Old 09-11-2008, 04:05 PM   #3736
<PsOp>
Guest
Posts: n/a
The 33 pinion wont fit in the LRP motor but the novak motor does I guess I have to switch to 64 pitch gearing then. Is there any other brand besides Xray spur gears I can use? Thanks again for the help guys
Noob question if 10.5 is 19t and 17.5 is 27t so WHAT is 13.5?
Old 09-11-2008, 04:53 PM   #3737
Regional Moderator
CarbonJoe's Avatar
RW, PRS, and Robinson spurs fit the 007, although the Robinson (and the non-Pro Touring PRS and RW) spurs don't have the motor screw access holes.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-11-2008, 05:16 PM   #3738
AaronR's Avatar
Trader Rating: 111 (100%+)
EDIT: Upon further review, I think I may have a 90T 64 pitch spur gear, not 48 pitch. :?
AaronR is offline   Reply With Quote
Old 09-11-2008, 05:40 PM   #3739
Trader Rating: 11 (100%+)
If I rember right 28-29 was the biggest pinion I could fit with a 90 48P spur.
PSOP 13.5 = 19T and 17.5=27T. I guess 10.5 is now a mod motor or a new class could spin off from it.
Tim
got2bqik is offline   Reply With Quote
Old 09-11-2008, 10:52 PM   #3740
rcfiend's Avatar
Trader Rating: 30 (100%+)
Hey I just picked up a pre-owned 07, is there still part support for this car? Also what is the biggest differences between the 07 and the 08? Just getting back into the hobby, been gone for a few years.
rcfiend is offline   Reply With Quote
Old 09-12-2008, 07:46 AM   #3741
Regional Moderator
CarbonJoe's Avatar
Yes. Check StormerHobbies.com, nexusracing.com, amainhobbies.com, ashfordhobby.com, ampdraw.com, among others...
Old 09-12-2008, 10:34 AM   #3742
Kimbrough spur gears work as well
Bull_Dog is offline   Reply With Quote
Old 09-12-2008, 12:22 PM   #3743
act2007's Avatar
Trader Rating: 46 (100%+)
Originally Posted by act2007 View Post
I second that, they're great guys to deal with too!
Guys, I just got my new replacement Chassis 2.5mm Graphite - Rubber-Spec.
To sand the sides, can you guys recommend what number sandpaper
grit I should use. I have from 200 to 1200 Grit, It's been a while since
I did my 007 EU! Thanks guys!
Nobody here can recommend what sandpaper grit I need to sand the
side of my chassis?
act2007 is offline   Reply With Quote
Old 09-12-2008, 01:38 PM   #3744
Drew Ellis's Avatar
side of my chassis?
I belive 500 to 600 would be fine not sure I use my dremal with a sanding bit...Later Drew
RCAMERICA-Xray-Hudy-GravityRC-Kopropo-PROLEVELRC-Team EAM-ORCA-P1Brand-AVID-ProlevelRC Raceway-MOTIV-Max Power America-SRC America
Drew Ellis is offline   Reply With Quote
Old 09-12-2008, 06:07 PM   #3745
act2007's Avatar
Thanks Drew, that's what I used tonight, the 500 grit! And put CA glue
on all the sides after sanding!
Old 09-12-2008, 09:09 PM   #3746
<PsOp>
Guest
Posts: n/a
My front diff is making some noise and sometimes it gets stuck/binds in the right side. Can this be open and what tools do you need? anyone knows a link on how to dissasemble t2 diff. Thanks (my diff is the one on the right pic)
Old 09-12-2008, 09:22 PM   #3747
Regional Moderator
CarbonJoe's Avatar
First, peel the two black plastic covers off the sides of the diff. Start at the top, use your fingernails to pry the one edge of the cover off by the teeth, then work your way around until it is off. Do the other side.
Look down the outdrive and find the side with the 2mm cap head screw. Insert the 2mm wrench, stick a hex driver shaft sideways in the other side outdrive, and unscrew the bolt all of the way. The diff will split in half. Clean the diff balls, rings, and pulley. Re-lube the diff balls, re-insert them in the holes in the pulley, re-assemble the diff in the reverse order. Snap the covers back on. Tighten the diff appropriately (so that it doesn't slip). This may require tightening after running on the track if it slips (whining noise while accellerating).
Look at the exploded view in the manual if you get stuck. You shouldn't need to mess with the c clip that holds the inner thrust bearings in.
Old 09-12-2008, 10:06 PM   #3748
<PsOp>
Guest
Posts: n/a
Thanks alot Joe
Old 09-15-2008, 10:49 PM   #3749
<PsOp>
Guest
Posts: n/a
Any sugestions of a good body out there besides stratus or mazda6 for asphalt track.
Old 09-16-2008, 08:11 AM   #3750
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Speed6...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
