Old 07-27-2007, 08:29 AM   #3091
davo7's Avatar
Rocket Racer...Congrats on your new 007 purchase. In the future when you do not want to go crazy waiting for X-Ray parts,do not bother ordering any parts from your LHS. For some reason a lot of 007 parts are not being shipped from RC America to your LHS.(shock springs,shock spring kits, rear belts and cone washers for the diff.)Good news is Stormer probably has at least 5 of everything....I bet Ashford does too. Someone correct me if I am wrong.
davo7 is offline   Reply With Quote
Old 07-28-2007, 10:00 AM   #3092
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Tried fitting a Peak 4800 lipo in my kit... noticed that the pack hits the rear centerdrive bulkhead. because of this the battery sits a bit more foreward than the usual nimh pack. is this ok? won't the pack pe damaged from the it rubbing agains the bulkhead during the normal twisting of the chassis?
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is online now   Reply With Quote
Old 07-28-2007, 10:59 AM   #3093
team green's Avatar
Read this http://nexusracing.net/newsdesk_info.php?newsdesk_id=60
team green is offline   Reply With Quote
Old 07-28-2007, 11:07 AM   #3094
VooDooPH's Avatar
Originally Posted by team green View Post
yup. read that. did the spacer mods to lift the topdeck already. just want to make sure the rubbing doesn't ruin the battery... the lipo pack aint a cheap "investment".
Old 07-28-2007, 03:32 PM   #3095
protc3's Avatar
Trader Rating: 13 (100%+)
what may not be a bad idea is pulling the chassis off your car,picking up a barrel sander bit for your dremel and sanding the webbing between the cells about 1mm.dont go all the way out the side of the chassis.this should allow the pack sit sit a little lower and not casue it to rub the bulkhead
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 07-28-2007, 03:39 PM   #3096
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
Yeah, you're wrong... I have no problems getting 007 parts.
mrrcguy is offline   Reply With Quote
Old 07-28-2007, 03:55 PM   #3097
Big B's Avatar
We have the same problem at SIR, it is a month to two months to get parts from RcAmerica, I don't know how Stormer gets them so regularly, it is getting to be a hassle and I am going to have to buy a couple spares of the usual things (arms, knuckles, etc..) as I can't run my car hard for fear of breaking something specially when that something isn't in stock
Big B is offline   Reply With Quote
Old 07-28-2007, 05:13 PM   #3098
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Nexus Racing try them I am sure they will get you what you need.
Rod
RKeasler is offline   Reply With Quote
Old 07-28-2007, 05:39 PM   #3099
C_O_jones's Avatar
Trader Rating: 11 (100%+)
SIR has a good selection of parts, they got in a big order the week of the nats.
Lots and lots of steering knuckles, C-hubs and rear hubs.
What else breaks ?
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 07-28-2007, 06:02 PM   #3100
Big B's Avatar
What else breaks ?
Actually the only thing I have broken yet was a L side steering knuckle, either the chassis is super tough or I have been really lucky. I will have to go down and stock up on some things since they have some in stock
Old 07-28-2007, 11:37 PM   #3101
Cool
Anyone got a setup for a track with the following?
50x130, parking lot sprayed w/soda (loose), somewhat tight,
125 degree temperature........my gearing was fine (30/114) but
the car felt really loose. I was using RP-30's and was tempted
to try 32's or 36's. Any help would be appreciated. I would try going
to XRAY's site but usually track conditions are for high traction/super smooth
tracks which is not my case. Thanks for any help.
daveb is offline   Reply With Quote
Old 07-29-2007, 12:10 AM   #3102
adamge's Avatar
dave, I've never ran on a hot track like that, but I'm also running on a parking lot sprayed with grape soda, 50x100. I've never driven asphalt on another track, so I can't evaluate the traction, but it seems pretty good. We don't do much sliding - well, at least my car doesn't.
I'm loving KoreyH's setup:
http://forum.teamxray.com/xform/inde...6&setup=t2_007
I made a couple tiny changes to it that seem to make it faster for me:
http://forum.teamxray.com/xform/inde...9&setup=t2_007
What body are you running? That seems fairly important. What motor?
-Nietzsche
Old 07-29-2007, 12:23 AM   #3103
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
ok ive been through almost 300 pages on rctech in general, and i still cant find a link to show like if i wanted to use losi shock oil but all i had was associated or kyosho. yes there is a difference! i cant seem to find one anywhere.
also what is the difference between the novak 13.5 and the ex13.5?
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 07-29-2007, 07:32 AM   #3104
BBSpence's Avatar
Trader Rating: 45 (100%+)
If you use the search option, there are several posts on this. Here is a chart that came up in the search....
BBSpence is offline   Reply With Quote
Old 07-29-2007, 11:16 AM   #3105
jrr102486's Avatar
thanx a ton. i totally spaced on the search option.
