Old 07-21-2007, 02:05 PM   #3016
rmdhawaii's Avatar
Originally Posted by PitCrew View Post
The carpet chassis was the BMI chassis. I ran all screws in the bottom, and I removed the front rear, and rear front set of screws on the top deck. (hope that doesn't sound too confusing).
On the EU right now I'm running all screws in except the bottom screws that are in the cut out area (that screw into the bottom of the bulkhead).
If you plan on running a spool, just run a diff really tight. Unless you can absolutely keep the car off the boards. A tight diff can save your car a bit because if you stuff a pipe, then energy can "diff out" to the other side of the car. Instead, if you are on power with a spool (or one way also) you can more easily bend your dog bones, our break the outdrive savers.
Understood. Thank you
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 07-21-2007, 02:34 PM   #3017
jrr102486's Avatar
Send a message via MSN to jrr102486 Send a message via Yahoo to jrr102486
Originally Posted by adamge View Post
jrr, are you racing on asphalt or carpet, and rubber tire or foam?
i will mainly be racing carpet rubber.
Josh Riese - 2002 Subaru Impreza WRX (212whp/223trq 12psi no tune!)tuning stage 2.5 @25psi
jrr102486 is offline   Reply With Quote
Old 07-22-2007, 09:26 AM   #3018
TMcKinney711's Avatar
Pit Crew one question, your saying if im running a one-way I need to run my rear diff tight? Not understanding what diff-out means?
TMcKinney711 is offline   Reply With Quote
Old 07-22-2007, 10:48 AM   #3019
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
hope ya don't mind... just posting some pix of my T2... haven't run it like this though (new RX and servo)...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 07-22-2007, 02:53 PM   #3020
PitCrew's Avatar
No. I was telling him that if he wanted to run a spool in the front, he is better off running a very tight diff to save breaking parts if he isn't super super clean. A one way and spool have a tendancy to bend drive shafts and break the outdrive savers more easily than a tight diff. Because a tight diff is STILL a diff, and will allow much of the energy to spin the tire that isn't in contact with the board or pipe. If he wants to run a one way though, then he'll just have to run a one-way.
This doesn't affect the REAR diff in any way.
Diff-out is a term used to describe when say for instance you are exiting a corner and the chassis is leaned to one side. When you get all over the throttle, the inside tires can spin. Happens more in higher power situations like 19t or open mod. There is probably a more specific term for this though.
PitCrew is offline   Reply With Quote
Old 07-22-2007, 03:38 PM   #3021
SammyZ's Avatar
Trader Rating: 138 (100%+)
how do you know if the diffs are too tight or too loose?
SammyZ is offline   Reply With Quote
Old 07-22-2007, 04:33 PM   #3022
PitCrew's Avatar
If you can slip the diff, its too loose...
Its probably too tight if you can rotate the motor when you try to turn one wheel.
Other than that, its mostly feel. I wouldn't say there is one particular setting that is best. It depends on the track condition and your set up.
But as far as running a front diff instead of a spool, get it set tight enough that you DO rotate the motor when you turn one wheel, then back it off just a pinch (just so you don't rotate the motor). I know thats a vague statement, which depends on the particular motor and gearing, and is probably more difficult to get the right feel with a BL motor which has very little drag.
Old 07-22-2007, 05:38 PM   #3023
Ow ok thanks for clearing that up Pit.
Old 07-22-2007, 07:28 PM   #3024
Big B's Avatar
I was told to run the 007 rear diff a little looser than normal, how do you have yours setup for SIR?
Big B is offline   Reply With Quote
Old 07-22-2007, 07:48 PM   #3025
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
I just have mine setup so it only slips when you really reeef on it. The car will never put that much load of the diffs so it works well. My diff when spun feels really free... but it doesnt slip.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-22-2007, 08:11 PM   #3026
PitCrew's Avatar
I have mine set probably just a touch tighter than what Korey has described. But, as he says, it should not slip.
But, yes, it should always be a little looser in the rear than the front.
Old 07-22-2007, 08:21 PM   #3027
since we are into the diff topic..... I am new to on road and xray for the most part previously ran 1/10 off road.. anyhow the problem i am experienceing with my t2 007 is lag when i stand on the throttle from a stop.. upon further investigation the center of the diffs (where the belt rides) will spin before the tires. not sure if this makes any sense but if i were to hold the car against something and hit the throttle i can watch the belts run but the tires dont turn.
I am running a mamba 7700 with a 24t pinion to a 109t? (stock) spur. I know thats alot of power but i am having trouble transferring it to the ground !! can the diffs be tightened ? how there is nothing in the manual that i can see. will this affect my cornering?? what are my options? it takes half of the back straight before the full power becomes noticeable.
any help appreciated thanks in advance .
brew is offline   Reply With Quote
Old 07-22-2007, 08:43 PM   #3028
PitCrew's Avatar
Yes, your diffs need to be tightened. They are slipping, which will significantly shorten their life.
In the diff outdrive, there is a small hole. You will see iy between the bulkheads. Rotate that hole so you can insert a small allen wrench through the hole (There is the head of a screw with a hole that must be lined up, do this by holding one tire and rotating the other).
Now, with the allen wrench all the way through the hole, hold the wrench in place and rotate the SHORT end of the outdrive by rotating the tire; CLOCKWISE. In the rear of the car, this is the RIGHT side.
Old 07-22-2007, 08:49 PM   #3029
Could you explain about the diff slipping, are you talking about when your on throttle or when you hold a tire and try to slip it that way? I think ive been running my rear diffs too loose.
Thanks!
Old 07-22-2007, 10:05 PM   #3030
PitCrew's Avatar
You should not be able to slip the diff either way.
A diff in ANY car should NEVER slip.
