Old 02-18-2008, 05:39 AM   #3616
Trader Rating: 16 (94%+)
Originally Posted by blueskieshlg View Post
whats the differance between a 24 tooth 48dp pinion and a 24 tooth 64 dp pinion?
The difference between them is the pitch.
The definition of Pitch in this case: the degree of inclination or slope
48-pitch pinions require the use of 48-pitch spurs, while 64-pitch pinions requre 64-pitch spurs.
Why would you want one over the other? 64-pitch offers a greater variety of gear ratios since 64-pitch tooth count on the spur/pinion will be higher to reach the required diameters to work in the car. Most people agree that 64-pitch is slightly more efficient, but 48-pitch is more durable with larger teeth and contact area. A side benefit of 64-pitch is they are generally quieter than 48-pitch setups. Lastly, 64-pitch will mostly be used is racing, while 48-pitch is more universal for on-road and off-road RC cars.
kn7671 is offline   Reply With Quote
Old 02-18-2008, 06:49 AM   #3617
Thanks Kn7671 for taking the time to explain
blueskieshlg is offline   Reply With Quote
Old 02-18-2008, 11:01 AM   #3618
adamge's Avatar
I thought pitch was defined as number of teeth per inch of diameter. Measuring a 64p 44t pinion I have here, it is about .675" diameter (measuring the valleys, not the peaks), multiplied by 64 = 43. Close, I probably measured wrong.
-Nietzsche
Old 02-18-2008, 06:50 PM   #3619
xraysteve's Avatar
what the heck is everyone talking about. just get the spur you want and take a body hole reamer and make a hole. it dos not make a difference if the spur gear has the same size hole all the way around it. one is all you need. it will work. i have done this many times. you can also take the aluminum spur holder off the car to ream some holes for the gear to fit it.
lazer speedway everything else is a parking lot
xraysteve is offline   Reply With Quote
Old 02-18-2008, 07:35 PM   #3620
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
Picture please or it didnít happen.
How did you drill a 96 teeth spur gear? We are not talking about 110 teeth and up spur gears, we are talking about 96 or lower spur gears.
komkit is offline   Reply With Quote
Old 02-24-2008, 08:47 AM   #3621
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Help !!
The grub screw that holds the dogbone to the CVD on my X-ray is rust welded in place. Is there a way of getting that screw out without loosing the entire assembly? I am about to hit an auto store for some rust remove or something. Can anyone help out with this.
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline   Reply With Quote
Old 03-16-2008, 09:48 PM   #3622
daveflyr's Avatar
the front belt has been fliping on my t2 007 lately. the belt was originaly installed with the front diff eccentric installed at the center notch. a few months later an experienced t2 007 owner sugested that the belt was too tight, so the eccentric was moved one notch to loosen the belt. i had no problems with it for the longest time then the belt started to flip, some times just on the front diff gear, sometimes on both. so i put the adjustmet back to the center notch. it still flipped. so i went one notch tighter again, and it still flips. the belts teeth all look good, gear teeth are clean. as i cant see anything wrong with the car i am wondering if the belt flips when the car is subjected to an impact?
daveflyr is offline   Reply With Quote
Old 03-16-2008, 09:58 PM   #3623
I kinda came upon a set-up that worked by accident at my local track the other day. I completely rebuilt my car and left the bulkhead screws a little loose for a reason. The car felt completely dialed, had controlability like I havent had in a long time. After I took it off the track I remembered that I was supposed to tighten the screws down again. I did, lost all the traction.
Today I went to the track, loosened up all the screws and again, phenomenal handling. Got it back to the bench and saw I lost a couple of screws. Put some loctite in the screws but decided to call it a day for personal reasons.
Question: Should i be doing this or looking for traction elsewhere? A guy I talked to said it will do that but it will be inconsistent cuz the screws will be movin out or falling out...which they did. I have tried removing the screws for the support post and it seemed to do ok but not near as well as having the screws on all the bulkheads turned half a turn loose.
Any help is appreciated, thanks.
wcalaker is offline   Reply With Quote
Old 03-17-2008, 08:40 PM   #3624
SARCAR_Revmax's Avatar
Send a message via MSN to SARCAR_Revmax
Well, I for a fact have drilled a 75 tooth 48dp spur, and am positive I could do it with a 72. Not sure about a 69 though.
Xray T2 '007
SMC Batteries
Novak GTB 13.5/17.5 Brushless
SARCAR_Revmax is offline   Reply With Quote
Old 03-17-2008, 08:44 PM   #3625
Joel Lagace's Avatar
Can someone post a detailed picture of a GTB installed in there 007. I'm looking for a really sweet clean install. I stared at my ride and gtb for an hour and then just gave up....
I hate long wires, i hate clutter ect ect. Show me your best installs please.... The GTB ended up getting shoe horned into my xxxcr for now... But ill need a BL in my 007 soon.
Thanks guys
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 03-17-2008, 08:49 PM   #3626
Verndog's Avatar
R/C Tech Elite Subscriber
Trader Rating: 16 (100%+)
Yes...that will work....But it will also prematurely wear your bearings out and contribute to runnout because the gear will no longer be balanced.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-17-2008, 10:34 PM   #3627
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Thanks guys
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 03-18-2008, 12:15 AM   #3628
ernestf's Avatar
Send a message via ICQ to ernestf
Thanks guys
Hi, I am running Norsam ESC (same as LRP TC Spec), please have a look and hope this helps.
http://ernrc.blogspot.com/
ernestf is offline   Reply With Quote
Old 03-18-2008, 09:32 AM   #3629
act2007's Avatar
Trader Rating: 46 (100%+)
Thumbs up
Joel, you should check out this thread for some really nice
GTB set up. Hope this would solve your dilemma!
http://www.rctech.net/forum/showthre...=211010&page=3
Here's mine as a starter!
Xray T2'007-my-xray-t2-002.jpg   Xray T2'007-my-xray-t2-004.jpg   Xray T2'007-my-xray-t2-001.jpg
act2007 is offline   Reply With Quote
Old 03-18-2008, 09:41 AM   #3630
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Thanks guys
Here are some pics of my GTB set up in my 007. All of the leads to the servo, PT, and SC have been shortened. The sensor wire runs behind eveything.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
