Old 02-03-2003, 07:10 PM   #1
CGR
CGR's Avatar
Default TC3 Shaft
Is there a performance difference (stock) between the carbon and aluminum drive shaft?
CGR is offline   Reply With Quote
Old 02-03-2003, 07:42 PM   #2
alfa's Avatar
it wont break
alfa is offline   Reply With Quote
Old 02-03-2003, 08:16 PM   #3
NTC3NUT's Avatar
The main differance is that it would be truer, and would not flex. You do give up the light weight though.
NTC3NUT is offline   Reply With Quote
Old 02-04-2003, 02:23 PM   #4
rc-zombies's Avatar
Originally posted by alfa
it wont break
yes..but once bent it stays bent.
get the new yokomo TC3 drive shaft..
best of both worlds..solid graphite and aluminum.
Old 02-04-2003, 03:20 PM   #5
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Bend an aluminum drive shaft on a TC3??????? News to me.
Core Creations is offline   Reply With Quote
Old 02-04-2003, 03:28 PM   #6
mab_man20's Avatar
Send a message via AIM to mab_man20
The graphite one bends, not the aluminum. But the aluminum is heavier so there is a trade off like always.
mab_man20 is offline   Reply With Quote
Old 02-04-2003, 03:31 PM   #7
I ran the carbon shaft in my FTTC3 for 6 mos in mainly stock racing, and then went to the new AE aluminum shaft when it came out and if anything my car has been slightly faster.....I don't notice any reduction in acceleration.
Old 02-04-2003, 03:43 PM   #8
NeO-pRo-3's Avatar
IT depends on what you like. I personally suggest the aluminum shaft by yokomo that rc-zombies pointed out. But..... if you want to save money get the AE aluminum shaft. IT's cost is around 6-10 while the IRS which is also good costs 15-30 depending on where you get it. All i can say is that the FACTORY drivers for AE use the carbon one or graphite
NeO-pRo-3 is offline   Reply With Quote
Old 02-05-2003, 05:39 AM   #9
Hi,
as for the alumium shaft bending I have seen this done. and also I have seen the graphite one break. I run the new Assoc Alumium shaft in both of my TC3's. mostly for clearance as I have moved the battteries in more towards to centreline of the chassis.
The Yokomo shaft looks nice. I think Racers Edge makes a Mag shaft but it's around $30.
Fakk2 is offline   Reply With Quote
Old 02-05-2003, 05:48 AM   #10
STLNLST's Avatar
Trader Rating: 21 (100%+)
a few guys at my track run the aluminum shaft due to the breakage of the regular one and I also feel that because it's a bit heavier it adds a touch of rotating mass to the car which should really help the car in the corners when off power. Just my $0.02
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-05-2003, 12:38 PM   #11
TC3
TC3's Avatar
i think the asso aluminum shaft is the best one, because it spinns very true, is very stiff and lightwight too (10g) (only 4g more than the asso graphit one).and because it is smaller, it has the same effect of less rotating mass.
TC3 is offline   Reply With Quote
Old 02-06-2003, 11:31 AM   #12
Northerner's Avatar
Send a message via ICQ to Northerner
the AE graphite shaft is three piece and is being discontinued and replaced with the new one piece aluminum shaft!
the new shaft is super straight, my car sounds a LOT quieter now with it installed
and its a third the price of the IRS shaft
Northerner is offline   Reply With Quote
Old 02-06-2003, 01:26 PM   #13
KINGZJ's Avatar
Send a message via AIM to KINGZJ
Neo,
Most of the factory guys at the Novak Touring Car Race were using the alum one not the graphite one.......
KINGZJ is offline   Reply With Quote
Old 02-06-2003, 01:32 PM   #14
rayhuang's Avatar
For whatever its worth-Walter Henderson of AE told me-if yourve got a CF drivehast and its not broken after a year-dont replace it.
But-if car is truly quieter with an alum driveshaft-that might make it worthwhile by itself.
Old 02-07-2003, 01:24 PM   #15
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
roughly 90% of the torsional load is carried on the outer edge of a shaft, so if the yokomo one is solid (not hollow), then it's only adding unneeded weight...
The thing I don't like about the new assoc alum one is the pins, I would think they would wear out the cups... Haven't yet at all though..
pimpedaccord is offline   Reply With Quote
Single shaft vs split shaft/slipper 1/18th-Vendetta/RC18 vs MLST/Half 8 imjonah Micro and Mini Scales 5 08-24-2008 01:38 PM
Giving my shaft cars the shaft. YR4Dude R/C Items: For Sale/Trade 10 08-22-2007 10:53 AM
MTX-4 lightwieght 2 speed shaft and front shaft rcfoolz R/C Items: For Sale/Trade 5 05-26-2007 10:15 PM
SG shaft vs. Threaded Shaft??? SeattleRCer Electric Off-Road 3 09-08-2005 09:56 AM
Question about SG shaft & threaded shaft on RS4 2/NTC3 ProRacer03 Nitro On-Road 3 12-13-2002 12:11 AM
