Old 06-09-2007, 12:29 AM   #2731
I didn't get it today. Maybe tomorrow (today Sat.). I was hoping to race but o-well. Dave
daveb is offline   Reply With Quote
Old 06-09-2007, 12:49 AM   #2732
corallyman's Avatar
Trader Rating: 99 (100%+)
Hey Dave,
When you mount the white/blue mazda the rear body mounts go on the front of the rear shock tower. When you mount the Blue MoHawk body the rear mounts go on the rear of the rear shock tower.
Steve
corallyman is offline   Reply With Quote
Old 06-09-2007, 09:26 AM   #2733
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by RCRacing.com.au View Post
Do you have a link or website i could go to so i can check them out please?
http://blogsperso.orange.fr/web/jsp/...?blogID=127906
Old 06-10-2007, 10:40 AM   #2734
SammyZ's Avatar
Trader Rating: 138 (100%+)
Guys, I was too loose in the rear on power so I layed my rear shocks in and stood up my front shocks. I got the rear ride height/droop set 4.5mm ride and 2mm total rear droop (carpet).
The When i went to stand up my fronts I can't get my ride height up to anything normal. The car is slammed like a brazilians '88 civic. I've tried every hole, the shocks are NOT binding. What happened? I mean i cannot even get my ride height gauge underneathe the front of the chassis! I've spent hours on this, anything helps!
SammyZ is offline   Reply With Quote
Old 06-10-2007, 10:46 AM   #2735
Registered User
Did you loosen your droop screws to allow more up travel so you can set the ride height?
...do you have the shocks attached to the suspension arm?
Desolas is offline   Reply With Quote
Old 06-10-2007, 10:51 AM   #2736
SammyZ's Avatar
shocks attached to arms, droop screws out!
Old 06-10-2007, 10:53 AM   #2737
rcracenut's Avatar
Trader Rating: 52 (96%+)
Check that there is enough clearance at the outside (hub) end of the camber link. If you have it on the outside hole, it could be binding against the hub.
rcracenut is offline   Reply With Quote
Old 06-10-2007, 11:07 AM   #2738
SammyZ's Avatar
nothing binding, thanks for helping though!
Old 06-10-2007, 11:16 AM   #2739
TMcKinney711's Avatar
Quick shock oil question, searched for a while but couldnt find the information I was looking for, could someone please explain the 'Shock' theories for me please or point me in the right direction.
If the track is smooth should I be running a thinner oil or a heavier?
If the track is rough should I be running a thinner oil or a heavier?
If the high bite is rough should I be running a thinner oil or a heavier?
If the low bite is rough should I be running a thinner oil or a heavier?
If its cold/hot outside should I be using thinner oil or heavier?
If I need to get more/less traction do I go thinner or heavier?
Just explain some general statements please, thank you so much in advance!
TMcKinney711 is offline   Reply With Quote
Old 06-10-2007, 11:48 AM   #2740
SammyZ's Avatar
i am so lost
Old 06-10-2007, 01:18 PM   #2741
adamge's Avatar
What thoughts do you guys have on aluminum screws for this car? The weight savings seems attractive. Are they strong enough for everywhere except the lower inner arm hubs?
-Nietzsche
Old 06-10-2007, 01:49 PM   #2742
Trader Rating: 45 (100%+)
If you post your setup I think quite a few people could help you fix your problem. As for your immediate issue, lengthen your shocks. Either unscrew the ball end on the shock shaft or use the longer ball ends that come in the T2'007 kit.
Apex is offline   Reply With Quote
Old 06-10-2007, 03:34 PM   #2743
SammyZ's Avatar
I don't use the aluminum, those things suck and are weak. I got the stainless set on ebay for $20 and its the BEST upgrade i ever did to this car.
Old 06-10-2007, 03:35 PM   #2744
SammyZ's Avatar
Just found out I had some broken suspension peices, a bent inner hinge pin, warped aluminum suspension nut and a siezed screw that secured the nut to the bulkhead and a worn out susp holder that held the hinge pin.
I kept asking why my car never breaks even though I crash every 2 seconds, then this LOL!
Old 06-10-2007, 03:36 PM   #2745
adamge's Avatar
Stainless isn't really an upgrade over standard screws.
-Nietzsche
