Old 09-12-2006, 12:50 PM   #1
Trader Rating: 52 (98%+)
Default what's the diff btwn 0-30 discharger & novak smart discharger
Hi, I am new to electric. what is the difference btwn 0-30 discharger and the novak smart discharger? All I know is that the novak will stop at 0.9 V. the the 0-30 will drop to 0 v. will 0 v hurt the battery? which one should I get?
Thanks in advance.
straightaway is offline   Reply With Quote
Old 09-12-2006, 01:20 PM   #2
Tsquare's Avatar
Thanks in advance.
One big difference between the two is the discharge rate, 0-30 is at 30amps, the Novak I believe is at 2.5amps. I use the 0-30 for a quick pull down on the battery after I run the car. I use the Novak tray to equalize the pack (at the rate I want, ie. .08) right before I place the pack on the charger.
Tsquare is offline   Reply With Quote
Old 09-12-2006, 01:40 PM   #3
quick pull down? will this drop the battery to 0 V? or do I have to monitor it? will this hurt the battery?
Old 09-12-2006, 01:45 PM   #4
Tsquare's Avatar
If you are using IB type batteries, you do not want to pull them down below .07. I usually use the 0-30 until the lights go out, then I pull them off the 0-30, and set my Novak tray to .07 and it takes 2 to 4 min. to get them equalised on the Novak tray. The important point here is that you need to monitor the IB's on the 0-30, not advisable to leave them on too long after the lights go out. If you are using GP type batteries, it makes no difference, those you can take right down to zero.
Old 09-12-2006, 01:57 PM   #5
Ali Graham's Avatar
Send a message via MSN to Ali Graham Send a message via Yahoo to Ali Graham
The Integy 0-30 is a 30A discharger, and it will take all all your cells down in voltage at a 30A rate, with no cutoff, the only way to measure what its doing is by the lightbulbs. The novak is an equalizer, it dischargers much slower (5A I believe) and stops discharging each cell at a cut off you select, therefore equalizing your pack.
I would use the Integy to bring the cells down first, then equalize on the Novak.
Hold onto your horses though, new Integy discharger on the way, 0-90, should rival the ubiqutous muchmore CTX-D
Mirage Racing | Team Xray | Nosram | Atsushi Hara Racing Products | Team Orion | Hudy | Apex Models | Much More Racing | Exit13 | NinjaGraffix | ali303.8.dtiblog.com
Ali Graham is offline   Reply With Quote
Old 09-12-2006, 02:13 PM   #6
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Yeah, 90A discharge will do wonders to a pack - . The new D-90 looks cool, but not nearly equal to the CTXD2 or DPD, IMO.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 09-12-2006, 04:27 PM   #7
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
The Trininty DPD does both correct? Discharges at 30 Amps and equalizes?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-12-2006, 05:31 PM   #8
Yes. The DPD will pulse discharges at 30A, where the 0-30 does 30A cont. discharge.
Retired from RC....
Old 09-12-2006, 06:01 PM   #9
If I use the 0-30, I should pull the battery off right after the lights goes off, then put it on the novak and set 0.9 or 0.7?
Or for no brainer and another $100, I should just get a ctx d2 which will do the job of both novak and integy?
Old 09-12-2006, 07:15 PM   #10
Yes, remove the pack from the 0-30 when the lights go off.
You would want to put the pack on the smart tray before you charge it, give it some time to cool first after the 0-30. .9 is the standard setting (most commonly used), but some people are using .7 on the new 4200's.
but..
You can't go wrong with the CTXD2 Only one extra item to carry in your pit box.
Retired from RC....
Novak Smart tray discharger robracer R/C Items: For Sale/Trade 2 01-27-2008 06:15 PM
Novak Smart Tray Discharger John Q Electric On-Road 2 02-12-2006 05:26 PM
NOVAK SMART TRAY DISCHARGER HELLOkitty Electric On-Road 12 11-08-2005 09:51 PM
Novak Smart Tray Discharger wademcgee R/C Items: For Sale/Trade 5 02-05-2005 10:02 PM
fs: Novak Smart Tray Discharger XCrash R/C Items: For Sale/Trade 2 10-28-2004 11:13 AM
