SpeedMerchant SpeedSpec >
Old 09-05-2006, 04:59 PM
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Default SpeedMerchant SpeedSpec
Looking to start a class with the speedmerchant speedspec kits on outdoor asphalt, hot weather tracks. Anyone run the speedmerchant speedspec kit on asphalt? If so how does it run compared to regular 1/10th scale kits? If running on asphalt, what tires and compounds should we run for low-med traction asphalt?
yyhayyim is offline
Old 09-05-2006, 06:00 PM
stormperson's Avatar
The speed spec is great on asphalt as the chassis has alot of grip in it and is easier to drive, alot more so than standard 1/10 scale cars. I would pick up some pink rears and magenta/double pink fronts.
stormperson is offline
Old 09-08-2006, 06:55 AM
yyhayyim's Avatar
Default Tires
Rear pink, and front magenta/dbl pinks? OK, but what brand, JACO, CRC, Trinity, etc...There are some good brands out there, but I'm looking for the best traction for low-mid grip asphalt with the best wear possible- what about the Jaco tires? Who can I get them from(in stock and cheap prices)?
yyhayyim is offline
Old 09-08-2006, 06:58 AM
yyhayyim's Avatar
Default Set Up
Also, how does set up work on these cars? Can you tune camber, caster, Toe, etc? Are there set up sheets for asphalt available? What is a good starting position for asphalt, low-med traction?
yyhayyim is offline
Old 09-08-2006, 07:37 AM
timmay70's Avatar
Speed Specs are standard link style pan cars in 1/10th scale. They use the old skool front ends that the Rev 4.5 uses. Adjusting toe is by tuning the control linkages from the servo to the steering blocks. For caster and camber adjustments, you'd use shims under the suspension arms. Our local track stocks Jaco tires for the Speed Spec classes, they seem to hold up quite well.
timmay70 is offline
Old 09-08-2006, 09:39 AM
Jeff Brown's Avatar
http://www.superiorhobbies.com/istar...&numperpage=12
Jeff Brown is offline
