Old 04-24-2007, 03:21 PM   #2371
techically, the current top deck is two pieces. Maybe that's what his is
DOTMAN is offline   Reply With Quote
Old 04-24-2007, 03:51 PM   #2372
nashrcracer's Avatar
R/C Tech Charter Subscriber
Originally Posted by EAMotorsports
Associated 50 wt.
EA
pimping your new sponsor already aren't you....
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 04-24-2007, 06:57 PM   #2373
Big B's Avatar
All the T2's have a two peice topdeck
Big B is offline   Reply With Quote
Old 04-25-2007, 09:25 AM   #2374
Yes, it is true somewhat but when I first read his post I was thinking about something like this which Xray developed for the original T1:
http://www.teamxray.com/teamxray/pro...e%20Top%20Deck
cvt01 is offline   Reply With Quote
Old 04-25-2007, 10:11 AM   #2375
Big B's Avatar
oh, I see. I was wondering is the new BMI one a multiflex topdeck or is it like the new 2mm topdeck?
Old 04-25-2007, 07:27 PM   #2376
protc3's Avatar
Trader Rating: 13 (100%+)
it is going to be a front and rear top deck.back in the days of the FOC car i messed with variable flex and found that it worked well until an impact even being that i did not find benefit of the full flexing positions.being that most of us do hit stuff,i scrapped the plan.i have found over the years that having flex in the car for lower bite conditions is good but too much causes problems.i came to a fixed rate and amount of flex and have stuck with it ever since.i found a sweet spot for flex before it started to bind the car up and slow it down.excessive flex in these cars will make it easy to drive but not carry corner speed.in areas such as indoor asphalt where the bite is very high,a stiffer chassis will be needed such as a carpet chassis because you will not be relying on mechanical traction of the chassis.this is not bashing xray with the multi flex.i just have found no benefits of having that much adjustment of a feature that really should not be depended upon.a little flex is good,excessive flex will tweak the car very easily and throw a monkey wrench into the setup.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-26-2007, 12:55 AM   #2377
Cristian Silva's Avatar
Trader Rating: 11 (100%+)
Their are 2 positions for the servo to be mounted, I have a KO Propo, which position is best?
Whats the difference? is this for weight set up or different size servos?
Team Xray Australia - HEI International ~ www.hobbyexpress.com.au - www.smaracing.org
Cristian Silva is offline   Reply With Quote
Old 04-26-2007, 08:19 AM   #2378
Gravity RC
Cristian: I think that it is for different size servos.
Jason: In my Opinion in the us we rarely run on very low traction serfaces, but when their is very low grip that is where people will find that soft setting to be good. at almost every us race we will run the med stiffness(even for what we think low grip is) which is accually high grip for the rest of the world.
this for rubber tire racing.
Paul L is offline   Reply With Quote
Old 04-26-2007, 10:19 AM   #2379
protc3's Avatar
thats true paul.on our low grip tracks we still use some sort of sugar water and such.maybe thats why i never could get away with real flexi setups.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-26-2007, 10:42 AM   #2380
Viat's Avatar
Trader Rating: 24 (100%+)
Thumbs up
I swiched to TRF Blue shocks.
Hobby Place // G's R/C Raceway www.gsrc.us Shippensburg PA 17257 (717)530 5200 // The Track Raceway
Spektrum DX7 // SAB Goblin 700
DX3R PRO // Mugen MBX6T ECO // SCTE 2.0 // DESC410 V2
FOR SALE: // for SALE
Viat is offline   Reply With Quote
Old 04-26-2007, 12:26 PM   #2381
So Jason, where are those pictures you promised???
Old 04-26-2007, 04:05 PM   #2382
protc3's Avatar
i fell a little behind this week with some of my work.i should have them running tommorow.i will shoot a pic of the 1st one off the machine.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-26-2007, 06:19 PM   #2383
Originally Posted by RC MARKET
RIEMON SPEED WORKS
XRAY T2/T2'007 AXLE SHAFT Alum. ( A7075 ) Lightweight Champagne Gold
Has anybody used these axle shafts, what are they like?
Old 04-26-2007, 11:01 PM   #2384
SammyZ's Avatar
Trader Rating: 138 (100%+)
Hi!
I just got my T2 '007 and I im having a lot of difficulty setting it up for the first time. I have a droop/ride height gauge but NO support blocks, a setup board, and tweak station along with a camber gauge even a digital mic.
Its a carpet spec and Im looking to run 4mm ride heigh front & rear with 1.5mm of droop above ride height for the front and rear.
Do I need to ditch my droop/ride height gauge and buy a setup with blocks and a straight droop only gauge? My current droop gauge has 1 block built in but how do I keep the opposite end of the car up when measuring the downstops.
Im trying to set the car up per the T2 setup book step by step in order. My biggest concern is: The first step-measuring downstops! Your setting the downstops per what you want your ride height to be set?! is that right?!
Then How do I accurately measure droop?!
SammyZ is offline   Reply With Quote
Old 04-26-2007, 11:32 PM   #2385
adamge's Avatar
b18, rubber tires or foam?
-Nietzsche
