Old 11-04-2007, 07:18 PM   #3511
adamge's Avatar
Joe, do you find you have to tighten the belts as they wear?
Also, I love your signature. I'm pretty new, but I race for modified. I run stock and 19t because mod often isn't run or is poorly attended, but they are rather boring.
I've been trying to set up my 007US mod car for foam-carpet. I'm running 5cell 4.5t brushless. I'm having trouble finding a great, 'dialed' setup. My stock and 19t car (my other 007US) seems pretty easy to get dialed. The mod car, though, seems like it either is hard to drive because it will dig into a corner hard, or doesn't have enough steering, or traction roll. Do you have any tips, and what's your current foam-carpet mod setup?
-Adam
-Nietzsche
Old 11-04-2007, 07:43 PM   #3512
adamge's Avatar
Hey, good news. I just noticed this new setup posted:
http://forum.teamxray.com/xform/inde...8&setup=t2_007
It does some things I've been sort of thinking about to solve the problem of traction rolling and biting in up front when running a soft tire up front. He's running considerably stiffer front damping (5lb stiffer oil, lower outer shock mount point). He's gone to a higher front roll center. He's running the big anti roll bar up front. He's gone to 4deg caster.
I'm definitely trying this setup. Unfortunately, my local club's mod class literally died yesterday, so I won't get to try it until the next big regional race in three weeks.
from Xray's forum:
XRAY 30w (new 450cst) = AE 50-55wt
XRAY 25w = AE 35-40wt
-Nietzsche
Old 11-04-2007, 10:19 PM   #3513
The furthest I have ever gone is 3 notch's in. Thats as far as I have had them stretch as they wear in. This is a link to my set-up from a race today and it was very good.
http://forum.teamxray.com/xform/inde...2&setup=t2_007
hope this helps
Joe
Real men race MODIFIED!!
JoeGlover is offline   Reply With Quote
Old 11-06-2007, 09:49 PM   #3514
TonysScrews's Avatar
Trader Rating: 13 (100%+)
UPDATE!
Team Xray T2 007 screw kits are now in stock!
Team Xray T2 007 190-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts and set screws.
Thanks and best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 11-08-2007, 03:42 AM   #3515
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anybody know the size of the c-clip in the rear differential? are there alternative parts or can i get it from a hardware store? mine flew when i was rebuilding the diff and can't find it anymore.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-18-2007, 10:17 AM   #3516
CREWMAN's Avatar
Trader Rating: 19 (100%+)
My local Track closed and i am considering changing my T2 us edition to the euro one. I plan on just buying the Euro conversion, but what will the Multi Diff do for my performance. You have mentioned it in previous posts and i don't understand the difference between the multi diff and the one that is in my car now. I am new to indoor touring and haven't even tried to running it outdoor.
Thansk
D&K HOBBIES!!!!
Losi 8ight-T 2.0 Race Roller/Losi 350/JR 9100 Servos/Spektrum DX3R
BMI Copperhead 12/Thunder Power Lipo/Futaba Servo/Express 17.5/Spektrum DX3R
CREWMAN is offline   Reply With Quote
Old 11-18-2007, 10:38 AM   #3517
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Thansk
Crewman - you only really need to get the EU chassis, top deck, and the multi diff. to convert your US spec over. Buying the conversion kit, especially with the 008 right around the corner, will get you stuff you really dont need, especially the bulkheads.
As for the multi diff, it gives you the option to run a solid axle/spool, one way, or solid one way. The diff if your car now is just a ball diff and is not the best choice for asphalt or rubber carpet.
As for the track, yes yesterday was the last race at Horsham, but we plan to be in a new building with a new track as a club in the next 3 weeks
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 12-15-2007, 12:24 PM   #3518
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Can some people post some pics of there GTB set-up in there cars..
I have like no room for it. I ran out of configurations to get it in there..
Thanks..
HRCRACER123 is offline   Reply With Quote
Old 12-15-2007, 01:00 PM   #3519
BSchorr's Avatar
R/C Tech Elite Subscriber
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
I shortend the servo wire on the board to nothing! Micro spektrum RX, stealth AMB in the front bumper
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 12-15-2007, 01:31 PM   #3520
Wow..That looks sweet...Thanks.
Old 12-15-2007, 02:11 PM   #3521
dal bains's Avatar
Trader Rating: 35 (100%+)
Here is my gtb before it was swapped out for the lrp.
The heatsink has been milled down. The novak cap was replaced with the speed passion cap and now with the TOP cap. The brushless motor leads were shortened. Didnt help now with wanting to use the motor for off-road, but I'll find a way to lengthen it!!
Xray T2'007-c7-2-.jpg   Xray T2'007-c6-2-.jpg   Xray T2'007-c5-2-.jpg   Xray T2'007-9c61_1_b.jpg   Xray T2'007-topsupercap.jpg
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 12-16-2007, 04:13 AM   #3522
BSchorr's Avatar
Cmon guys, just because teh 008 is coming out, dont let this thread die!
Here is my new lid i painted first time using liquid mask
Old 12-16-2007, 05:53 AM   #3523
ernestf's Avatar
Send a message via ICQ to ernestf
Hi, here is my 5cell car - 007' with Nosram brushless ESC and SpeedPassion 3.5R ESC.
Xray T2'007-img_0007.jpg   Xray T2'007-img_0008.jpg   Xray T2'007-img_0009.jpg   Xray T2'007-img_0014.jpg
ernestf is offline   Reply With Quote
Old 12-16-2007, 05:55 AM   #3524
ernestf's Avatar
Hi - nice layout !!
May I know how the SpeedPassion cap work with Brushless system ?
Ernest
Old 12-16-2007, 09:54 AM   #3525
My GTB set ups. I shortend the servo, PT, and GTB leads. The sensor wire has been wrapped in protective tape and run behind the electronics.
Retired from RC....
