Old 04-05-2007, 08:19 AM   #2251
teamgp's Avatar
Originally Posted by gonzo416
so if i add a spacer should i also raise the quick roll center position?(out-top/in-top)
That would defeat the purpose of adding the spacer on the outside. The desired effect on roll center and camber gain come from the change in angle of the upper link in relation to the lower arm.
For a better understanding, please take a look at pages 24-27 of the XRAY T2 Set-up Book.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 04-05-2007, 08:38 AM   #2252
TMcKinney711's Avatar
Does the T2 007 front and rear bulk heads fit on a regular sedan T2 chassis?
TMcKinney711 is offline   Reply With Quote
Old 04-05-2007, 08:44 AM   #2253
Team Speedy's Avatar
Trader Rating: 42 (100%+)
Post
Wrong thread..
Team Speedy is offline   Reply With Quote
Old 04-05-2007, 08:56 AM   #2254
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
No, the 007 bulkheads will not work with the orginal T2 chassis. The T2 used one piece bulkheads, which incorporated the layshaft & motor mount, where the 007 bulkheads are 2 pieces.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 04-05-2007, 08:59 AM   #2255
|<R1Z |>'s Avatar
Send a message via AIM to |<R1Z |>
007 specs
T2 specs
lol. doh!
signature'd
|<R1Z |> is offline   Reply With Quote
Old 04-05-2007, 09:02 AM   #2256
Originally Posted by Kris Preisinger
lol. doh!
Yeah, I misread the orignal post, shoot me I need some sleep
Retired from RC....
Old 04-05-2007, 09:29 AM   #2257
Nexus Racing's Avatar
R/C Tech Elite Subscriber
Just to be clear:
The T2 main chassis and T2'007 main chassis are interchangeable...same mounting holes even though the bulkheads are so different.
The bulkheads from each car will fit on the other car, but will obviously require different top decks, etc.
TMcKinney711, if your goal is to trade the main chassis between the two cars, that will work fine. If you are wanting to trade only the bulkheads, that will not work in itself because you will need the T2'007 servo saver & upper decks.
AFAIK, the std T2 main chassis has been discontinued and replaced by the '007 EU edition chassis. Xray could have made the EU conversion set include all the essentials minus the main chassis since the two chassis are so similar.
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 04-05-2007, 09:43 AM   #2258
teamgp's Avatar
Originally Posted by Nexus Racing
Just to be clear:
Correctamundo...
At one point, I had tried my original T2 lower chassis with all the rest of the 007 parts and it worked great for more flex and grip.
Guy Hood
Old 04-05-2007, 10:07 AM   #2259
Well I just got such a good deal on the US version that I wasnt about to pass it up, but im not going to be running it on carpet, ill be running it on concrete. So I was going to try and pick me up an spare T2 old style chassis, and use all of my 007 stuff. So basicly if I get an old style T2 chassis and use my 007 parts ill need to get what else? And EU topdeck maybe? Becuase I know the old T2 top deck wont fit on the new bulkhead's correct?
Ill have old T2 chassis, 007 parts, what type of topdeck can i use?
One last thing, im so lost with the whole one way, solid and all of that stuff. I was under the impression that the US kit came with a diff that would allow you do have a oneway, solid, or solid oneway but the US kit only comes with ball differentials correct? These can or can not be made into different diff's?
Thanks guys!
Old 04-05-2007, 10:14 AM   #2260
Mal
Registered User
You really don't need anything else. Run the carpet spec top deck and see how it handles.
I did the exact same thing. I bought a carpet spec 007 but switched the lower chassis with my old T2 chassis.
Mal is offline   Reply With Quote
Old 04-05-2007, 10:16 AM   #2261
OK, the US-edition top deck will actually work OK on rubber without the stiffening posts installed.
If you wanted to convert to full rubber-spec, the only differences then would be the 301178 rubber-spec upper deck and 305102 the multi-diff.
NEXUSRACING.com
Old 04-05-2007, 10:18 AM   #2262
Mal
Registered User
Thanks guys!
You can't make a diff into a one-way or the spool. You need the multi-diff for that....
Old 04-05-2007, 10:20 AM   #2263
Do they run the multi diff in the front?
Old 04-05-2007, 10:26 AM   #2264
I know this one for sure Yes, run the multi diff in the front.
Retired from RC....
Old 04-05-2007, 10:30 AM   #2265
RC MARKET's Avatar
Trader Rating: 12 (100%+)
Originally Posted by teamgp
I replied to your PM.
Thanks!
