Old 04-27-2007, 04:51 PM   #2401
Chris08527's Avatar
Trader Rating: 16 (100%+)
Originally Posted by B18C Turbo
i need help, how do i lower my rear ride height if my collars are topped out
B
try the team tamale shock retainers for the T2
http://www.teamtamale.com/
this should give you about 2 more mm of travel
hope that helps
"Hello How 'bout that ride in? I guess thats why they call it Sin City." Alan Garner~"I play the drums, I'm good as hell" Richie Rich
Chris08527 is offline   Reply With Quote
Old 04-27-2007, 05:11 PM   #2402
Cristian Silva's Avatar
Trader Rating: 11 (100%+)
Originally Posted by adamge
back the droop screws out to get tons of droop (don't want droop screws messing with the ride height setting).
set ride height. push car down to surface, let go, measure under back end of chassis and under side of chassis just behind front arms. Use shock collars to set ride height. left and right shock collars should be very close. If one side of chassis is lower than other, you can make small side-to-side collar adjustment to level it.
set rear droop. lift rear of car by shock tower until one wheel just lifts from the surface. Measure the chassis' height at rear end. Difference between this height and ride height is droop. Turn in droop screws to lessen droop. Keep adjusting screws until both tires pick up exactly at the right chassis height (in this case, 5.5mm).
set front droop. same procedure. lift on front shock tower, watch or feel for one tire lifting off surface, then measure chassis height (just behind front arms). Again, adjust screws so both tires lift at 5.5mm.
This is a way I adjust the cars tweak by lifting the front and rear and seeing if both tires lift up at the same time, though I adjust with the spring collar, should it be done this way or with downstop screws?
Team Xray Australia - HEI International ~ www.hobbyexpress.com.au - www.smaracing.org
Cristian Silva is offline   Reply With Quote
Old 04-27-2007, 05:15 PM   #2403
RIEMON SPEED WORKS
XRAY T2/T2'007 AXLE SHAFT Alum. ( A7075 ) Lightweight Champagne Gold
Has anybody used these axle shafts, what are they like?
Old 04-27-2007, 05:16 PM   #2404
Default Setup
Have a question for the guys who run XRay cars. I have a T2.007 US version and I can NOT afford to buy the rubber tire chasise and top deck. Like to know if anyone has a rubber tire setup and recommendation for tires to use on the US car and how to set the car up to run rubber? At least for now til I can afford the chasise and top deck. It would be appreciated.
Cookie
hotcar is offline   Reply With Quote
Old 04-27-2007, 05:48 PM   #2405
ottoman's Avatar
R/C Tech Charter Subscriber
Trader Rating: 13 (100%+)
Well, I mean its hard to believe that all the electrics will make the car slam 1.5mm, let alone slam it to bottom out as you claim. Are you positive this will happen? I have loaded the chassis with some weight to give the effect but no luck!
Update: i added a servo, motor and Rx to the chassis still need a Li-po pack and ESC. Without the battery&ESC I measure 5mm ride height in the rear and that is as LOW as it gets. Im stuck.
Did you use the proper lower shock ends? There are short and long ones in the kit. You should use the short ones. I believe the long ones are on the shock parts tree and the right (short) ones are separate.
ottoman is offline   Reply With Quote
Old 04-27-2007, 06:11 PM   #2406
Big B's Avatar
Originally Posted by Cristian Silva
RIEMON SPEED WORKS
The ones that come with the 007 are great, why do you want different ones?
Big B is offline   Reply With Quote
Old 04-27-2007, 08:04 PM   #2407
protc3's Avatar
RIEMON SPEED WORKS
Riemon make some really nice stuff.i ran the rear and front axles in 1/12th and they are really awesome.they are expensive but worth it in quality.the machine work is top notch as are the materials.well worth it.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-27-2007, 08:25 PM   #2408
SammyZ's Avatar
Trader Rating: 138 (100%+)
Different shock ends huh? Well I will take a look inside my kit tonight to see if there are different lengths there and I will also post up my shock length tonight when I get home.
Please let me know what your total length is so I can compare!
SammyZ is offline   Reply With Quote
Old 04-27-2007, 08:32 PM   #2409
Viat's Avatar
Trader Rating: 24 (100%+)
B18C Turbo,
what was the heaviest total weight of the 007 with all the thing you tried to weigh it down?
A body weights about 100g and the legal weight for a race is 1525g
hotcar,
I have T2 with custom upper deck - which are like the US 007 bur with spider at the end of front one.
In your place I would only change the lower deck when you get some money for it. That way you have more options with front upper deck.
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 04-27-2007, 10:14 PM   #2410
SammyZ's Avatar
my total freelength of the rear shocks are 65mm each
Old 04-28-2007, 10:24 AM   #2411
SammyZ's Avatar
Oh and I also have a T2 '007 custom team pickles chassis 3.1mm super stiff that is a beautiful woven carbon fiber peice. It is an exact replica of the 2007 chassis and will be perfect for your T2 conversion!
Old 04-28-2007, 11:21 PM   #2412
Trader Rating: 2 (80%+)
I m having issues gettong my 007 us crpet spec to handle right.
First i know Its my setup I m just at a loss. I am running double pink / orane in front and double pink in rear for tires. I have chnged from pink front springs to blue and still my car hs a hrd time turning. I tried reversing the tires front to back nd tht caused me to spin out. I hve even bcked out all the spring tension on the fron springs and used various adjustment in the rer springs but it seems still to have hrd time turning. ny suggestions would be appreciated. My controller is a M11 and i hve everything set to 100%
gunlocators is offline   Reply With Quote
Old 04-29-2007, 12:40 AM   #2413
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
what seen to be the issue ,,is the car pushing into the corner or just not enough
steering, if the car is pushing into the corner front suspention is to hard or not enough droop, if the car is going into the corners to hard and you are loosing time because not enough roll stiffen up the suspention a little bit by either changing the springs or moving the shock position on the shock tower
SERPENT S811 AND S811T, FUTABA 4PKS , viper rc solutions
OS SPEED WORLDS EDITION 21 , OS 2060 PIPE
BYRON %30 FUEL , PROTEK 2300 LIPO RX PACK
SAVOX SERVOS 1268MG HV , 1267MG HV
turboxrayt1fk05 is offline   Reply With Quote
Old 04-29-2007, 12:51 AM   #2414
It seems to not be turning egnough if you put my son tc4 on same transmitter same settings and my xray and just turn a sharp circl his turns much more tighter. Mine darn near needs the entire with of the straight away to make a turn where his takes about 1/3 of it. I do not understand why it would not have a tighter turn radius. I think this is whats killing me in the corners that are tighter cause even if I am going really slow in the turns it seems I do not have egnough steering. I am talking just practicing running the course less than half throttle it seem It cannot make sharp turns. Now if i go really fast in a sharp turn I can slide the back end and clear the turn but doing that everytime is a bit difficult for my drive style
Old 04-29-2007, 09:23 AM   #2415
Viat's Avatar
gunlocators,
Does your steering blocks turn either way (L or R) enough to touch the caster blocks?
