Old 10-10-2006, 11:58 AM   #16
AM03GT's Avatar
Originally Posted by "Spanky
do you have the formula for rollout? Also what units to use for the measurments. I am confused because what make for a different gear ratio if you have a 72 tooth spur and its 64 or 48 pitch (doesn't it still have the same # of teeth?)
the rollout depends n the final drive ratio of the gearing for a particular car. if you compare gearing charts for a car with similar sized spur gears (dia. not teeth) you'll see that the change in FDR per tooth on the spur/pinion is smaller with 64 pitch than it is with 48 pitch... basically it comes down to the fact that 64 pitch has smaller teeth which translates to the smaller changes.
Associated // Reedy // Radiopost // Integy // Parma PSE
AM03GT is offline   Reply With Quote
Old 10-10-2006, 12:06 PM   #17
Default roll out
RO = D * 3.14159 * S / P
where
RO is rollout (inches or cm)
D is rear wheel diameter (inches or cm)
S is number of spur gear teeth (pitch makes no difference)
P is number of pinion gear teeth
atr4tigers is offline   Reply With Quote
Old 10-10-2006, 12:18 PM   #18
Default 64 vs 48 pitch
using 64 pitch provides you with more gearing options vs 48 pitch for a given diameter of spur gear.
let's say the biggest gear that will fit your car is 128 tooth in a 64 pitch, that would equate to a 96 tooth spur in 48 pitch, for example; therefore, for allowing for finer adjustment in gear ratios for any particular pinion.
Old 10-11-2006, 11:48 AM   #19
"Spanky's Avatar
thank you!
Brendan a.k.a. "Spanky"
TEAM LOSI 22SCT ..... 22T 2.0 ..... 22 2.0
Orion----Promatch Racing----Spektrum---Proline---Island Raceway
"Gone But Not Forgotten" --- RC10T, RC10T3, RCTc4, XRay007, XXT, XXTcrGraphitePlus, XXXT, XXXTMF, XXXTMF2----
"Spanky is offline   Reply With Quote
Old 10-11-2006, 11:40 PM   #20
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
Originally Posted by TimPotter
I have had problems with PRS pinions. I have had 2 or 3 of them that did not fit on the output shaft. The ti racing pinions have been the best for me.
Contact PRS.. i had bought 3 of there spur gears, and they were to wide.. they sent me 3 replacements for the bad ones.. there customer service is awesome..
tho your gears did not fit, remove some of the coating inside the hoes.. alot of mine are tight.. But i like that because it keep the pinion super true on the sfaft.. no slop wobble..
I dont run there spurs tho.. i refuse to pay 6.50 for a spur that can pick upa stone and be junk in one run.. I prefer the standard kimbrough's.. also even tho a spur looks good be carefull for slight rounding or spreading of the teeth.. if you notice the car gets a little louder its time to replace the gear.. this happens with all spurs..
burbs is offline   Reply With Quote
Old 10-11-2006, 11:54 PM   #21
XrayFK's Avatar
Xenon spurs are the shit.
XrayFK is offline   Reply With Quote
Old 10-12-2006, 07:54 AM   #22
timmay70's Avatar
Has anyone had the chance to use the Kimborough plastic pinions? I'd like to hear a review on these.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-12-2006, 09:54 AM   #23
I've been using them for years- Touring and 1/12th.I've had no problems you do the mesh a little tigher than the metal gears. I won a Masters Roar Nationals 1/12th championship in 2003 using these gears in 1/12th. Presently running the Novak Brushless Stock 13.5 for several months in an RDX , again with no problems.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-12-2006, 04:51 PM   #24
UCHEATULOSE's Avatar
only one name when it comes to spurs and pinnions people!
prs
UCHEATULOSE is offline   Reply With Quote
Old 10-12-2006, 08:21 PM   #25
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
RW spurs and TiR Ultra pinions!
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
FS NIP 64p pinions and spurs!! sg1 R/C Items: For Sale/Trade 15 04-29-2008 09:52 AM
64P pinions and spurs Tron 101 R/C Items: For Sale/Trade 17 01-25-2008 03:01 PM
Pinions and Spurs and 13.5's oh my! or8ital Electric On-Road 20 04-04-2007 10:32 AM
mtx-3 pinions & spurs... onnetz R/C Items: Wanted to Buy 0 04-30-2006 03:00 PM
HPI R40 - pinions and spurs J_Longbrake R/C Items: For Sale/Trade 3 10-06-2004 03:45 PM
