Old 01-23-2007, 10:09 AM   #1621
slotcarrod's Avatar
Originally Posted by Anthony.L
Putting a silver can in a 007 is like buying a Ferrari and putting a civic motor in it.
I know it seems strange, but they had a GT class (fun class) this weekend at the WCICS Lethbridge race. You can only run a Silver Can motor and rubber tires with any chassis. It made for some very sweet racing. It was fun to watch! I want to race in it next year!
It's been said that politics is the second oldest profession, it bares a great similarity to the first.
Rod Littau
slotcarrod is offline   Reply With Quote
Old 01-23-2007, 10:16 AM   #1622
Send a message via AIM to R/C Anonymous
Thanks for the replies to my question everyone. Much appreciated.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-23-2007, 10:24 AM   #1623
Trader Rating: 22 (100%+)
Send a message via AIM to AChupp2
Originally Posted by Nexus Racing
You shouldn't turn over the XRAY diff rings (per XRAY)...they come slightly scuffed on one side to prevent the diff outdrive from slipping against the ring.
Where did you find this information? It's not that I don't trust it, I just have never seen it anywhere.
Fantom Racing Team Manager
AChupp2 is offline   Reply With Quote
Old 01-23-2007, 11:15 AM   #1624
Nexus Racing's Avatar
R/C Tech Elite Subscriber
Here; discovered it when uploading the products to our e-shop.
When examining the rings closely, the difference is indeed noticeable .
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 01-23-2007, 12:22 PM   #1625
Big B's Avatar
Thats some great info, when I get my euro 007 I will be sure to break in that rear diff, also in regards to the CA glueing, if you use tape to hold down your batts its a good idea to CA the tape slots, or you could cut the tape, it has been my experiance with CF to do every exposed edge, those splinters hurt
Big B is offline   Reply With Quote
Old 01-23-2007, 12:38 PM   #1626
Dane's Avatar
Trader Rating: 24 (100%+)
Send a message via AIM to Dane Send a message via Skype™ to Dane
Should the screws that attach the arms to the bulkheads be fully tightened without binding the arms? Should I instead tighten them fully and tap the back of the arms to free them?
"the big secret is to keep practicing and never get discouraged when taking a good beating on the track" - Paul L
www.toycarracingblog.com
Dane is offline   Reply With Quote
Old 01-23-2007, 02:28 PM   #1627
c-lyon's Avatar
Nexus, I know the ring sides were different on the original T1, and the date on the listing you mention was May 2001. I may be wrong, but I don't think it applies to the current version even if it has the same part #. In any event I've changed sides on the 05 and 007 without problems.
Perhaps someone from XRAY can clarify, teamgp???
c-lyon is offline   Reply With Quote
Old 01-23-2007, 02:47 PM   #1628
TeamButter's Avatar
Send a message via AIM to TeamButter
The original reason for the rough side of the rings was to provide consistent diff action. If both sides were polished you would have to crank down on the diff to get it tight enough to function properly. The problem was that you had to tighten so hard you could flat spot the diff balls and score the rings.
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 01-23-2007, 02:55 PM   #1629
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Butter has spoken!!!
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-23-2007, 03:14 PM   #1630
adamge's Avatar
Butter, the question is, are they still like that? I just looked at a pair of NIB diff washers I have, and I can't see a difference between the surface of the two sides.
I also had a rough diff, so yesterday I sanded (600 grit) both washers on the side the balls run on until they were track-less. I'll run this diff this weekend and find out how well that worked.
-Nietzsche
Old 01-23-2007, 03:17 PM   #1631
That's exactly what you should do!
NEXUSRACING.com
Old 01-23-2007, 03:25 PM   #1632
The difference between the sides is very faint, but as far as I can tell, still there. I accidentally flipped a ring on a new T2 in June, and that diff became "crunchy"...as soon as I flipped the ring back, the diff was fine!
NEXUSRACING.com
Old 01-23-2007, 03:37 PM   #1633
GK
Suspended
You can also try pushing the arm (gently) toward the screw you're tightening so that the pivot pin holder itself doesn't turn while tightening the screw...
GK is offline   Reply With Quote
Old 01-23-2007, 08:43 PM   #1634
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by HarshGuy
I'll have my spare 4300 if you need it as well (same one you used at the NWCC)
....Alexia is on her way, according to USPS website should take 2 days and she was shipped yesterday ...so should have plenty of time to throw the STLNLST setup on her and electrocnis with the 4300.
Charlie said both of my motors shipped today so I expect to see them by Thursday. If not I'll take the loaner just so I don't have to cut a motor.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-24-2007, 10:10 AM   #1635
TeamButter's Avatar
If I were you I wouldn't believe anything Suangka says!! LMFAO!!!
