Old 09-14-2006, 09:58 PM   #1
Default Charging Li-PO
Can someone help me how do I set the ICE charger to charge the 3 cells Li-po cells for the 3PK? As this is my first time using a Li-Po cells for my 3PK, I'm just a bit cautious.
A_380 is offline   Reply With Quote
Old 09-14-2006, 10:01 PM   #2
Trader Rating: 18 (100%+)
If it is 3 cell lipo, then set charger to 11.1v with the correct amperage of the pack. Make sure you are in lipo mode. Then set your charge rate (up to 1c) and you are done.
trilerian is offline   Reply With Quote
Old 09-14-2006, 11:23 PM   #3
Send a message via MSN to ammo
Normal charging at 1C:
If your battery is 2000 Mah, then 1C = 2.0 amps
if your battery is 1500 Mah, then 1C = 1.5amps
If your battery is 800 Mah, then 1C = 0.8amps
Charge according to the capacity of the pack, set it at 1C or below. Charging time at 1C is about 1 hour. this is normal for all lipo batteries.
More importantly as mentioned, is to set the voltage to the correct cell count.
1s = nominal 3.7V, charged 4.2V
2s = nominal 7.4V, charged 8.4V
3s = nominal 11.1V, charged 12.6V
ammo is offline   Reply With Quote
Old 09-14-2006, 11:32 PM   #4
Drewdc90's Avatar
The instuctions for the charger tell you how to charge lipos and how to look after them.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 09-15-2006, 07:26 AM   #5
SlamMan's Avatar
Which Lipo pack did you get for the 3PK?
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 09-15-2006, 04:02 PM   #6
heavy's Avatar
Trader Rating: 20 (100%+)
If I get a Maxamps 6000 can I charge it with a Much More CTX charger ?
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 09-16-2006, 01:38 AM   #7
It's a Premium Power Li-Po 2100mah 11.1v 10c
Felt bloody good every time I use my 3PK now!
Old 09-16-2006, 03:17 AM   #8
Drewdc90's Avatar
It should charge fine.
Just a quick question, does the Logan ,Brendale or the Bayside club allow you to run LiPo's for club meets?
Thanks Drew.
Old 09-16-2006, 03:02 PM   #9
heavy's Avatar
G'day Drew.
No not at the moment - I would be ok to run some tests at Bayside but not in a big race meet or in teh club champs etc.
I am currently doing some testing with the Novak 13.5 in stock at Hobby Station and Bayside with no issues but again not for points and not at big meets. I wanted to do some testing with the Lipo and the 13.5 so at least we'd be reasonably informed to take part in the debate but didn't want to have to buy a new charger as well.
Can I do testing with either the 13.5 or the Lipo at your track ?
Old 09-16-2006, 03:05 PM   #10
Drewdc90's Avatar
You should be able to, I'm running a Maxamps 4000mah in mod, I don't think I will be able to run for though.
Thanks, Drew.
Old 10-06-2006, 09:39 AM   #11
Send a message via MSN to sampaio Send a message via Yahoo to sampaio
Hi all,
I'm looking to find a charger that supports more than 1A in LIPO mode.... currently I found only ICE and Robirtonic chargers, the orion and much more supports only 1A in LIPO mode.... do you know other charger option?
thanks
Carlos
sampaio is offline   Reply With Quote
Old 10-06-2006, 09:46 AM   #12
MrBlack's Avatar
The Advantage Charger charges 2S Li-Po's up to 10Amps
http://www.teamorion.com/Products/Ch...+_+Dischargers
Also the Avionics Flight Charger Will charge 1-5S all at up to 5Amps
http://www.teamorion-avionics.com/Ad...Flight+Charger
Even Our Orion Avionics Li-Po charger will charge up to 3Amps and up to 4S
Just a foot note I would always make sure my charger can charge near 1C for my battery. We've used the Li-Po only charger to charge 3200mAh but I would not recommend it for say a 4800mAh as it will only charge it at 3A which will take a while.
There ar emany Li-Po chargers out there that only charge up to 1 or 1.5Amps and these are made primarly for the Li-Po's you put in your transmitter and I would not recommend them for the batteries you put in your vehicle.
Just an FYI.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 10-06-2006, 09:54 AM   #13
bs6ef's Avatar
Originally Posted by sampaio
Hi all,
thanks
Carlos
Hi carlos
try this link http://www.finedesignrc.com/battchargechargers.asp.
"ASTRO 109 Lithium Charger
Lithium Battery Charger, Charges from one to nine cell Lithium Poly Battery Packs. Charge rate 50 ma to 8 amps.
Input 12 volt DC."
bs6ef is offline   Reply With Quote
Old 10-06-2006, 09:58 AM   #14
Hi guys,
thanks....... and about balancer...... wich one are you using?
rgds
Carlos
Old 10-06-2006, 10:31 AM   #15
MrBlack's Avatar
http://www.teamorion-avionics.com/Ce...lancing+System
charging hillbillyrcer Micro and Mini Scales 9 01-16-2008 03:58 AM
Charging ? NitroMaxx3.3 Nitro On-Road 7 06-18-2007 02:57 PM
need help with charging please mikezilla Australian Racing 9 04-11-2006 05:17 AM
Charging. How to? Mossie Australian Racing 14 01-27-2004 02:32 PM
