Old 02-04-2003, 07:29 AM   #1
Default Using CA and filing a new graphite chassis plate
Got a new 12th scale bottom plate and need advice on using CA to seal the edges and using a file on the battery slots. Do you apply CA as you would when glueing a tire or do you use a different applicator? What type of file do you use and how much filing needs to be done?
Thanks for any advice. I want to do this carefully.
coolrcdad is offline   Reply With Quote
Old 02-04-2003, 07:39 AM   #2
Hi,
I use the normal CA for my tires for my graphite parts.
WEAR A MASK when filing graphite. And have a vacuum
cleaner around to suck the dust. Graphite is not very
healthy.
ongbenghui is offline   Reply With Quote
Old 02-04-2003, 07:51 AM   #3
dtm
dtm's Avatar
Send a message via ICQ to dtm
A couple of drops of CA glue onto a cotton wool bud and wipe it onto the edges...no mess. Just make sure you have a few cotton wool buds spare..it dries up pretty quick and you will need a few. Also leave it overnight in a well ventilated area to dry. If you put it in a bag the CA mist will fog up the edges. This will still occur if the "feels" dry...overnight..just to be sure!
dtm is offline   Reply With Quote
Old 02-04-2003, 08:19 AM   #4
Team CRC has a good advice for graphite chassis prep.
I've used it on my 1/10 and 1/12 pan and it works very well.
Follow the link
http://teamcrc.com/team_crc_raceway/chassis.htm
rcboat_racer is offline   Reply With Quote
Old 02-04-2003, 08:41 AM   #5
Eddie M's Avatar
Other tips... wet sanding to reduce the amount of dust...
Eddie M is offline   Reply With Quote
Old 02-04-2003, 08:46 AM   #6
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Dtm's way is pretty fool proof . but I use Q-tips rather than Cotton swabs.... And a little prep work with some hi-grit sand paper helps too
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 02-04-2003, 10:15 AM   #7
Thanks for your advice. Any input on filing the battery slots?
Old 02-04-2003, 10:21 AM   #8
With a file!
Just kidding I use a flat file and a Dremel both, just knock the corners off if not you risk dropping the batteries too low and dragging them on the ground or carpet. I have seen many a chassis with batteries that have custom scratches on them.
Dan
Difuser is offline   Reply With Quote
Old 02-04-2003, 10:24 AM   #9
just keep a single cell handy to check the fit.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 02-04-2003, 10:38 AM   #10
Also when you are done and you have all of the graphite dust on your skin wash your hands with VERY HOT WATER!!!
This will open your pores and allow the graphite dust to be removed from your skin... If you use cold water the pores will close and rap the graphite dust in and then your coolrckid will be asking "daddy why do you have zits on your hands".....LOL J/K but alot of people make this same mistake... Also remember donot touch your face or goto the bathroom before washing....... I would have to think what that graphite would do to your johnny.....LOL
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 02-04-2003, 05:52 PM   #11
I almost always have a stuffed up nose for 2-3 days after grinding
chassis plates
Speedmerchant Rev 4 / 4.5 Chassis Plate and Top Plate ToddFalkowski R/C Items: For Sale/Trade 4 09-05-2008 06:21 AM
WTB:hpi graphite camber plate mr2sd R/C Items: Wanted to Buy 0 06-28-2008 01:06 PM
Graphite Plate Transponder Mount? acutts Electric On-Road 6 04-10-2006 07:53 AM
Cell slot filing and chassis ca glue service. RCknight Electric On-Road 0 01-19-2006 03:10 AM
12L3 Chassis plate iridescent graphite "speckled" Mach10_shooter R/C Items: For Sale/Trade 5 09-27-2004 10:35 AM
