Old 04-19-2008, 12:39 AM   #3661
paul123's Avatar
Originally Posted by A. Rhodes View Post
This was an issue with the first batch of 007's, but Xay was supposed to have fixed the problem. I would contact RC America and let them know you are having the issue, and they should replace the parts.
Thanks, I will do that.
Shiny new B44
paul123 is offline   Reply With Quote
Old 04-27-2008, 01:58 PM   #3662
ziggy12345's Avatar
I am looking for an Xray 007 rolling chassis. Does anybody have one for sale?
Email me at [email protected]
Cheers
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 05-01-2008, 03:41 AM   #3663
paul123's Avatar
Default melting wheels
I am having a problem with the wheels melting onto the hubs front and rear on the left hand side of my t2 007, the axle'a and hubs are getting too hot to touch and one of my rims melted off during a race after about 4 min!
Does anybody know if this would be worn bearings?? help
Shiny new B44
Old 05-02-2008, 08:32 PM   #3664
anotherrcguy's Avatar
Trader Rating: 84 (100%+)
Default looking for multi diff
Does anyone have a multi diff in good shape they would want to trade for a diff?
PM me if you do.
anotherrcguy is offline   Reply With Quote
Old 05-04-2008, 12:25 AM   #3665
ford_racing's Avatar
Send a message via MSN to ford_racing
Sounds like it could be a dead or dying bearing, though you should be able to feel the car not driving as smoothly. Check driveshafts and bearings in the hubs, something is not quite right
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 05-07-2008, 06:54 PM   #3666
xraysteve's Avatar
hi i am running the t2 007 us version on asphalt. i am having trouble getting the rear end soft. no matter what springs and oil i run. the hinge pins are not bent or anything. in fact if i take the shock off the arm moves freely up and down. has any one else noticed this or is some thing wrong.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 05-07-2008, 07:37 PM   #3667
Trader Rating: 70 (100%+)
Inboard toe can have an effect on this,how much are you running?try taking 1deg inboard out and use 1deg hub you will feel quite a bit of difference
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 05-09-2008, 05:10 PM   #3668
wayne breault's Avatar
Default Spur Gear
I have a 2007 Xray that i'm trying to put a spur gear on. Can anyone tell me who makes the 100 tooth spur gear with the big holes around the side? Just got the car didn't reliaze that a regular 100 tooth supr gear would't work. I couldn't adjust pinon mesh. I looked at the Xray web site and they didn't offer a 100 tooth. Any help would be appreciated.
Wayne
wayne breault is offline   Reply With Quote
Old 05-09-2008, 05:36 PM   #3669
Regional Moderator
CarbonJoe's Avatar
Nexus Racing normally carries the new RW spurs, but they are currently out of stock on the 100 tooth.
http://nexusracing.com/index.php?cPath=145_321_322
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 05-09-2008, 07:33 PM   #3670
porsche928gs's Avatar
Wayne
Just drill some holes symetrically on opposite sides. 1/4 in should be good
porsche928gs is offline   Reply With Quote
Old 05-11-2008, 04:43 AM   #3671
Chris08527's Avatar
Trader Rating: 16 (100%+)
anywhere else you can get the RW spur, or anyone else make one that will fit with the brushless set ups???
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 05-13-2008, 09:20 PM   #3672
artwork's Avatar
Trader Rating: 62 (100%+)
Does anyone have a good step by step for rebuilding Xray Diffs?
I have built many diffs, but the Xray one's never come out very smooth after a rebuild.
I was wondering what kind of parts you replace in the process?
Do you sand rings?
What kind of grease do you use?
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 05-14-2008, 04:31 AM   #3673
Trader Rating: 16 (94%+)
Do you sand rings?
The thrust bearing is probably toast. This is the most common part to wear out. To keep them from toasting, you need to rebuild at least every 3-weeks of racing. Be sure to use good quantity of grease.
kn7671 is offline   Reply With Quote
Old 05-19-2008, 05:51 PM   #3674
Default set up sheet
I just got a t2 007 and it is set up for carpet with a 3.5mm carpet chasis.
I just got a eu rubber top deck.
can anyone give me set up suggestions for outdoor asphalt w/high traction.
Springs?
Shocck oil?
etc?
i Will be ok running the 3.5mm chasis??
Old 05-19-2008, 06:05 PM   #3675
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default 007
hey does anybody know where i can find blank setup sheets thanks for any help
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
