S
Old 12-06-2008, 07:05 AM   #3853
Also, as i go through this car-- (bought it from a friend).. the front arms bind horribly. Before i start relieving parts of their excess plastic- is this a known problem? is there an known fix??
Pins are true, arms -- tried brand new with the same result.. nothing is bent..
Keith
OUT
Old 12-06-2008, 07:49 AM   #3854
Keith
Most generally if th arms bind it's because one or more of the roll center screws are bent,back them out a few turns should be able to notice fairly easily,xray also makes a reamer for the arms nothing seems out of place
SpeedZone Batteries
Old 12-06-2008, 07:50 AM   #3855
jag88's Avatar
Keith
The first thing I do is ream the hinge pin hole with the Hudy reamer, it works great and I believe is necessary. The other thing is how you tighten the hinge pin blocks. If not done properly then this will bind the arm. If you are tightening the screw so that the block wants to rotate into the arm then hold the arm with your left hand so as to stop the rotation. If you are tightening the screw so that the block wants to rotate away from the arm hold the block so that it doesn't rotate. A couple of tries and you'll get it just right.
jag88 is offline   Reply With Quote
