Old 04-04-2007, 04:13 PM   #2236
HarshGuy's Avatar
Originally Posted by MACH55
Anyone have a setup sheet for Sacramento Speedworld????
Thanks in advance
I just answered your PM, I've got a couple at gearchart.com that have worked pretty good, use the latest one.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 04-04-2007, 05:42 PM   #2237
gonzo416's Avatar
Trader Rating: 39 (98%+)
so if i add a spacer should i also raise the quick roll center position?(out-top/in-top)
gonzo416 is offline   Reply With Quote
Old 04-04-2007, 07:41 PM   #2238
TMcKinney711's Avatar
Im figuring the rollout for my 007, are most rubber tires 24mm?
TMcKinney711 is offline   Reply With Quote
Old 04-04-2007, 07:52 PM   #2239
Jack Smash's Avatar
Trader Rating: 29 (100%+)
most are between 62mm and 64mm.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-04-2007, 08:25 PM   #2240
Ow ok thank you mate!
Old 04-04-2007, 08:29 PM   #2241
John Tag's Avatar
Trader Rating: 42 (100%+)
Roll out for stock rubber tires just do gear ratio as all rubber tires are same size,within specs.. Gear a CO27 between 6.20 to 6.40 for most all tracks..
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 04-04-2007, 09:04 PM   #2242
When you say that, do i need to get my ratio just by Spur/Pinion or get that then times it by 1.7?
Old 04-04-2007, 09:19 PM   #2243
HRCRACER123's Avatar
Trader Rating: 33 (100%+)
Hey guys with the initial purchase of a T2 007 what are the must have hop-ups?
I can only think of a P-Dub bumper.
Also is there anthing in the build process to be carefull doing or look out for. I think I read somewhere that the bearings were failing. Is this true? Thanks..
HRCRACER123 is offline   Reply With Quote
Old 04-04-2007, 09:43 PM   #2244
Big B's Avatar
I use http://www.gearchart.com/ it is very easy to use, hit the gearchart creator at the top and fill in the blanks
Big B is offline   Reply With Quote
Old 04-05-2007, 06:05 AM   #2245
ChrisP's Avatar
You should check out the T1/T2 area of the forums at www.teamxray.com for build tips and insights
ChrisP is offline   Reply With Quote
Old 04-05-2007, 06:18 AM   #2246
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Originally Posted by Brian McGreevy
Wrong. Completely backwards.
My bad, I had it right the first time
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 04-05-2007, 06:25 AM   #2247
Trader Rating: 52 (100%+)
I thought if you use final drive and a 116 spur then whatever pinion you use that is your roll out.
example: a 30 pinion is a 30mm roll out
and a 29 pinion is a 29mm roll out
and that is only with rubber tires
Mo
Mo Denton is offline   Reply With Quote
Old 04-05-2007, 07:07 AM   #2248
Mo
The math works out , thanks Mo, now I can leave the calculator at home for the summer.
Retired from RC....
Old 04-05-2007, 07:20 AM   #2249
NOOB-SMOKE's Avatar
Default deck
Has anyone seen the 2mm top deck available anywhere yet.
CUSTOM MODEL CARS AUSTRALIA,TEAM XRAY,HUDY,FERAL,SOREX,UFRA,
NOOB-SMOKE is offline   Reply With Quote
Old 04-05-2007, 08:13 AM   #2250
teamgp's Avatar
Originally Posted by RC MARKET
Hi Team GP
If change Front Suspension arm to low roll center , Rear is STD roll center ,
will how ?
Thanks!
I replied to your PM.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
