Old 10-06-2006, 11:40 AM   #16
Send a message via MSN to sampaio Send a message via Yahoo to sampaio
Originally Posted by MrBlack
Just a question, its not work with Premium 4800mAh, right?
rgds
Carlos
sampaio is offline   Reply With Quote
Old 10-07-2006, 09:52 AM   #17
gacjr0's Avatar
Trader Rating: 15 (100%+)
If you're careful you can lie to your ICE to let it charge/discharge at higher rates. Tell it the right 7.4/11.1 V but a higher mah.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 10-07-2006, 09:55 AM   #18
gacjr0's Avatar
Elelctrifly just released a balancer that will work with the ICE, it will charge balance when used with the ICE and it will discharge balance when used by itself. I played with one and plan on getting it.
Old 10-07-2006, 10:32 AM   #19
try E-Station 501DX, it look good for lipo
ref to www.bantamtek.com
G2B Anthony is offline   Reply With Quote
Old 10-07-2006, 06:37 PM   #20
Originally Posted by heavy
If I get a Maxamps 6000 can I charge it with a Much More CTX charger ?
Yes it would charge fine but at a 1A rate it will take forever.
cvt01 is offline   Reply With Quote
Old 10-07-2006, 07:25 PM   #21
Hi all,
this is a very nice option...... but one point and about Robitronic Overloader...
cheers
Sampaio
Old 10-10-2006, 12:53 PM   #22
MrBlack's Avatar
rgds
Carlos
You can use it to balance the 4800 not porblem you just have to modify the balancing harness like so...
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 10-10-2006, 01:04 PM   #23
Thanks man,
very nice.....
cheers
Sampaio
Old 10-10-2006, 10:50 PM   #24
Send a message via MSN to ammo
Some high capability lipo chargers are those used in the airplanes and helis section.
Some of the examples are the following brands:
1) Schulze 330D onwards, chameleon series of chargers.
2) Orbit Electronics, they have the MicroLader Pro and the very portable PocketLader
3) Thunder Power TP1010c
4) Astroflight 109 (this uses pulse charge, which can be a little harsh on the the battery)
There are some more which i can't recall offhand.
ammo is offline   Reply With Quote
charging hillbillyrcer Micro and Mini Scales 9 01-16-2008 03:58 AM
Charging ? NitroMaxx3.3 Nitro On-Road 7 06-18-2007 02:57 PM
need help with charging please mikezilla Australian Racing 9 04-11-2006 05:17 AM
Charging. How to? Mossie Australian Racing 14 01-27-2004 02:32 PM
