Old 08-23-2007, 02:53 PM   #3241
peded's Avatar
Originally Posted by peded View Post
Does anyone reccomend running AE springs on the car? Are they longer or shorter or what? I've seen quite a few setup sheets that run AE springs...
Anyone else?
Xray T2 US '007, JR Z590 servo, KO PROPO EX-10 Helios, Novak GTB, Novak 13.5, EP4600?, Orion Advantage.
Sportworks Recoil - MMR Spec, GTX
Additional Feedback: http://rctech.net/forum/showthread.php?t=145047
peded is offline   Reply With Quote
Old 08-23-2007, 03:03 PM   #3242
You will be fine with the Xray springs. But if you are running rubber tires, HPI springs may work better for some tracks. Many european team drivers have been using them lately.
Hagberg is offline   Reply With Quote
Old 08-23-2007, 03:05 PM   #3243
Chris Adams's Avatar
I would listen to Paul L.... Im pretty sure he knows what he is talking about..
TEXASEOS.net, RcAmerica, Xray, Hudy, Protoform, Orca, Avid, 2mm Designs, Ulti Tires America
Texas EOS 2018!
Chris Adams is offline   Reply With Quote
Old 08-23-2007, 03:09 PM   #3244
peded's Avatar
Its just the LHS don't carry very many pairs or sets for Xray so I know theres strong AE support around here so I thought why not use AE springs.
Old 08-23-2007, 07:17 PM   #3245
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i'm currently using Tamiya springs... works for me. Running on asphalt/rubber tho
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-23-2007, 09:29 PM   #3246
Gravity RC
Peded: I guess what i was trying to say is that i dont think that you would have bad luck with AE springs but even if it says 14lbs it dosent mean that it will work the same as an Xray 14lb spring. it will most likely have different size wire, different number of coils and a different overall legnth even though it has the same rating.
When i used the Ae springs years ago i struggled a bit with finding the right spring because they jump around a bit in the set with the copper spring being very progressive and i thought that it ever fit into the set.
Xray for example offers their regular set of springs but also offers the gold and silver spring that are more progressive but with the same Lb rating as the white and yellow.
Paul L is offline   Reply With Quote
Old 08-24-2007, 01:06 AM   #3247
rmdhawaii's Avatar
I've had my eye on the xray springs sets trying to decide if I'm going to buy both sets, but I realize that I'm never going to use all of them. For those of you that are running on asphalt, have you noticed that you have a tendency of staying below a certain spring weight - say 25 lbs?
14 LB Yellow/Gold - Super-Soft
15 LB Blue-Green
17.5 LB White/Silver - Soft
20 LB Light-Blue
22.5 LB Blue - Soft-Medium
25 LB Dark-Blue
28 LB Violet - Medium
30 LB Light-Purple
33 LB Purple - Medium-Hard
35 LB Light-Red
38 LB Red - Hard
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-24-2007, 02:03 AM   #3248
LOSI123's Avatar
Trader Rating: 63 (100%+)
I know this is the T2 007 thread but i assume a lot of you had the T2.
So my ? is, on the T2 kit there are 2 sets of the things that go onto the end of the shock shafts to connect to the A arms,
the manual says do not use this one but to use that one,
one is longer and one is shorter,
and i pulled all the parts off the parts tree so i dont know which ones the manual says are the ones to use or not !
so should i use the longer or shorter ones?
LOSI123 is offline   Reply With Quote
Old 08-24-2007, 02:19 AM   #3249
LOSI123's Avatar
Also any one know if a 77t spur & a 32t Pinion (48pitch) will fit ok with room to move up and down a bit in the motor mount, in a T2.
its for 540 Silver can racing where i need to be able to adjust rollout between 46mm and 50mm
thanks.....
Old 08-24-2007, 05:40 AM   #3250
Gravity RC
rmdhawaii: for asphalt i dont think you would have to go stiffer than a 22lb spring.
Losi123: i always use the short ones with no problems, and i assume that those are the ones that they tell you to use in the manual. as for the gearing, sorry i dont know. but im sure that their is a way to get that roll out if it dosen't.
Old 08-24-2007, 06:19 AM   #3251
LOSI123's Avatar
thanks, the manual says to use parts number XXXX for example but i have no idea which ones are which part numbers.....
Old 08-24-2007, 01:16 PM   #3252
rmdhawaii's Avatar
Thanks Paul!
Old 08-24-2007, 01:38 PM   #3253
what tamiya springs are you using mate? colours?
jordan
jordys jrxs is offline   Reply With Quote
Old 08-24-2007, 04:05 PM   #3254
rmdhawaii's Avatar
Setup Book: Effects of Shock Damping - Correction:
http://www.teamxray.com/teamxray/new...p?news_id=1250
Old 08-24-2007, 06:46 PM   #3255
ottoman's Avatar
R/C Tech Charter Subscriber
Trader Rating: 13 (100%+)
You want to use the short ones
ottoman is offline   Reply With Quote
