Old 09-07-2006, 02:26 PM   #1
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
Default drivetrain question
still got 05 drivers around?? i got a question for you guys.. i tested my 05 today and everytime i make a turn it makes a sound. i take a look at my front drive shaft and it has a mark from getting hit by the wheel axel. both left and right side...any advice will be appreciated..thank you
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 09-07-2006, 02:45 PM   #2
Z.Hallett's Avatar
Send a message via AIM to Z.Hallett
i would suggest turning down your dual rate on the radio. it sounds as if the wheel is turning too far.
-Zac
Z.Hallett is offline   Reply With Quote
Old 09-07-2006, 05:46 PM   #3
pinggoy's Avatar
i have it at 70%
TAMIYA TRF416X
Old 09-07-2006, 06:21 PM   #4
pinggoy's Avatar
and also my steering rack is shaking....or vibrating
TAMIYA TRF416X
Old 09-07-2006, 06:30 PM   #5
you can add a few shims . just make sure they dont bind . and also turn down your end point adjustments. so your servo isn't driving too far . try setting your end points to full lock then back them off ... Adjusting your dual rate will adjust the speed of your servo .. start a 100% then dial some out to your preference ....also you can add some o-ring's on the ball studs to take up some slop from your turn buckles ... have fun !!!
markb.
Mark Barden .
mb racer is offline   Reply With Quote
Old 09-07-2006, 06:31 PM   #6
Check to make sure you do not have any bad bearings... this may cause the shaking that you are complaining of.
You may also have a bent outdrive hub or drive shaft... that would cause the same behavior as well.
duckman996 is offline   Reply With Quote
Old 09-07-2006, 06:58 PM   #7
pinggoy's Avatar
thank you so much....i will try to disassemble it.and i will post whats wrong.. i think its the drive shaft....
TAMIYA TRF416X
Old 09-08-2006, 02:34 AM   #8
TRF415boy's Avatar
your drive shaft is probably bent.
TRF415boy is offline   Reply With Quote
Old 09-08-2006, 03:07 AM   #9
U can add AW [anti wear grease] in the cup joint.I try this yesterday and it's good.So quiet car.Hope to useful.
khunballz is offline   Reply With Quote
Old 09-08-2006, 10:46 AM   #10
Regional Moderator
Mark Mixon's Avatar
Default Help
I've run this car a lot. The steering is turning too far and the CVD is chattering. Adjust the endpoints on your radio so it stops the chattering. Plus, it'll stop you from turning the wheels too far and locking the steering. It's a lot like slamming the front brakes before entering a corner. Your car will carry a lot more corner speed and decrease lap times. Good luck.
FSEARA
"They may be toy cars, but I spend REAL money to race them!"- Racer X
"It's only a big deal if you make it one."
Mark Mixon is offline   Reply With Quote
Beef Up Drivetrain BuggyKing Micro and Mini Scales 11 10-23-2007 09:41 AM
tc3 drivetrain kh15 Electric On-Road 10 09-05-2004 09:38 PM
HPI Pro3 Drivetrain Question rpmmaxxed Electric On-Road 3 06-12-2004 09:46 AM
Drivetrain problem Committed88 Electric On-Road 9 05-10-2004 03:19 PM
Drivetrain Belt Potato Electric On-Road 1 08-05-2002 08:53 AM
