ko propo radio charging ?'s >
Old 09-07-2006, 10:42 AM
buffalobill989's Avatar
Trader Rating: 50 (100%+)
Default ko propo radio charging ?'s
wondering how people charge there rechargable pack in there radio. is it with the plug that goes into ur radio & into ur chrgr, the wall chrgr or are u just chrging staight from ur chrgr leads to the bat. how many cells do i set it at & what amp rate. thanks for ur help
buffalobill989 is offline
Old 09-07-2006, 10:56 AM
pheyhoe's Avatar
I use on old Riko charger i used to charge a cheapo car that took 8 AA cells.
If not i take them out the charger and charge them in a seperate charger that runs off the mains.
pheyhoe is offline
Old 09-07-2006, 04:17 PM
Scottmisfits's Avatar
I went to radio shack and got myself another 8 cell holder. Now I just use alligator clips on the two 9volt style plugs on the end of the pack.
I usually charge those batteries at 0.5a or less. You don't need the power or punch out of them, you want them to last a long time. The lower the charge rate, the longer the charge will last. And set the charger to 8 cells
Scottmisfits is offline
Old 09-07-2006, 06:59 PM
dsrbltoys's Avatar
Same as Scott, except, I use .9 amp, and a .03 drop back / cut-off voltage on a turbo GFX!
dsrbltoys is offline
Old 09-07-2006, 11:35 PM
Rob Phillips's Avatar
Watch the plugs polarity, if you use one to charge your cells, it's different than Futaba and Airtronics. I can't remember which is + and which is -, but I know it was different. I just use my MM CTX and clip my leads to the "9 volt" connection.
Rob Phillips is offline
Old 09-08-2006, 06:47 AM
thanks alot guys
Old 09-08-2006, 07:06 AM
how long does it take to charge the pack at .4 or .5?
Old 09-08-2006, 08:36 AM
Mr. Shookie's Avatar
Well if 1.0amp charge rate gives you 1000mah per hour than .4 or .5 would yeild you 400 -500 mah's per hour..
Depends on how many Mah your batteries are...
Hope that helps,
-Shookie <><
Mr. Shookie is offline
Old 09-08-2006, 08:45 AM
so by my calcs it will take a 2500 mah bat about 5hrs to charge at .5 amp? how long do the radio packs last. how long does the cgarge typically last? is just for one night of racing?
Old 09-08-2006, 09:49 AM
Yup it will take about 5 hours...LOL
But it will be full when it is....
2500mah should last you a good long while...
When you see the Voltage drop below 10V recharge your pack..
Hope that helps,
-Shookie <><
Old 09-08-2006, 09:54 AM
thanks alot i think that will get it for now. wow i feelpretty spec getting a reg mod to help me out
Old 09-08-2006, 10:25 AM
Don't feel too special....I am just as retarded as the next guy...LOL
-Shookie <><
Old 09-08-2006, 10:32 AM
