Old 11-15-2008, 10:14 AM   #3811
revo523's Avatar
i dont know what im doing so its confusing. can you do it for me?
revo523 is offline   Reply With Quote
Old 11-15-2008, 12:30 PM   #3812
CREWMAN's Avatar
Trader Rating: 19 (100%+)
revo523
I think you are geting yourself really confused with the gearing. Yes it is really confuseing. Hears what i did. I was having a hard time getting the FDR and rollout stuff. all i wanted to do was get started and get around the track. (that is the key when you are starting) It is hard to tell you how to gear it without knowing the track add conditions. So hears what i suggest. Go to your track and talk to the guys there. See what spur gear and pinion they are all running. Try to figure out a range of pinions to get. Lets say for example 30 tooth through 40 tooth. Then when you go to race you tune the gearing to the heat of the motor. If you are to hot go down a size and see whatit does. If you are cold, you can go ahaed and add some teeth. To mee that is the easy way to start with gearing. Once you get good at driving then you worry about the gear charts and stuff
sorry if it seemed like i confused you some more. Thats what i did when i was new.
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 11-15-2008, 01:04 PM   #3813
Regional Moderator
CarbonJoe's Avatar
One suggestion is to start on the low side when starting out (smaller pinion than others are running). This allows the motor to run cooler, have more rip out of the corners, and a touch less top speed. If you overgear it from the start (too big of a pinion), you could fry the motor or ESC since you probably don't know what is safe for the motor/ESC. Heat is the enemy for ESCs and motors.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-15-2008, 01:15 PM   #3814
revo523's Avatar
cool i just wanted to start with the recommended gear ratio that lrp its telling me but i ran the car and the motor and esc are not over heating im running a 34 p and 116 s just trying to learn all this new stuff thanks guys.
Old 11-15-2008, 04:00 PM   #3815
CREWMAN's Avatar
Thats good. When you first getting started as long as the motor is running cool, your fine. get the car handleing good on your track. then when the car is handling good, start messen with the gearing
D&K HOBBIES!!!!
Old 11-15-2008, 05:33 PM   #3816
revo523's Avatar
sounds good thanks
Old 11-16-2008, 10:42 AM   #3817
morris's Avatar
Trader Rating: 40 (100%+)
ok well i looked at some set-ups on the xray page...but it didnt do much justice for me due to the fast that most of them didnt sat whether it was foam or rubber tire.and the couple that did they were running mod.
i will be using 13.5 motor with jaco greens.
could anybody post a set-up for me or pm me with one.
thx,
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 11-16-2008, 05:19 PM   #3818
revo523's Avatar
went to the track today and the car did awesome and my brushless system didnt get hot at all
Old 11-17-2008, 05:37 PM   #3819
revo523's Avatar
i know someone mention that the tires go by the temp where you running at so the colder the softer i go in shore?
Old 11-20-2008, 07:04 PM   #3820
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys
is there a LiPo that you guys are using that fits the 007 nicely without too much of a mod???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 11-20-2008, 09:30 PM   #3821
revo523's Avatar
well im using the maxamps lipos and they fit pretty nice. i still shimed the middle brace for some extra clearance and dremeled the bulkhead.
Old 11-20-2008, 09:38 PM   #3822
XxAmpEnergy88xX's Avatar
Send a message via AIM to XxAmpEnergy88xX
The SMC 4000 LiPo fits perfect take a look http://i241.photobucket.com/albums/f...s/DSCF0112.jpg
*Mike King* *R/C Madness*Team Losi 8 2.0*X-Ray-M18T*X-Ray-M18*
XxAmpEnergy88xX is offline   Reply With Quote
Old 11-21-2008, 09:26 AM   #3823
Regional Moderator
CarbonJoe's Avatar
Regardless what LiPo you get, you'll need to dremel the right rear bulkhead to allow the pack to clear the front screw. I just got rid of the frontmost screw. The Orion 3400, 3600, and 3800 packs fit with no other mods. The SMC 5000 28C packs fit if you shim the top deck 1.5mm. I also dremeled the inner sub-C battery holders to fit the SMC pack to prevent it from sliding into the belt.
See this article on Nexus Racing's site about fitting LiPos in the '007
http://www.nexusracing.com/newsdesk_...newsdesk_id=60
Old 11-21-2008, 06:44 PM   #3824
i didnt have to mod anything the only thing i need to do is take the battery strap off to put battery tape on the battery then put the strap back on
Old 11-24-2008, 02:40 AM   #3825
Can someone tell me if the T2008 SOLID AXLE 38T SET is going to fit in my T2007? I never use any other option than solid, and the multidiff is very heavy, so no reason for me to use that as solid...
Foodie is offline   Reply With Quote
