Old 11-24-2008, 06:25 AM   #3826
Trader Rating: 70 (100%+)
[QUOTE=Foodie;5085858]Can someone tell me if the T2008 SOLID AXLE 38T SET is going to fit in my T2007? I never use any other option than solid, and the multidiff is very heavy, so no reason for me to use that as solid... [/The
007 uses 34t pulleys
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 11-24-2008, 10:57 AM   #3827
ok, so i guess, if i get it with 34 teeth, then it should be fine?
Foodie is offline   Reply With Quote
Old 11-24-2008, 12:13 PM   #3828
revo523's Avatar
is this a good upgrade to have?
http://www.nexusracing.com/images/305590_03.jpg
revo523 is offline   Reply With Quote
Old 11-25-2008, 03:25 AM   #3829
The original plastic parts are working just fine, I would save that money and buy optional springs, anti-roll bars or spare parts... but this is just a personal opinion
Ralf is offline   Reply With Quote
Old 11-25-2008, 12:02 PM   #3830
Regional Moderator
CarbonJoe's Avatar
Is anyone using the '007 US (foam) edition in Vintage T/A? What kind of setup have you been using?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-28-2008, 08:32 PM   #3831
revo523's Avatar
Is this thread going dead? i hope not!!!
Old 11-28-2008, 09:52 PM   #3832
revo523's Avatar
Hey guys today i decided to change the oil in my shocks but for some reason i cant get the rebound right, on the setup book says that i need a rebound of 50 or 75% but no matter what i do they always just shoot out all the way. any advice? thanks.
Old 11-28-2008, 10:25 PM   #3833
Loosen the shock bottom push the shaft in at the same time tighten the shock bottom this will bleed the excess oil,depends how full they were after rebuild you may have to repeat,i usually run 50% rebound,hope this helps.
SpeedZone Batteries
Old 11-28-2008, 10:43 PM   #3834
revo523's Avatar
Thanks!
Old 11-29-2008, 01:11 PM   #3835
revo523's Avatar
Hey steve i did what you said and it worked i really appreciate your help.
Old 11-29-2008, 11:04 PM   #3836
alecladanga's Avatar
Old 11-29-2008, 11:13 PM   #3837
revo523 glad i could help,as far as the 5000 lipo you would have to shim the upper deck,you also have to remove the front screw hole on the right rear bulkhead with a dremel,i am currently running a 4000 lipo and tray which you do not have to shim fits fine.
SpeedZone Batteries
Old 12-03-2008, 06:56 PM   #3838
revo523's Avatar
Hey guys quick question if my motor is running hot i need to go lower on my pinion right? Im running a lrp 3.5 with a 116 spur and 20 pinion.
Xray T2 009 EU Tekin RS PRO Novak 13.5 SMC 5200
Team Magic G4JS O.S.12 skyline 12plus
Spektrum DX3S
What came first the chicken or the egg?
Old 12-03-2008, 07:22 PM   #3839
Really depends on track size?Also what speedo and setting are you running?
SpeedZone Batteries
Old 12-03-2008, 07:35 PM   #3840
revo523's Avatar
i dont know the actual size of the track but its not that big all say 50x100. i have the lrp sphere comp with the 3.5 and all my settings are at the lowest. I was running the car in front of the hobby shop today and i touched the motor and it felt really hot then i got my temp gun and after the car was sitting for like 5min it was at 160.
Spektrum DX3S
