Xray T2'007
Old 02-01-2007, 08:32 AM
  #1771
How are we turning the spur? If I get a good pull on the belt it will spin maybe one rotation but turning the spur itself it goes maybe a 1/4 turn. Is that about right? This is my first belt car I have built. All my others were bought used/assembled. Everything was smooth as butter before the belts went on.
Originally Posted by TeamButter
Didn't read the no wheels part...there is almost no rotating mass to keep the spur turning with no wheels.... Nothing wrong with your car then
MikeXray-the spur should do at least one revolution....check the drive train and wheels for binding on the arms or shock ends. You can also take one seal out of the bearings and make sure they are towards the inside of the car. I run my car outdoors and still run the same set of bearings.
Hope it helps..
porschejim911 is offline
Old 02-01-2007, 09:25 AM
  #1772
syndr0me's Avatar
Trader Rating: 32 (100%+)
I heard this car is the bomb in Boston.
syndr0me is offline
Old 02-01-2007, 10:04 AM
  #1773
SlamMan's Avatar
LMAO
SlamMan is offline
Old 02-01-2007, 10:26 AM
  #1774
Moderator
StephenSobottka's Avatar
Aqua Teen Hunger Force...ASSEMBLE! hahaha, favorite show on the planet
StephenSobottka is offline
Old 02-01-2007, 10:51 AM
  #1775
TeamButter's Avatar
LOL!! Thats what I like to hear!! Smooth as Butter!!!
The ability to spin the drivetrain via the spur or the belts has no bearing on how it will perform once the belts are broken in (couple of runs), and once you have some rotating mass to allow the drivetrain to continue spinning(Tires)
I can assure you that the Xray's drivetrain is one of the smoothest and free spinning you will find.
As for whether or not YOUR car is ok... It sounds fine... Don't guide yourself by the ability to turn the spur....
Butter
TeamButter is offline
Old 02-01-2007, 11:23 AM
  #1776
Thanks. That was pretty much what I was thinking but since the question came up I thought I'd ask. Sweet car to build.
Butter
Old 02-01-2007, 12:01 PM
  #1777
TeamButter's Avatar
Anytime...good luck!
Old 02-01-2007, 08:40 PM
  #1778
Still Bill's Avatar
Trader Rating: 12 (100%+)
Originally Posted by Jack Smash
Corner of Center and Virgina, just south of downtown. I know it's 12pm to 10pm during the week, I don't think weekend times have been set yet (probably depends on what they come up with for a race schedule). Indoor carpet, wider but shorter than Stockton, same rules as Stockton.
Jack,
Any pictures?
I can end up in Reno occasionally.
Bill
Still Bill is offline
Old 02-02-2007, 12:16 AM
  #1779
Jack Smash's Avatar
Trader Rating: 33 (100%+)
www.highperformancehobby.com
Track is like billiard table. I ran my 1/12 at 3.5mm, no traction compound marks on the chassis. The front of the body was sitting at 2mm and it was barely tapping the track at the end of the straight. It's a little tight for TC with the layout right now but it's dialed for 1/12th.
Jack Smash is offline
Old 02-02-2007, 07:18 AM
  #1780
STLNLST's Avatar
Trader Rating: 26 (100%+)
Too tight for TC then I can't come visit you
STLNLST is offline
Old 02-02-2007, 08:28 AM
  #1781
Jack Smash's Avatar
It's not too tight, it's a little tight. You just gotta put your driving shoes on.
Old 02-02-2007, 08:52 AM
  #1782
MikeXray's Avatar
Trader Rating: 73 (100%+)
Thats about what mine does, it feels like the spur doesn't have enough mass to keep the spur going. Butters post though seems to be that its ok, I was just curious.
MikeXray is offline
Old 02-02-2007, 07:54 PM
  #1783
HarshGuy's Avatar
Does anyone have any idea why the aluminum shock bodies don't show as compatible with the T2/007 on the parts cross reference sheet on xray's site? ...they appear to be same size as teh plastic ones?
HarshGuy is offline
Old 02-02-2007, 08:01 PM
  #1784
Team EAM
Trader Rating: 79 (100%+)
They are longer than the T2 shock bodies.
EA
EAMotorsports is offline
Old 02-02-2007, 08:07 PM
  #1785
John Tag's Avatar
Trader Rating: 42 (100%+)
EA get back to Epcot.....
John Tag is offline
