Old 02-28-2007, 06:22 AM   #2011
Trader Rating: 31 (100%+)
I will have to play with that this weekend TeamGP. So by the sounds of it, it is not the steering throw so much as it is the ackerman causing the wheel hop. Someday when you at at the track, I need for you to explain how ackerman effects the car. That is one area I never really dug into or understood very well. In oval, there never really was a need for it.
Jamie Hanson is offline   Reply With Quote
Old 02-28-2007, 06:45 AM   #2012
adamge's Avatar
I'm seeing 20-22deg on the inside wheel, and about 3deg less on the outside. This is for a small and tight carpet track. On a large and flowing carpet track I had less than this.
-Nietzsche
Old 02-28-2007, 07:29 AM   #2013
rmargiotta's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rmargiotta
Originally Posted by Dane
What's the point in the locking hex drives? Convenience only? Do they add to any performance?
You ever work on a car where the hexes stay inside the wheels?! I have and wanted to throw it across the room when i took the wheels off....
Sponsors:
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 02-28-2007, 07:42 AM   #2014
Boosta's Avatar
Ditto on that one i'll be getting my gauges out as soon as i get in from work and see what the effects are if i'm understanding it right you should be able to gain corner speed by reducing the angle difference between the two wheels and limiting the scrub on the inside wheel
thanks teamgp
Boosta is offline   Reply With Quote
Old 02-28-2007, 08:22 AM   #2015
teamgp's Avatar
Originally Posted by NOOB-SMOKE
I was just looking at how you set up your steering and what you say is at full lock the inside wheel should not go over 16.5d when at full lock.
So i went and tried mine to see what mine is and at full lock, mine is 27d on the inside and 18d on the outside.
To acheive your 16.5d on the inside tyre i had to turn down the dual rate from 100% down to 65% now if i did that, to me you are NEVER gunna have enough steering / steering lock.Am i setting it up wrong or do you guys always turn the steering down that much.
Also my xray is kit set up in regaurds to ackerman and i set it up so 100% steering throw just touches the carster blocks and the 27d inside tyre and 18d on the outside is what it reads at kit.
What are everybodies thoughts.
cheers.
Some drivers, especially the old school ones that started before all this techno handheld gadgetry, have their EPA/dual rate turned up way high. However, they never really use the full steering throw, unless they're facing a wall and need to turn around within 2 feet.
With rubber tires on asphalt, I have used upwards of 22d/17d in the past and the car drove ok. But when I turned it down to 16.5d/14.0d and changed the setup to gain steering, corner speed went up and lap times went down.
Some setups will work with a lot of steering throw. But some cars dogbones, like the T2's, won't allow a lot without excessive chatter.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 02-28-2007, 08:25 AM   #2016
teamgp's Avatar
Originally Posted by corradopsi
TeamGP, can i use the ackerman settings to reduce inside steering angles and still retain outside angle so i still have plenty of steering for tight sections of track? id assume moving the quick ackerman horn on the servo saver forward would give the desired effect.
Yep. Move the servo saver forward and/or the arm positions backward to reduce ackermann effect and then reset your front toe-out as it will change.
Guy Hood
Old 02-28-2007, 08:26 AM   #2017
teamgp's Avatar
Me too.
Guy Hood
Old 02-28-2007, 08:26 AM   #2018
teamgp's Avatar
thanks teamgp
Yepper.
Guy Hood
Old 02-28-2007, 11:10 AM   #2019
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
No no no... it's when you take the wheel off, the hex goes with it, AND the drive pin falls out into your carpet never to be found again! Thats when I start throwing stuff hahaha.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-28-2007, 12:37 PM   #2020
teamgp's Avatar
-Korey
And a shag carpet to boot!
Guy Hood
Old 02-28-2007, 02:34 PM   #2021
gonzo416's Avatar
Trader Rating: 39 (98%+)
the fastest driver at my lhs puts his car in the tightest lane of the track and sets his dual rate to be able to make a full circle in it. i'm thinking he does this because if he hits the board or is hit in the tightest spot in the track he will be able to turn around, but what i get from what you are saying is that he must be settting his car according to that steering. please clarify
since it looks like you really know what you are talking about i have another question if you don't mind.
1-why is it with the 2 stage wraps double pink&orange in front and double pink in the rear, the front tires are wearing at least 1.5 millimeters more than the rear. this is using:
ride height- 4.5mm fr & rr
camber- 1.5degrees fr & rr
caster- 4degrees fr
toe- .5 fr, 2degrees rr
droop- .5mm fr, 1mm rr (both over ride heght)
the rest of the setup is stock.
this is for foam on carpet using a 19T Checkpoint
gonzo416 is offline   Reply With Quote
Old 02-28-2007, 03:00 PM   #2022
Send a message via AIM to Bobby Flack
caster- 4degrees fr
It sounds like to me that your car is simply pushing. Generally when a car is pushing it wears the fronts more, and when a car is loose it will wear the rears more. Post the rest of you setup and maybe it is something with that. From what you did post I would say 6deg castor blocks could help.. but id like to see the rest of your setup.
Bobby Flack is offline   Reply With Quote
Old 02-28-2007, 03:44 PM   #2023
C_O_jones's Avatar
Trader Rating: 11 (100%+)
Oh, it's a RED shag carpet in Korey's room!
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 02-28-2007, 04:50 PM   #2024
NOOB-SMOKE's Avatar
When you steering is set at 16.5d/14.0d is that even with a spool ?
CUSTOM MODEL CARS AUSTRALIA,TEAM XRAY,HUDY,FERAL,SOREX,UFRA,
NOOB-SMOKE is offline   Reply With Quote
Old 02-28-2007, 06:01 PM   #2025
gonzo416's Avatar
the rest of the setup is the same as the foam set-up sheet that comes with the kit except that i'm using fixed 3 holes in shock pistons
