Old 01-21-2007, 05:02 PM   #1591
Still Bill's Avatar
Trader Rating: 12 (100%+)
Originally Posted by STLNLST
Gonna be alot of fun come next weekend. I'll shock the world and run stock....
Won't shock my world...I'll be at a seminar in Rancho Cordova...Dang!
If they don't change the track...Try to beat my 8.85s in legal stock (C027).
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 01-21-2007, 05:33 PM   #1592
Gravity RC
I always shorten the wire on my futaba9550 from the inside. it can be a bit of a pain but it is not that hard. when you open up the servo you will most likely have some waterproofing thich you must very carefully cut and seperate from the board so you can unsolder the wires. once you do that its home free. but remember which wires go where lol.
If your not that confident in doing this i have also seen people cut the servo wire and put new plugs on the wires for the J connector, atleast this way you have a few of chances at getting it right.
Paul L is offline   Reply With Quote
Old 01-21-2007, 09:00 PM   #1593
Send a message via AIM to goop
i just wanted to take this time to thank Paul Lemieux for all the help this weekend. i have never seen anyone at a track help so many people. i dont think i would have gotten my car so dialed if it wasnt for his help. thanks again.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 01-21-2007, 09:28 PM   #1594
Send a message via AIM to R/C Anonymous
What does one person do with their setup going from stock foam to 19turn foam?
I tried out 19turn foam in my somewhat dialed stock foam car and it seemed way too edgy.
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 01-21-2007, 09:31 PM   #1595
Anthony.L's Avatar
Trader Rating: 36 (100%+)
You can compare setups of xray team drivers from stock and 19t/mod on Xray's online setups. From what I noticed it's typically how much the shocks are leaned in, and the use of sway bars. Some changes with springs and piston holes.
Anthony.L is offline   Reply With Quote
Old 01-21-2007, 11:05 PM   #1596
Big B's Avatar
Thanks Bill for your help,
Big B is offline   Reply With Quote
Old 01-21-2007, 11:16 PM   #1597
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Setup
Also to add to what Anthony said, it would be best if you could find how the same driver might change his car between classes because there can be differences in each persons setup due to driving style etc.
Steve
corallyman is offline   Reply With Quote
Old 01-21-2007, 11:19 PM   #1598
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
Dood... Steveo.... that avatar is dialed.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 01-22-2007, 12:03 AM   #1599
teamgp's Avatar
IMO, the main difference is the greater torque applied on-power. The 19t will drive the rear end with a lot more force. With that in mind, I usually have to do two things.
1. Slow the rear ends action down by stiffening the dampening. Usually closing one hole in the rear shocks is all thats needed here.
2. Limit the rear end roll by either:
-- Stand up the rear shocks more by moving the upper mount to the outside
-- Go up on spring rate
-- Adding a rear sway bar (or switch to a stiffer one)
Most of the time all I have to do is close one more hole on the rear shocks and the car is good to go.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 01-22-2007, 07:36 AM   #1600
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally Posted by racenut123
What happened to your GTB? You better run 19t!
Nothing.. I had a couple of motor issues. That's all.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-22-2007, 07:37 AM   #1601
STLNLST's Avatar
If it's allowed to be run at the track it's legal....LOL
Old 01-22-2007, 09:52 AM   #1602
Trader Rating: 18 (100%+)
Don't WUSS OUT!!!! Run 19T.....geez.....
If need be I have a motor you can use but it needs the endbell.
Prepare to be owned on Saturday!!!!
Advil is offline   Reply With Quote
Old 01-22-2007, 03:21 PM   #1603
OVA
OVA's Avatar
Trader Rating: 79 (100%+)
Default discharger
[QUOTE=Still Bill]Brian,
I only consider the Integy Reactor 30 as being a "discharger". The other two are more or less "battery conditioners". They discharge at very slow rates.
Hi Bill
I can't disagee the Integy Reactor 30 as being a "discharger, But the Spintec not only at discharge slow rates ,it also help to condtion the old batteries , and lower Internal Resistance for more batteries power..I know by useing the spintec first before charging the batteries it is a big difference performace...just my 02 cent
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 01-22-2007, 05:01 PM   #1604
jallshouse's Avatar
Send a message via Yahoo to jallshouse
Default Chassis Prep
please forgive me if this was covered, but i couldnt find it in detail looking through the 3 million pages for this car and also using search (did find alot of useful stuff though)......any good tips, or step by steps on preping the us carpet spec chassis? i have read the part about how to do the battery slots, but would like a detailed description on what other parts and best way to do it right. i know with my current car (not telling) i read that i should not do the top plate......any help and or pics would be greatly appreciated so i have a chassis that is preped correctly and get the most out of it. thanks in advance, and cant wait to try the car, this is my first XRay
jallshouse is offline   Reply With Quote
Old 01-22-2007, 05:05 PM   #1605
BSchorr's Avatar
R/C Tech Elite Subscriber
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Just filing down the battery slots properly, umm take you time sanding and CA'ing the chassis, because if you try to touch it to soon to see if its dry, you end up putting your finger prints inteh CA glue.
When i do an over haul or just when im working on the car, i am going to sand and ca the rest of the car (Front and Back shock towers, the rest of the top deck, and then the rear top deck also.
Make sure you line teh front 3 holes with CA glue where teh front bumper connects to, because that is a stress area.
Id recommend getting the pdub bumper and then teh wide under plastic bumper for it.
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
