Old 01-28-2007, 08:06 PM   #1696
adamge's Avatar
I found the 'wait for gravity' technique to be hard to use consistently. I am able to arrive at a desired rebound much quicker just by starting with too much rebound, and holding the shaft in and blowing away the oil that leaks out. Take a little oil out, put the bottom lid back on, check rebound, and repeat if there's still to much rebound. If I hold the shaft far in, oil comes out fast and I can get down to very low rebound. Hold it in just a little to get slow oil leak, and end up with lots of rebound.
-Nietzsche
Old 01-28-2007, 08:16 PM   #1697
ttso's Avatar
Anyone can help here:
Originally Posted by ttso
What would be the significant difference on driving between T2 and T2'007? I think the rear of T2'007 got more traction, am I right?
(Edit add) Also, with bone stock car, which one is lighter?
ttso is offline   Reply With Quote
Old 01-29-2007, 09:12 AM   #1698
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by Big B
No it was Deluxe anodizing in Buffalo, NY. They do an awesome job.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-29-2007, 09:13 AM   #1699
Team EAM
The 007 generates more traction all around than the T2 did. It has to do with the rear bulkheads and the longer top deck. It makes the car smoother and easier to drive but have more steering/traction. The longer top deck also reduces the chance of tweak in a crash.
EA
Contact Us
Old 01-29-2007, 09:16 AM   #1700
HarshGuy's Avatar
EA
Drove mine for the first time this weekend ...and all of the above is true, took some pretty healthy hits (on purpose --- testing you know ) ...and the car never got tweeked as I was throwing up on the tweek station after every run to check'r out.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-29-2007, 09:30 AM   #1701
GTRtuned's Avatar
Default Building shocks
Originally Posted by chris moore
Seems many times that one shock is stuborn and I have to build it twice or three times to get it equal to the others. Mabey I'm just too picky
Hey Chris, I am also very picky with my shocks. If you are getting air in your shocks, you may want to try to screw on the cap a certain way. After you've added the oil and moved the shaft up and down to allow bubbles to rise to the top, you let the shocks sit for around 15 minutes unless you have a shock pump. After the bladder is placed, take an allen wrench and press the center of the bladder in a circular motion allowing the oil to bleed from the sides. When placing the cap, hold down the plastic mount tight and then screw down the collar. This elimiates air bubbles. Now you probably have a shock with a lot of pressure. Unscrew the bottom cap and move the shock up and down. You'll bleed out a drop of oil and take a napkin to wipe off the oil. You can do this until the desired rebound is accomplished. Shocks are perfect every time.
Walter Cosico
RC America/ X-ray/ SRG www.superradgraphics.com/ Hudy/ R1wurks/ TeamBocaBearings
GTRtuned is offline   Reply With Quote
Old 01-29-2007, 11:01 AM   #1702
ttso's Avatar
EA
Thanks lots EA.
Old 01-29-2007, 12:30 PM   #1703
TeamButter's Avatar
Send a message via AIM to TeamButter
Originally Posted by Jim Herrmann
Chris,
First of all what is the problem you are having with your xray shocks? leaking? air in them? what? Here is how I buld mine from the step of hving the pistons installed and ready for oil.
Pull shock shaft to the bottom of the shock, fill shock body with desired shock oil, move shock shaft up and down to get any air that may have been trapped under the piston to come to the top, repeat this three or for times, wait for all of the air bubbles to rise to the top of the shock and disperse, place shock bladder in the shock body using the end of an x-acto handle to ensure that the bladder is not being pushed up from excess oil, scew shock cap on, try and push the shock shaft up now, you will probably not be able to. Now lower the bottom shock cap off of the shock body and push the shock shaft in. This allows you to blead off the excess shock oil and get the proper rebound needed for each shock. once you get the desired rebound put the lower cap back on and you should have a shock described as "Butter"
Hope this helps.
Jim
That's exactly how the name came about Jimmy...LOL!!! How is everything going?
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 01-29-2007, 03:13 PM   #1704
Hi at all!
I'm a very happy with my T2 '007 EU in italy but i have a "problem":
at mid corner off throttle the car understeer...how to get rif of understeer?
and at corner exit on power the car understeer too...how to get rid of?
Now i have 2 camber in front and 1.5 in the rear...i start with 2 front and 3 rear!
And i have 5 of downstop at front and 4.5 at rear...is better for my problem if i test 4.5 in front and 5 in rear?
Thanks to all!
Cla88 is offline   Reply With Quote
Old 01-29-2007, 03:35 PM   #1705
Trader Rating: 8 (90%+)
EA
Very good service at that place. They do a great job. Just dont get any custon colors done, me and Rich Scaduto got Pink done and cost about $200 for 2 cars worth.
Johnny Carey is offline   Reply With Quote
Old 01-29-2007, 03:40 PM   #1706
Iceracer's Avatar
Regarding the part in bold, is the shock cap indexed to the collar like on an Fk05? If so, how can you do this, as the cap and collar must turn in unison.
Iceracer is offline   Reply With Quote
Old 01-29-2007, 03:46 PM   #1707
theisgroup's Avatar
they are no longer indexed
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-29-2007, 03:48 PM   #1708
jallshouse's Avatar
Send a message via Yahoo to jallshouse
EA
anyone have contact information?
jallshouse is offline   Reply With Quote
Old 01-29-2007, 03:49 PM   #1709
Iceracer's Avatar
Thanks, can I use top caps from a T2 on my FK05 to make holding down the bladder easier while I tighten the cap?
Old 01-29-2007, 04:09 PM   #1710
Team EAM
Deluxe Anodizing
588 Michigan Ave
Buffalo, New York 14203
Attn: Paul
716-856-6203.
They charge around 50-60.00 for up to 400 pieces of a standard color.
EA
Contact Us
