Old 04-30-2007, 06:55 PM   #2431
SlamMan's Avatar
Originally Posted by adamge
Christian, that technique does not check for tweak. Tweak means the car has uneven weight distribution when at ride height. You need a system that checks the weight on each wheel at ride height to check for tweak (such as four scales, or balance beams).
Werd. You need a tool like the MIP tweak station or 4 scales to check the corner weight (known as tweak).
If you check the corner weight and your left and right droop screws are slightly different or your surface isn't level your adjustments will be off.
The above method should be used only to check chassis up travel.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 05-01-2007, 01:43 PM   #2432
turd ferguson's Avatar
Send a message via AIM to turd ferguson
Originally Posted by bigb11
Has anybody installed the EU Conversion on their T2?
Yes
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 05-01-2007, 03:07 PM   #2433
ford_racing's Avatar
Send a message via MSN to ford_racing
Guys
I'm about to buy my first Xray and Belt driven car.
I have a couple of quick questions about the US edition 007.
Firstly largest 48dp Spur that will fit, I have heard an 87 but am not too sure.
Secondly what size hex wrenches would I need, I'm thinking 1.5, 2, 2.5mm
Thirdly spares or optional parts, here is what I have come up with so far:
Battery brace
Shock ends
Rear hubs
Rear shock tower
6 deg castor
Front Hubs
Drive shaft caps (Have not found a part number, if you could help me out that would be great)
Anything else I should know before purchasing the kit?
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 05-01-2007, 03:20 PM   #2434
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
87 is the largest, but if you run outdoor it might be risky.
1.5, 2, 2.5 are the tools you need
Battery brace you don;t really need one
Shock ends only for backup reasons
Rear hubs only for backup reasons
Rear shock tower only for backup reasons
6 deg castor
Front Hubs only for backup reasons
Drive shaft caps 305240 definately need some but fortunately they are stronger now. I used to change them every 3 batteries now it's every 15
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is offline   Reply With Quote
Old 05-01-2007, 03:21 PM   #2435
Shop Owner
nnick's Avatar
87 is the largest, you might be able to use 90 if you run indoor
6 deg castor
Nikolakopoulos Nick
RC RING
Enjoy RCing....
R/C Tech #82
IRT #123
Old 05-01-2007, 04:30 PM   #2436
Thanks for the quick reply
ARC R11
Yokomo YRF001
AE B5m
Old 05-01-2007, 07:21 PM   #2437
Captain Harlock's Avatar
Guys,
will the T2's normal bearing size fit in the aluminum steering blocks or am I obliged to use the ones that come with the aluminum blocks only?
Captain Harlock is offline   Reply With Quote
Old 05-01-2007, 07:30 PM   #2438
theisgroup's Avatar
Originally Posted by Captain Harlock
Guys,
not for the xray ones. the team tamale ones use the same bearings
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-01-2007, 07:58 PM   #2439
GTRtuned's Avatar
Guys,
The T2 uses 5X10 bearings all around. The aluminum X-ray hubs use 5X9 bearings which are the same hub bearings the Tamiya 415 MS uses.
Walter Cosico
RC America/ X-ray/ SRG www.superradgraphics.com/ Hudy/ R1wurks/ TeamBocaBearings
GTRtuned is offline   Reply With Quote
Old 05-01-2007, 09:43 PM   #2440
how many people run sway bars on there t2/007 im trying to decide weather ro but sway bars or extra spare parts
C_Suzuki is offline   Reply With Quote
Old 05-01-2007, 10:46 PM   #2441
SlamMan's Avatar
Originally Posted by ford_racing
Guys
Battery brace
Shock ends
Rear hubs
Rear shock tower
6 deg castor
Front Hubs
I like to keep C hubs, steering hubs, front arms, rear hubs, steering bushings, ball joints, unidirectional ball joints, lower suspension holders, shock ends, and shock bodies on hand. In about that order of importance too.
Plenty of screws especially 16 and 18 mm button heads and replacement belts are nice. Skip the rear shock tower.
Michael H
OnRoadColorado.com
Old 05-01-2007, 10:50 PM   #2442
SlamMan's Avatar
Sway bars seem more common on rubber tire setups so if that's what you run they're a nice tuning option. Sway bars don't do you much good if you don't have spares to fix your car though.
Michael H
OnRoadColorado.com
Old 05-06-2007, 12:50 AM   #2443
lbckevin's Avatar
Trader Rating: 91 (99%+)
Whats the hot setup for the upcoming Reedy Race in 19t ?
EU or US version and what other details....?
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 05-06-2007, 01:01 AM   #2444
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Guys
Battery brace
Shock ends
Rear hubs
Rear shock tower
6 deg castor
Front Hubs
Yes 87T & also these spare parts !
Sus. pin , Bearing , belt & upper bulkhead .
But i'm like order more 1 kit for spare .
Old 05-06-2007, 11:47 AM   #2445
Guess i will have to start posting in this thread seeing as i have just brought a used T2 007 . Carn't wait to get my hands on it and see how things have advanced compared to my 3 year old Tamiya 415.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
