Old 01-28-2007, 04:46 PM   #1681
protc3's Avatar
Trader Rating: 13 (100%+)
dont forget the oven and arbor press to take the bow out of the chassis eric see you at the birds brutha
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 01-28-2007, 04:49 PM   #1682
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Doesnt seem to hurt my car at all. It just needs a driver 99% of the time
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 01-28-2007, 04:50 PM   #1683
protc3's Avatar
man,i always know how to get under your skin.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 01-28-2007, 04:55 PM   #1684
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Originally Posted by EAMotorsports
Here are some pics of my new red 007...fresh and ready to go for the birds!!
EA
EA, that is a great looking car!
Ronnie
EA Motorsports
picco007 is offline   Reply With Quote
Old 01-28-2007, 05:00 PM   #1685
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
EA
Awsome EA! Can we expect another A main run at the birds?
Kave is offline   Reply With Quote
Old 01-28-2007, 05:24 PM   #1686
BSchorr's Avatar
R/C Tech Elite Subscriber
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
where did you get teh Ano done and how much?! they got blue?
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-28-2007, 05:26 PM   #1687
Regional Moderator
Jim Herrmann's Avatar
just got mine done in Blue, I will post pics when it is back together. Which should be this week since I need it for the birds next week. lol
Jim
Jim Herrmann, ex-Professional (turned Life Coach)
Jim Herrmann is offline   Reply With Quote
Old 01-28-2007, 06:11 PM   #1688
Team EAM
Thanks Ronnie!!
Kave...Its highly undoubtfull!!! LOL. We will see how it goes though. The car is capable....just need the driver to cooperate again!!
Ben it was done by a place in New York. I'll have to find the name of it though. Its about 50.00 for up to 400 pieces. They are the only company I have found that can get every piece of alumn you send them the same color...even if its different grades!!
EA
Contact Us
Old 01-28-2007, 06:36 PM   #1689
Big B's Avatar
Thanks Ronnie!!
EA
was it Able Anodizing http://www.finishing.com/able/index.shtml
Big B is offline   Reply With Quote
Old 01-28-2007, 06:42 PM   #1690
chris moore's Avatar
Trader Rating: 88 (99%+)
Default shock question
Ok I have a question about shocks. I allways seem to have a hard time getting the xray shocks right. Has anyone replaced the xray shocks with another brand and if so why. The reason I ask is that a local fast guy just bought a tamiya car and said that the kit was ugly to build except for the shocks which are "butter". So that got me to thinking that if the Tamiya shocks are that much better would thay fit on my xray
Chris
chris moore is offline   Reply With Quote
Old 01-28-2007, 06:45 PM   #1691
jallshouse's Avatar
Send a message via Yahoo to jallshouse
Chris
my car isnt here yet, so i cant comment from experiance but i did read some interesting tips here http://nexusracing.net/newsdesk_info.php?newsdesk_id=40 hope this helps, i am going to use it when building mine
jallshouse is offline   Reply With Quote
Old 01-28-2007, 06:45 PM   #1692
teamgp's Avatar
EA
EA, its sooooooooooo pretty! Pretty Ricky whatcha call'em!
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-28-2007, 06:53 PM   #1693
Yep I have read and tied the tips both there and on the xray site, thay do help but still seems tougher than it should be. Also if you notice one of the tips is to replace the shock collar with the one from tamiya which leads me to belive that it might fit but I'm not sure about the top of the shock and the mounting system.
Old 01-28-2007, 07:05 PM   #1694
Regional Moderator
Chris
Chris,
First of all what is the problem you are having with your xray shocks? leaking? air in them? what? Here is how I buld mine from the step of hving the pistons installed and ready for oil.
Pull shock shaft to the bottom of the shock, fill shock body with desired shock oil, move shock shaft up and down to get any air that may have been trapped under the piston to come to the top, repeat this three or for times, wait for all of the air bubbles to rise to the top of the shock and disperse, place shock bladder in the shock body using the end of an x-acto handle to ensure that the bladder is not being pushed up from excess oil, scew shock cap on, try and push the shock shaft up now, you will probably not be able to. Now lower the bottom shock cap off of the shock body and push the shock shaft in. This allows you to blead off the excess shock oil and get the proper rebound needed for each shock. once you get the desired rebound put the lower cap back on and you should have a shock described as "Butter"
Hope this helps.
Jim
Old 01-28-2007, 07:21 PM   #1695
Thanks Jim, that is close to the same way i build them, the only difference is that I let the shocks self-bleed by inverting the shock and leting the shaft slowly decend into the shock body. No problem per se just looking for an easier way if it exists. In reality its not that its a major problem but I'd like them to be a bit more equal. Seems many times that one shock is stuborn and I have to build it twice or three times to get it equal to the others. Mabey I'm just too picky Also I read that the tamiya shocks have a different bleeding system and a fluorine coated cylinder lining which reduces the drag, making the shock smoother.
