Old 09-15-2006, 10:59 AM   #31
bxpitbull's Avatar
Originally Posted by MrBlack
??? Orion has been the primary promoter and seller of Li-Po batteries specifically design for use on R/C cars for a little over a year now. We didn't just take a plane pack and market it to car guys. We made a specific package to be used in todays R/C Cars and have constanly been and continue to work to improve cells and there interface to be used in our applications.
We also are the largest supplier of Sub-C cells worldwide this allows us to be on the forefront of both technologies. Some are not and they make themselves obvious.
I know you guys are really pushing the Li-po thing, I meant as far as getting your dirvers to run them. I have since heard they ran them at the KO propo, so...nuf respect due.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 09-15-2006, 03:20 PM   #32
MrBlack's Avatar
Originally Posted by killerjvf
MrBlack,
How did they make this fit in the MSX? The rear bulkhead is in the way. Did they modify the batt case or the car?
Thanks for the info.......
I do not believe either of them ran the MSX i think they ran the 415 standard edition.
The new 3200 Race Spec Li-Po coming next month will fit right into the MSX without any modification.
TEAM ORION - AVIONICS - KYOSHO - KO PROPO - PEAK
"Racing is about the journey not the destination if it wasn't it would simply be called Arriving"
"The solution is people need to spend more of their efforts on promoting and finding more people to race with, rather then a personal quest to form a class that they can win at."
MrBlack is offline   Reply With Quote
Old 09-15-2006, 03:30 PM   #33
MrBlack's Avatar
Unfortunately the majority of races our drivers run do not allow Li-Po batteries. For the K.O. because our drivers are used to running Ni-MH and there cars where set up as such they chose to eliminate any variables and run traditional Sub-C cells. We only had a couple factory drivers there and they were trying out prototype stuff for there chassis factories so they were incouraged to run traditional batteries for this event.
You have to add a lot of weight to make the minimum especially today with today's super heavy Sub-C's which are much larger in diameter and weight then the cells we used just 6 years ago.
Chassis designs are changing and most of the chassis manufacturers have already told us they are considering Li-Po in there chassis from this point forward. The 6 sub C cell pack has long been a hinderance for proper chassis design with lighter power that can be shaped more compact the future should allow for chassis handling much better, being much lighter and allowing a more affordable platform. We will also be able to go much faster with less motor in the future. These are things that those of us that work in R&D and design in our industry are realizing were are at that point again right before TC came out so the next stage of electric on-road is still to be set.
Old 09-15-2006, 03:35 PM   #34
Rick Hohwart's Avatar
I do not believe either of them ran the MSX they ran the 415 standard edition.
Medel actually did use an MSX. In fact it was my old car. To make the pack fit, you use the top plate and right rear bulkhead from the stick pack conversion kit.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 09-15-2006, 08:49 PM   #35
Send a message via MSN to ammo
TrakPower does put the cells thru a dedicated process to ensure the packs are more than good enough for 1/10 race cars.
I would not go into arguments as in which is better or not. Nor will I look at it as a form of competition, rather at this stage, every new lipo pack designed for cars will only further compliment the trend towards providing more performance and convenience for all players in r/c vehicles.
ammo is offline   Reply With Quote
THE WAY OF THE FUTURE COBRARACING Australian Racing 10 08-26-2008 05:00 PM
THE WAY OF THE FUTURE COBRARACING Nitro Off-Road 0 08-25-2008 04:46 PM
Future of RC 1fastdude Electric On-Road 225 02-04-2008 05:05 PM
The future... axel Chat Lounge 7 06-05-2005 10:21 AM
The Future Of The Nct....... Mike Dana Northwest Racers 122 09-02-2004 04:23 PM
