Old 09-07-2006, 01:38 AM   #1
RocketRacer's Avatar
Default Charge/Discharge Temperature
charger - Supernova Competition
battery - Nosram PMax Vtec 4200SUP
discharge @ 20amps
charge @ 5.5amps
my concern was the temperature of the battery when discharging. it peaked at 65 degrees celcius/ 149 degrees farenheit. is this normal? i have never used a temp probe previously as my LRP Pulsar 2 charger doesn't have one.
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 09-07-2006, 01:47 AM   #2
Superkarter's Avatar
That's extremly high you want them to peak around 125F or 52C if they kept peaking at that temp you will kill them very quickly. Try lowering your delta peak to around 3mv/cell or 18mv/pack and never have the cells in sitting in the sun when you charge them.
Superkarter is offline   Reply With Quote
Old 09-07-2006, 01:56 AM   #3
that was the discharge temperature peak.
the charge peak is around 50C.
RocketRacer
discharge /charge rate for battery aussies1129 Electric On-Road 2 02-13-2008 12:32 AM
Charge and discharge rule of thumb? HeltonPrecision Radio and Electronics 1 01-21-2008 03:20 PM
help - charge / discharge / equalise simba Electric Off-Road 11 01-15-2008 11:16 AM
Discharge after a race or before you charge? jamescam Rookie Zone 10 08-12-2005 09:12 PM
