Old 01-16-2007, 12:44 AM   #1501
rmargiotta's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rmargiotta
If you ONLY have Asc or Trinity oils, use 50 wt. That's about equivalent to 30 wt. XRay...
Sponsors:
- Cold Hard-Earned Cash Money -
rmargiotta is offline   Reply With Quote
Old 01-16-2007, 01:28 AM   #1502
Deves's Avatar
Anybody know where I can get an Xray pit hauler bag? One I can put all my stuff in to haul around to races?
Deves is offline   Reply With Quote
Old 01-16-2007, 07:36 AM   #1503
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Don't know about a XRAY bag, but if you want the best of the best........then you can't beat the one made by Team Magic!!!
Team Magic F8 Hauler bag
Fits everything you need to go racing with and then some!!!
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 01-16-2007, 08:16 AM   #1504
MikeXray's Avatar
Trader Rating: 73 (100%+)
Huh? is this common practice? does xray use its own viscosity scale or something?
I just rebuilt my shocks and was out of the 30 that came with the kit, so I used the AE I had, I guess it did seem a bit thinner.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-16-2007, 08:52 AM   #1505
So I should use the same weight oil front and rear? Never had a car that was the same front and rear that is why I ask.
Thanks again
Xtreme_Lee is offline   Reply With Quote
Old 01-16-2007, 09:23 AM   #1506
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
In most cases, the Xray 30 wt is good for just about every surface out there with a few piston hole tweaks to get a different oil feel front to rear. In general, I run 3 holes open front and rear in rubber, and 2 holes open in foam. Everyone has their own flavor of how a car should feel and whats fast for them.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-16-2007, 10:00 AM   #1507
dal bains's Avatar
Trader Rating: 35 (100%+)
Default TWEAK PLATE
Does the IRP tweak plate for the T2 align up correct for the T2 007?
I have had problems with my setup boards being out of wack so when i rebuild my car the chassis was bowed because of that.
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 01-16-2007, 10:01 AM   #1508
HarshGuy's Avatar
It has NOTHING to do with the 18 beers the night before
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 01-16-2007, 10:01 AM   #1509
Anthony.L's Avatar
Trader Rating: 36 (100%+)
Yup, the IRP plate works on both the T2 and T2'007.
Anthony.L is offline   Reply With Quote
Old 01-16-2007, 10:03 AM   #1510
Or the ten times you hit the wall going onto the straight.
Juan Aveytia is offline   Reply With Quote
Old 01-16-2007, 11:05 AM   #1511
Trader Rating: 15 (100%+)
Default crash
What about the double axial barrel roll across the track?
AARON YOUNG is offline   Reply With Quote
Old 01-16-2007, 11:18 AM   #1512
dal bains's Avatar
boy oh boy, i make a post once in a while and all you guys show up to ruin it...
the car worked awesome once it was figured out that the pit board was not level!!!!
and i drove very clean!!!
RCAMERICA-XRAY-HUDY
Old 01-16-2007, 08:05 PM   #1513
STLNLST's Avatar
Trader Rating: 21 (100%+)
I think it was that killer set up you put on
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-17-2007, 07:40 AM   #1514
AdrianM's Avatar
A setup that makes you die is bad. I like fast setups better than killer ones
Adrian Martinez
What I run: Schumacher Mi5/Associated RC10R5.1/Associated RC12R5.2/Futaba/HobbyWing/Team EA Motorsports/BSR Racing
Where I run: Florida Indoor R/C Complex/Thunder Racing/Florida On Road State Series
AdrianM is offline   Reply With Quote
Old 01-17-2007, 08:15 AM   #1515
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by Xtreme_Lee
Just picked up a 007 and the shocks look to be built with the 3 hole non adjustable pistons. What shock oil should I use with these. I only have AE and Trinity oils no X-Ray. I am running on Med Bite Ozite with foams. Thanks
Here's a chart that me and Seaball made up. We tested all the oils with a $20,000 machine that is at his work. Some of the oils will differ from batch to batch slightly but this will give you a general idea what is going on with the different brands. Trinity is the thinnest of all the oils. AE, Losi and Hudy/serpent 30t are all very similar. When Hudy goes up after the 30 the jumps get more spread out. Example hudy 35 is similar to Ae/Losi 45 maybe slightly lighter than 50. Then Hudy 45 is closer to Losi 100wt.
wt..........losi...................associated
20..........0......................0
25..........0......................0
30..........All similar...........All similar
35..........0.....................463
40..........559..................552
45..........0.....................0
50..........760..................709
55..........0......................0
60..........920...................883
70..........988...................1050
80..........1140.................1044
90..........1335..................0
100........1470...................0
wt.............hudy......trinity
20.............0............0
25.............0............0
30.............378.........0
35............ 662.........373
40.............1030.......0
45.............1485.......0
50.............2482.......0
55............ 0............750
60.............0............0
70.............0............755
80.............0............862
90.............0............0
100...........0............0
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
