Old 05-31-2007, 04:26 AM   #2656
RCRacing.com.au's Avatar
Cheers Drew.
Thanks for your help mate.
If you ever come down and race here again come over and say hi please.
Steve P
LCORCCC - Life Member
100 Cubic Inch Thumping V-Twin Victory Hammer 8-Ball!
-Stuff for sale-
CRT.5 - OS .12TZ (P) All reasonable offers Considered!
RCRacing.com.au is offline   Reply With Quote
Old 05-31-2007, 06:43 AM   #2657
Default corner speed
HELP
i have t2007 eu on 36 sorex on low grip asphalt,the car is kit set up with spool in the front.
the car has no corner speed,mid corner its like the brakes are on and no the wheels arn't touching the shock bottoms
what will help????
would shorting all camber links and going high roll centre all round help.
nothing seems to increase the corner speed
ghost rider is offline   Reply With Quote
Old 05-31-2007, 06:46 AM   #2658
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by Drewdc90
I ran Xray 30wt front and back, with the T2 2006 i ran two holes open in the front and four holes open in the back. I don't change shock oil, i just use the external shock hole adjustment for damping. Try the downstops first, if that doesn't fix it stiffen the front end.
Drew.
I'm also use ASSO Oil 35W 2 holes
Old 05-31-2007, 07:29 AM   #2659
KyLayfield's Avatar
Trader Rating: 86 (99%+)
Originally Posted by ghost rider
HELP
what will help????
How much rear toe are you running? Kit is 2 degrees I think, try running 1 degree.
KyLayfield is offline   Reply With Quote
Old 05-31-2007, 08:15 AM   #2660
lbckevin's Avatar
Trader Rating: 91 (99%+)
dont forgert your radio trims....With spool, I use alot of roll. I need to hold the brakes to stop the car from rolling to carry more corner speed.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 05-31-2007, 09:57 AM   #2661
AdamD's Avatar
I would also try short camber links, front and rear and then try shorter wheel base.
AJ DiPirro
T.O.P. Racing U.S.A. / Serpent America / EA Motorsports / Team Epic / Trinity
P3 Graphics / RC3 Grafix / Adco Paving Inc / Team Butter
AdamD is offline   Reply With Quote
Old 05-31-2007, 12:03 PM   #2662
RC MARKET's Avatar
yes me too ,very good feel , have more direct steering feel & more turn
Old 06-01-2007, 01:52 PM   #2663
SlamMan's Avatar
I've got the aluminum steering hubs and I'm thinking about picking up the aluminum C hubs.
Does anyone ever have trouble with the alu C hubs getting bent?
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 06-01-2007, 02:44 PM   #2664
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
The problem with the alum c-hubs is that a slight bend might not be visible, and can cause you to chase a setup all day. Also, if you add more alum, the force in a crash will be transferred elsewhere (arm, hinge pin / mounts, servo saver, etc.), causing something else to possibly fail. You are better off just using the knuckles, they are the weakest part of the front end.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 06-01-2007, 04:02 PM   #2665
Default Servo Horn
OK,
I'm putting in my Hitec servo and I'm using an aftermarket horn because the 007 doesn't come with one compatable.
But, it looks like I need a 1/4 inch space, i.e. the servo to the mounts is a crazy gap.
Anyone else have this problem? Picture of what you did?
Maybe drill some new servo mount holes????
BeeMain is offline   Reply With Quote
Old 06-01-2007, 04:58 PM   #2666
I put a couple of 2mm shims between the servo and the post to move it out which will alow for your alloy servo horn to work.
Steve P
-Stuff for sale-
Old 06-01-2007, 05:33 PM   #2667
I was breaking the plastic C hubs, steering block, and bending the cvd. Changed to aluminum C hub and then just broke the arm. Not sure if hub is bent. The 007 seems a lot more breakable than my old t2 was for some reason. If I tap anything it seems to break. Even going down the straight and just tapping the wall a little seems to break something. Thinking about getting something else since it's so costly.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
porschejim911 is offline   Reply With Quote
Old 06-01-2007, 06:14 PM   #2668
adamge's Avatar
Jim, do you have a P-dub bumper? I put one of those on both my cars around January 1, and through the rest of the carpet season I think I broke one knuckle.
-Nietzsche
Old 06-01-2007, 07:23 PM   #2669
Sure do. Problem seems to be that when I tap the side I'm turning a little so the wheel extends out past the bumper. Usually would break turning in. But like I mentioned I broke a couple times just getting too close in the straight. Very seldom does it seem like anything that would have broken some of the cars I had in the past. With other cars I would practice and maybe 1 out of 3 times I'd break something. Now it seems I break at least twice everytime I practice. Have no problem with breaking if I really hit something but sucks when you barely tap the wall. Ah well.
Hot Bodies Cyclone
Xray T2 007
KO Helios
Duratrax ICE
Old 06-03-2007, 09:20 AM   #2670
c1 racin's Avatar
Send a message via ICQ to c1 racin Send a message via AIM to c1 racin Send a message via Yahoo to c1 racin
Originally Posted by BeeMain View Post
OK,
Here's what I did.....
c1 racin is offline   Reply With Quote
