Old 10-11-2007, 03:15 AM   #3436
Originally Posted by Nexus Racing View Post
This is incorrect...all the T2 and T2'007 lower chassis are completely interchangeable .
You could put a T2/T2R chassis on a 007, or a 007 2.5mm/3.5mm chassis on a T2/T2R. In fact, XRAY titles the '007 chassis "T2 chassis".
You are right. I actually have both, but only now i realised the chassis is the same, although the top deck and bulkheads are different.
Itchy is offline   Reply With Quote
Old 10-11-2007, 03:19 PM   #3437
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys
just got the brushless set up today in the mail
lrp tc spec esc and peak 10.5 system
does anyone have any pics of the lrp in mounted in the car, room looks a little tight
also what kind of spur/pinion you running i am going to the last outdoor race of the season sunday, on a big flowing "gas type" track
Chris
Chris08527 is offline   Reply With Quote
Old 10-11-2007, 05:03 PM   #3438
Anyone got the measurement for the height between the upper and lower deck?
Thinking of getting the T2 007 but wanna make sure my Maxamp 4400mah Saddlepack lipos will fit under the upper deck.
Lplate is offline   Reply With Quote
Old 10-11-2007, 07:23 PM   #3439
BSchorr's Avatar
R/C Tech Elite Subscriber
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Chris, Ill take a pic in a bit of my 007, but as for spur and pinion.. you want to be around a 33-34mm rollout with a 10.5. I was running a 114 spur and the max pinion i could go was a 35 which set my mesh perfect. And my tires were at 60mm (Jaco Prisms) so when my tires got smaller, i was screwed, cause i couldnt gear up to maintain that rollout.
But if i was going to race stock sedan, i would be screwed... inorder to get part of both worlds.. stock and 19 turn, you have to get the RW 108 spur, that way you have the range for teh 40ish rollout that th 13.5 calls for.
33ish for 19turn, 40is for stock
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-11-2007, 07:37 PM   #3440
BSchorr's Avatar
21.5mm
Old 10-11-2007, 07:53 PM   #3441
BSchorr's Avatar
Ya
Old 10-11-2007, 11:00 PM   #3442
Cristian Silva's Avatar
Trader Rating: 11 (100%+)
After all this discussion about gearing,
Im curious to know what rollout everyone is using for BL 13.5 48 or 64 pitch?
Im trying to get a good starting figure for running rubbers on asphalt.
Ive heard 116 spurs a popular? not sure why
Cristian.
Cristian Silva is offline   Reply With Quote
Old 10-11-2007, 11:26 PM   #3443
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Originally Posted by Chris08527 View Post
hey guys
Chris
here's mine with a GTB...
switched to LRP TC and the layout is pretty much the same. the only diff would be that the LRP capacitor is ziptied under the topdeck.
i'm using an orion 10.5 so that would be around the same as the peak. i'm, geared 4.9 to 5.1 fdr (rubber/asphalt)
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 10-12-2007, 02:12 AM   #3444
BSchorr's Avatar
If you are going to run brushlees 13.5 in a 007, you HAVE to get a 108 spur gear to be able to gear high enough for a 13.5 motor, otherwsie you will be slow..... No ifs, ands.. or buts..
Xray does not make a 108 tooth, so you have to get it from RW Racing. If you want to continue running the 46 pitch.. Im not sure who makes a smaller 46 pitch.. i think xray makes a lowest of 82 or 84
116's are popular because bigger teh better for a Brushed motor, it allows for finer adjustment gearing.
Old 10-12-2007, 02:44 AM   #3445
Castradamus's Avatar
Trader Rating: 53 (100%+)
Default Misc. Parts
I have left over parts from my T2 if anybody is interested.
1 - Parma Hard Bumper
1 - Front Belt
2 - Rear Right Carriers
2pr - 4 Deg Caster Blocks
1 set - Team Tamale Shock Tower Braces
3pr of Springs (LT. Purple, Purple, Violet)
I am open to trades (Corally RDX part prefered but will consider anything).If you are interested, send me a PM.
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 10-12-2007, 03:51 AM   #3446
Cristian.
We are running 4.6-5.0 on asphalt using a RW 104 or 100 tooth 64 pitch spur.
tarheelquality is offline   Reply With Quote
Old 10-12-2007, 08:43 AM   #3447
syndr0me's Avatar
Trader Rating: 32 (100%+)
49-50mm with the 13mm rotor in the Novak 13.5. Yea, it's nuts.
syndr0me is offline   Reply With Quote
Old 10-12-2007, 09:36 AM   #3448
BSchorr's Avatar
You cant go much about a 42mm rollout with a 108 spur.. do you mean 39-40* cause 50mm isnt realistic with a 007
Old 10-12-2007, 09:42 AM   #3449
syndr0me's Avatar
I'm not sure about the 007, sorry. I'm currently running about 49.5mm (and looking for more) in my R using 108/53. There's some room for bigger pinions yet. The 13mm rotor makes the Novak 13.5 unruly for gearing. :-)
Old 10-12-2007, 05:34 PM   #3450
The previous info about gearing has been very helpful,
Just curious to know what would be a better mesh.
an 84 spur with a 28 pinion or
a 108 spur with a 36 pinion
both have a rollout of 38.81
would their be an difference?
thanx
