Old 01-29-2007, 04:13 PM   #1711
Default X-Ray T2 '007 (Parts Quality Fit/Finish)
Hi, just wondering whether anyone that already has a '007 kit has exp any flaws in parts quality fit/finish. Reason I ask is I just read a review for the '007 US Spec edition kit in the current issue of Xtreme RC Cars magazine, and it mentioned the spur gear in the kit they tested touched the rear flex plate and had to be filed for clearance. I was surprised when I read that because I know X-Ray has an excellent rep in the parts quality fit/finish dept.
I'm seriously considering going ahead and buying a '007 kit. Anyone else had or heard of any issues with parts quality fit/finish?
CAT Productions is offline   Reply With Quote
Old 01-29-2007, 04:15 PM   #1712
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Originally Posted by Jim Herrmann
just got mine done in Blue, I will post pics when it is back together. Which should be this week since I need it for the birds next week. lol
Jim
Herrmann post your pics of the blue 007
please
wallstreet is offline   Reply With Quote
Old 01-29-2007, 04:30 PM   #1713
BSchorr's Avatar
R/C Tech Elite Subscriber
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Dam, I could have my Losi 8ight, CR Buggy and the CR truck coming out too! that should be under 400 peices also!
Yes, please do post the Blue 007, im going to have it done after this season
EA, what was teh turn around time for the ano?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-29-2007, 04:37 PM   #1714
GK
Suspended
Originally Posted by CAT Productions
Hi, just wondering whether anyone that already has a '007 kit has exp any flaws in parts quality fit/finish. Reason I ask is I just read a review for the '007 US Spec edition kit in the current issue of Xtreme RC Cars magazine, and it mentioned the spur gear in the kit they tested touched the rear flex plate and had to be filed for clearance...
No issues with parts fit at all, if the spur gear touches the deck most likely it's installed wrong, flip it 180 and it'll be fine...
GK is offline   Reply With Quote
Old 01-29-2007, 04:38 PM   #1715
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
On mine it was about a day....but it depends on if they are doing other colors at the time and what their work load is. But anytime Hyperdrive has sent stuff up there its never been more than 3 days.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-29-2007, 04:53 PM   #1716
Big B's Avatar
Still 3days turnaround is fast,
Big B is offline   Reply With Quote
Old 01-29-2007, 05:02 PM   #1717
O.K., thanks!
Old 01-29-2007, 05:15 PM   #1718
chris moore's Avatar
Trader Rating: 88 (99%+)
Thanks to Iceracer, GTRtuned, adamge, & Jim Herrmann for all your help and tips on building the shocks, Ill try thame aal and see which helps.
Chris
chris moore is offline   Reply With Quote
Old 01-29-2007, 05:34 PM   #1719
teamgp's Avatar
Originally Posted by Cla88
Hi at all!
I'm a very happy with my T2 '007 EU in italy but i have a "problem": at mid corner off throttle the car understeer...how to get rif of understeer? and at corner exit on power the car understeer too...how to get rid of? Now i have 2 camber in front and 1.5 in the rear...i start with 2 front and 3 rear! And i have 5 of downstop at front and 4.5 at rear...is better for my problem if i test 4.5 in front and 5 in rear?
Thanks to all!
Please post your full setup on the XRAY forum online setup sheets so we can take a look at everything. We'll need more info in order to give you better advice.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-29-2007, 08:12 PM   #1720
GTRtuned's Avatar
I have both kits and I understand what you are talking about. I did have a similar issue when I put on a Kimbrough spur. It's super wide and it didn't have holes to let the motor wrench through. It sort of touched the chassis but it was a fat gear. Remember when buying a spur gear for the 007, you will need clearance holes for the motor wrench. If the spur gear doesn't have holes than you can drill a few holes around the gear making sure they are equal distance. Not sure who put the car together in the mag but I used the fattest gear and I still had a TQ & win at La Mirada. If you really want to make sure the spur fits, use an RW or J works gear and you're good to go.
Walter Cosico
RC America/ X-ray/ SRG www.superradgraphics.com/ Hudy/ R1wurks/ TeamBocaBearings
GTRtuned is offline   Reply With Quote
Old 01-29-2007, 08:19 PM   #1721
Great, thanks for the tips. The author of the article in the mag worded it as if it may have been a pre-production flaw or something like that. Who knows? Like I mentioned, I know X-Ray is known for top quality, so I doubt there's a flaw in the majority of kits (otherwise, I'm sure more people would be "screaming" about it).
Old 01-29-2007, 08:33 PM   #1722
MikeXray's Avatar
Trader Rating: 73 (100%+)
Xray spur gears are offset a good bit on one side, could have been soo noobish not to notice?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-29-2007, 08:50 PM   #1723
"Spanky's Avatar
I had the same problem, nothing my dremel couldn't fix. I had to do a lot of grinding on the chassis for battery fit and for the spur gear. well worth it though!
Brendan a.k.a. "Spanky"
TEAM LOSI 22SCT ..... 22T 2.0 ..... 22 2.0
Orion----Promatch Racing----Spektrum---Proline---Island Raceway
"Gone But Not Forgotten" --- RC10T, RC10T3, RCTc4, XRay007, XXT, XXTcrGraphitePlus, XXXT, XXXTMF, XXXTMF2----
"Spanky is offline   Reply With Quote
Old 01-29-2007, 09:18 PM   #1724
I hear that. O.K., just wondering, I know a lot of people are either in the TRF415 camp or the '007 camp. Curious as to how the quality of the 2 kits stack up. I think they're priced about the same. I also do think they both LOOK great. But does anyone have both kits to compare quality?
Old 01-30-2007, 05:19 AM   #1725
NOOB-SMOKE's Avatar
Default balance
my car is over weight t2007 with brushless.
Is it better to have left and right balance or just as light as possible.
NOOB-SMOKE is offline   Reply With Quote
