Xray T2'007
Old 02-05-2007, 02:48 PM
  #1831
thanks I've found some cheap ones in HK, price is about the same as the link you posted.
cvt01 is offline
Old 02-05-2007, 02:57 PM
  #1832
Trader Rating: 27 (100%+)
Default ? ? ? ?
Got a 007 us spec, works awesome, but if I wanted to run rubbers on the rug will the extra stiffness hurt performance. Any one have a set up for the us car, but for rubbers?
convikt is offline
Old 02-05-2007, 04:34 PM
  #1833
BSchorr's Avatar
Trader Rating: 92 (100%+)
I keep tweeking the upright screws in teh rear hubs! I do have teh set screw in the hole not being used, but it always tweeks and my car turns retarded one way, think i should get the Xray or Team Tamale rear hubs then!?
BSchorr is offline
Old 02-05-2007, 04:37 PM
  #1834
TeamButter's Avatar
BSchorr- If you are running foams on carpet, then the aluminum hubs might be best. They are inherently stiffer than the plastic ones and through less flex will give you less traction or take some away.
Now, when you say tweak do you mean the camber link pops off or the hubs are breaking??
TeamButter is offline
Old 02-05-2007, 04:54 PM
  #1835
Chris08527's Avatar
Trader Rating: 16 (100%+)
i put the x-ray alum hubs on . . . solved all my probs
Chris08527 is offline
Old 02-05-2007, 05:01 PM
  #1836
I ran a US Spec car for rubber for awhile. For me it was faster then my 007 Euro. I ran a one way in the front and a rendition of the Paul Lemieux setup from the IIC race.
R/C Anonymous is offline
Old 02-05-2007, 05:23 PM
  #1837
MikeXray's Avatar
Trader Rating: 73 (100%+)
Since switching to the tamale alum hubs my next weak point is the quick roll center mount, I broke one shock tower, and since put a flat washer on the screw. I can still bend them though and it alters camber and causes the car to pull, anyone have any other tricks? (yeah beside not hitting things )
MikeXray is offline
Old 02-05-2007, 05:36 PM
  #1838
adamge's Avatar
I've gone from the normal rear outer camber link screws to screws that are 2mm longer. I'm using 3mm of shims there, so the longer screws are to get the screw depth closer to the maximum. Prior to this I was having problems with border tapping causing the screw to loosen up the plastic hub. I also went with 2mm longer screws in the front upper camber link, and use a shim on top of the ball if the screw touches the axle.
adamge is offline
Old 02-05-2007, 07:24 PM
  #1839
TeamButter's Avatar
Well you covered the number one thing!! (not hitting)
I would use a large concave washer and as adamge posted try a longer screw. It seems that the longer screw "catches" more thread and makes it stronger.
As will happen when you go to a stronger material (aluminum in this case), the forces are transferred to the next weakest point (Tower or link)
Old 02-05-2007, 07:28 PM
  #1840
protc3's Avatar
Trader Rating: 13 (100%+)
or to the absolute weakest link,YOU what up sucka.what day you shooting up here?
protc3 is offline
Old 02-05-2007, 07:29 PM
  #1841
TeamButter's Avatar
unfortunately Saturday. A-lo is picking me up on the way up. This is killing me!!! My 5 year streak snapped!!
Old 02-05-2007, 07:34 PM
  #1842
protc3's Avatar
im just going to try to redeem myself from last year after this i will just be going to help the team
protc3 is offline
Old 02-06-2007, 04:24 AM
  #1843
How well do you think it would work w/ a front diff?
convikt is offline
Old 02-06-2007, 05:22 AM
  #1844
sukh's Avatar
Default titanium screws
does anyone know if the mtx4 uses almost the same screws as the 007, the reason i ask is because i wanted to change to titanium screws and i can get my hands on the mtx4 screw set. thanks!
sukh is offline
Old 02-06-2007, 07:05 AM
  #1845
When I first got it I ran it with the diff. I gained a consistent .2 a lap from the front diff to the front one-way. (two totally different setups)
Contact Us Archive Advertising Cookie Policy Terms of Service
