Xray T2'007
Old 07-15-2008, 07:19 PM
  #3691
Default Anti roll bar
Just got a 2nd hand unused T2-007, will be running on asphalt with rubber tires. Wonder if the anti roll bars are necessary? Wonder why the 008 version comes with anti roll bar but not the earlier versions.
shadowless is offline
Old 07-15-2008, 09:43 PM
  #3692
Default Bars
Ive been running the 007 for nearly a year now on asphalt and ive tried all different setups. And have settled on soft springs with sway bars. Its just more consistent. If you dont run them I find i had to change springs as the grip changed. And you run a lot harder springs.
Try
Soft bar on back. Medium or hard up front.
And springs 2.2 or 2.4 on back or 2.4 or 2.6 up front.
Or (old springs) yellow, turqoiuse back, turqoiuse white up front.
Lees52 is offline
Old 07-16-2008, 06:08 AM
  #3693
act2007's Avatar
Trader Rating: 46 (100%+)
Default FDR for 10.5 motor!
Just got a 10.5 Brushless, want to know what's the optimal FDR
for a high speed with some tight corners Asphalt track? I have a
48P/84 and 48P/87 Spur that I've been using for my 4.5R. Any input
would be appreciated, thanks!
act2007 is offline
Old 07-16-2008, 08:04 AM
  #3694
try 5.5 to 6.5 FDR for your 10.5 on a 6 cell setup
Old 07-20-2008, 04:56 PM
  #3695
Trader Rating: 21 (100%+)
How tight should the diff's be. Or a good all around starting point for asphalt racing.
VA_Racer is offline
Old 07-26-2008, 01:17 AM
  #3696
ngo8's Avatar
bump
ngo8 is offline
Old 07-26-2008, 05:34 AM
  #3697
alecladanga's Avatar
for me, it'll depend on what motor your running. if you're running stock, a loose diff would be good. if you're running mod, set the diff tighter.
alecladanga is offline
Old 07-26-2008, 05:50 AM
  #3698
hi guys
will the LRP brushless motor heatsink with cooling fan fit the 007 EU without modifying/cutting the rear top deck?
attached picture for reference
thanks in advance
Old 07-26-2008, 05:00 PM
  #3699
xraysteve's Avatar
yes it should fit just fine. i have seen many t2 007s with them. with outany triming.
hey dos any one use a belt tenchener? what are they for and should i buy one?
xraysteve is offline
Old 07-26-2008, 06:43 PM
  #3700
Regional Moderator
CarbonJoe's Avatar
No, you don't need a belt tensioner on the '007. The composite bearing holders for the diffs are slightly eccentric, so that when you rotate them to the different notch settings, the belt tension changes. This is documented in the instruction manual. I know that they just came out with a belt tensioner for the '008, but I can't see the need for it, unless you need more bling and have money to burn.
CarbonJoe is offline
Old 07-27-2008, 09:18 PM
  #3701
Old 07-27-2008, 11:18 PM
  #3702
act2007's Avatar
Originally Posted by alecladanga
hi guys
thanks in advance
I had to cut the left rear "ear" upper deck to make it fit or you can also
use the optional Rear Upper Deck 2.0mm (part #301182) as seen in the
picture here: Hope this helps!
act2007 is offline
Old 07-28-2008, 03:28 AM
  #3703
thanks act2007 for the information and picture reference, it is very mcuh appreciated
Old 08-03-2008, 01:54 AM
  #3704
Dan87's Avatar
hey guys,
im running 540 class with a 007 in the state tittles coming up i was wondering if any of you guys could help me out with gearing as i have no idea cheers
Dan87 is offline
Old 08-03-2008, 02:25 AM
  #3705
rcstunt101's Avatar
Trader Rating: 16 (100%+)
Dan ive got a few 73 spurs on the way to make gearing a bit easier for brushless stock. Im also looking for gearing advice for a sp17.5 . Im starting with a rollout of 58. Does this sound in the ballpark?
Dan, found some info saying start rollout about 36-40. Start with pinion around 23 with 73 spur.
rcstunt101 is offline
