Novak GTX maybe dead >
Old 09-10-2006, 04:11 AM
Default Novak GTX maybe dead
Help required
I have got novak GTX speedo, Which seems to have gone a bit faulty.
When i connect the wires to the battery the motor starts turning even if the switch is turned off. Is this a return job or is there anything i can do to fix this.
Cheers
Anthony
adavison1974 is offline
Old 09-10-2006, 04:48 AM
TRFTIM's Avatar
Are you sure that the wires are connected up properly
TRFTIM is offline
Old 09-10-2006, 04:50 AM
Yep,
As used it in round one then changed cells over and problem occured tried with different packs and also took speedo out of car in case of shorting etc and still same thing, tried diff speedo and hey presto working ok so cells and motor etc are ok problem must be with speedo
Old 09-10-2006, 07:46 AM
Much Much More's Avatar
Mosfet Failure in your ESC. Its fried!!
Much Much More is offline
Old 09-10-2006, 08:03 AM
JAY_UK's Avatar
Told you it was dead!
JAY_UK is offline
Old 09-10-2006, 01:43 PM
Bit like your shiney blue turnbuckle on your trf
Old 09-10-2006, 10:28 PM
Have you had it working lately ... and as long as you have not changed the wires leading into the unit from the receiver, or have not installed it incorrectly in the receiver:
RIP GTX...
duckman996 is offline
