Old 08-16-2007, 06:28 AM   #3226
sinisterRC's Avatar
I have a quick question.
I just rebuilt the car and now it pulls to the right under throttle, any suggestions? Im planning on rebuilding the steering system and re-alighning it but maybe there is something I should look for.
MUGEN Tekno - MBX6TE TEKIN
Custom Nitro Pro Mod
MRX6 under construction..
sinisterRC - High Performance R/C
sinisterRC is offline   Reply With Quote
Old 08-16-2007, 06:38 AM   #3227
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
just a minor gripe... was running my kit last week's club race.... after one of the runs, i noticed my rear left wheel wobbling. not knowing what it was i pulled the rear axle apart to try to find out what was wrong. turned out to be a shattered bearing. and i mean shattered. the balls were all gone. the outer rin broken in like 3 or 4 segments... etc, etc. thinking nothing of it, i replaced it and ran the final heat.
when i got home, i decided to pull out all the bearings and replace them with some spare metal shielded bearings i still had (side note: tamiya m4wd 10mm bearings fit perfectly). when i pulled apart the rear right axle, it too had a shattered bearing. not as bad as the left one, but still shattered.
fixing it is realy easy for as long as you have access to the parts needed. i guess i'm just posting this for the xray guys as a heads-up. might want to check and re-check the quality of the other components that go with the kit. i know xray is known for high quality and craftsmanship and i wouldn't want someone to ditch their xray kit just because they got fustrated with some shattered bearings.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 08-16-2007, 02:02 PM   #3228
sinisterRC's Avatar
whaen adjusting toe on the front wheels are you able to do so through the steering rods or is it strictly done through the spacers?
Old 08-16-2007, 02:06 PM   #3229
rmdhawaii's Avatar
You can use the steering rods. Checkout page 19 of the setup book.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 08-16-2007, 06:15 PM   #3230
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
I am selling mt X-Ray if anyone is interested...
http://www.rctech.net/forum/showthread.php?t=177188
HRCRACER123 is offline   Reply With Quote
Old 08-17-2007, 06:56 AM   #3231
sinisterRC's Avatar
Well pretty sure I bent the rear bulkhead in one of my recent wrecks! That's why the car is not tracking straight. The back end sways around like its doing the lambada!
Old 08-18-2007, 01:19 AM   #3232
evo8guy's Avatar
Trader Rating: 28 (100%+)
Hello, I am new to onroad and just picked up a used 007 us. I seem to have alot of tweak on the car, I was wondering if someone might be able to tell me how to straighten it out. Any help would be great.
Mike Steidtmann
Top Gear Hobbies Raceway
Team Associated / Futaba / Reedy / Tekin /
evo8guy is offline   Reply With Quote
Old 08-18-2007, 08:22 AM   #3233
Nexus Racing's Avatar
R/C Tech Elite Subscriber
There is both a .pdf and a post at this link that can help you out:
http://forum.teamxray.com/viewtopic.php?t=2872
Instead of placing the car on droop blocks, I usually just place my car (w/o tires) directly on a flat surface to square it up.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 08-18-2007, 10:44 AM   #3234
evo8guy's Avatar
Thanks alot for the info...looks like I have alot to learn
Mike Steidtmann
Old 08-20-2007, 03:14 AM   #3235
peded's Avatar
I'm looking for a setup sheet for a Med-large Asphalt track. Med traction and running with foams. I will be running 38's or 40's all the way around.
Tracks range in different designs but generally in this perimeter: http://rctech.net/forum/attachment.p...7&d=1187197705 and
http://rctech.net/forum/attachment.p...5&d=1186593450
Xray T2 US '007, JR Z590 servo, KO PROPO EX-10 Helios, Novak GTB, Novak 13.5, EP4600?, Orion Advantage.
Sportworks Recoil - MMR Spec, GTX
Additional Feedback: http://rctech.net/forum/showthread.php?t=145047
peded is offline   Reply With Quote
Old 08-22-2007, 07:09 PM   #3236
busman's Avatar
Originally Posted by PitCrew View Post
XRay sweeps all but one class at the 20th Annual Summer Sizzler in Tacoma, WA.
Stock: Jon Sterling FK05
19T: CJ Redelfs (me) T2007
Open Mod: Korey Harbke T2007
Gas Touring: Mark Tveten NT1
Only brushless 13.5 was not won by an Xray; Ritchie Reynolds, with some "other" car. LOL
and unlike the "other" mains, i won mine running away, even with a older version none sintered novak motor. in a Mi3
(ritchie, under mikes screen name for some unknown reason.)
busman is offline   Reply With Quote
Old 08-22-2007, 11:21 PM   #3237
peded's Avatar
Does anyone reccomend running AE springs on the car? Are they longer or shorter or what? I've seen quite a few setup sheets that run AE springs...
Old 08-23-2007, 12:21 AM   #3238
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
actually thats a good question. i would like to know myself because i got the complete factory team set from my tc3 laying around. i think all spring rates are the same just different colors i think.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 08-23-2007, 01:04 PM   #3239
Gravity RC
I know that AE springs will fit but i dont see any advantage in using them over the x-ray springs. but everyones springs will be a different on the track just by the endless different ways to come to a 14,15,16ect ect lb spring.
Paul L is offline   Reply With Quote
Old 08-23-2007, 01:17 PM   #3240
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Paul how you been...... havent seen you at the track since the diaper incident ...
I will get you back.....
wallstreet is offline   Reply With Quote
