Old 09-13-2007, 01:49 PM   #3361
BSchorr's Avatar
R/C Tech Elite Subscriber
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Anyone have a starting point for gearing/mm rollout with lets say... 58mm tires.. for the 10.5 and 13.5 on carpet?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-13-2007, 02:34 PM   #3362
The Evicerator
Maybe 33.5 mm for the 10.5 and maybe around 40 mm for the 13.5 ... that's just from my rule of thumb... not from experience though... some other guys might have more refined answers.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 09-13-2007, 03:20 PM   #3363
jallshouse's Avatar
Send a message via Yahoo to jallshouse
what size spur/brand spur gear are you running?
jallshouse is offline   Reply With Quote
Old 09-13-2007, 06:49 PM   #3364
Send a message via AIM to jsl6v8
looking for suggestions on a spur and pinion for stock asphalt racing here in Florida, extremely technical track, the straightaway is maybe 25-30 feet and there is only 1. For my T2 not a 007. I'm looking not to thermal, it will be my first time racing so I'm really just learning to drive more than trying to win.
jsl6v8 is offline   Reply With Quote
Old 09-14-2007, 01:43 AM   #3365
Originally Posted by racer34v View Post
hardend steel, usually something like 8620 alloy
Thanks for that. Found a great website with all the specs I needed.
jsl6v8:
I've raced pretty open and tight tracks with a FDR of about 6 to maybe 6.5 max. I'd suggest going maybe a little higher if you're after less speed. Between 6.5 and 7?
FDR = (internal ratio) * (no. of teeth on spur) / (no. of teeth on pinion)
T2 internal ratio = 1.7
A.D.D. is offline   Reply With Quote
Old 09-14-2007, 05:18 AM   #3366
Thanks A.D.D
Old 09-14-2007, 07:13 AM   #3367
ok I'm looking at a final drive ratio of 6.4 for my T2, pretty dern technical course for my stock motor so 1.7 * spur/pinion= 6.4 now my question is does the combination of spur and pinion make a difference? is it the Gear ratio itself that causes motors and ESC to overheat and thermal or is it to large of a spur on to small of a pinion kind of thing?
Also I don't know if anyone does this but I have a bunch of 1.5mm shims that I would trade for .75mm or .4mm shims Also I have a left and right 6 degree C hub I would trade for 4s and a bunch of lower suspension holders top(+.75) and bottom dot(-.75), not middles that I would trade for more middle dotted ones. Not sure that anyone uses these even but I figured if someone did might as well get me some more spares of the stuff I use.
Old 09-15-2007, 05:33 PM   #3368
daveflyr's Avatar
Default steering servo torque
Leaving 1/12, moving to 1/10 sedan. LHS has ordered an xray t2 007 (US), and i will need a new steering servo. speed is important, the faster the better, but what about the torque? what is the minimum number of ounces of torque required for this car?
daveflyr is offline   Reply With Quote
Old 09-15-2007, 07:03 PM   #3369
BSchorr's Avatar
the ideal is 100oz in at .10 but everyseems to go with the low-profiel 9550
Old 09-15-2007, 09:18 PM   #3370
ChrisP's Avatar
KO 2413 here....works like a dream!
ChrisP is offline   Reply With Quote
Old 09-17-2007, 04:29 AM   #3371
It's just a too lower gear ratio that'll cause overheating. As long as you find the right spur/pinion combo you'll be fine. I think the max sized 48 pitch spur you can stick in a '007 is 87... not sure about the T2 though.
If you're after getting the last millisecond out of laptimes, use smaller spurs and pinions for less rotational intertia. But to be honest, the difference in size is pretty insignificant. The main difference will be due to the motor being positioned more to the front or back.
Check the inside back cover of your manual/set-up book for a whole range of combos to arrive at the ratio you're after.
Old 09-17-2007, 05:10 AM   #3372
figured it out yesterday I'm going to go with a 22/84 but I'll get a 21-23 just in case I don't like the 22. Also anyone able to find a good picture of a brushed motor on the GTB, I can't seem to find a good picture that shows me what I'm suppose to do to this thing as far as wiring it.
Old 09-17-2007, 08:10 AM   #3373
HD-F1's Avatar
Trader Rating: 18 (100%+)
Hey guys, I have never owned a xray before and wanted to know a few things. It's a T2 (not a 007) has the original chassis but I did chance the top plate out for the thick one that has no reliefs in it and put in the posts that are to stiffen it up. What I wanted to know is with all those screws in it is really prone to tweak in the event it makes hard contact with something. Dont really know, figured someone in this thread would have some insight on it.
Thanks,
Heath
WWW.MAXAMPS.COM
WWW.HYPERDRIVERACING.COM
WWW.NITROKILLERS.COM
myspace.com/ballisticwhiplash01
COOPER MOTORSPORTS
HD-F1 is offline   Reply With Quote
Old 09-17-2007, 09:49 AM   #3374
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys, which stores have the BEST price on the T2 '007 's ? (rubber or foam) ...
thanks,
Pat
Tabushi is offline   Reply With Quote
Old 09-17-2007, 10:08 AM   #3375
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
There is a nib rubber tire version on fleabay for 379.00 with free shipping.
1armed1 is offline   Reply With Quote
